  • View posts since last visit
  • View your posts
Logged in as Anonymous. Your last visit was on
Announcement & Sticky [23]
TopicsRepliesViewsLast Posts
No new posts  Sticky:
how to build a head light pod / air scoop
 [ 1, 2 ] by ROB_IOW
372393on 20th November 2017, 12:06 am by Mr B View latest post
How to change water pump
   by Guest
222488on 16th September 2017, 8:27 am by gtir_woody View latest post
This topic is locked: you cannot edit posts or make replies.  Sticky:
diagrams
   by nomad
42376on 18th June 2017, 8:14 am by gtir_woody View latest post
how to renew bigend bearings (engine in situ)
   by GTI-R US
510013on 8th May 2017, 7:15 am by Tassyguy84 View latest post
cv joint/driveshaft gator renewal
 [ 1, 2, 3 ] by nomad
606588on 25th April 2017, 9:19 pm by gtir_woody View latest post
Direct power feed from battery to fuel pump
 [ 1, 2 ] by Gaz GTiR
266069on 27th March 2016, 11:21 pm by Mr B View latest post
GTiR Manuals Download
   by Admin
108564on 5th January 2016, 9:59 pm by Bandyleg View latest post
oem paint codes
   by nomad
41665on 13th April 2015, 6:22 pm by nomad View latest post
Replacing rear arches
   by Admin
182478on 3rd September 2014, 10:41 am by gtir_woody View latest post
changing brake lines ect little tip for you's regarding fluid
   by GTI-R US
6888on 9th July 2014, 10:57 pm by keastygtir View latest post
change clutch ''how to''
   by GTI-R US
65742on 1st July 2014, 3:00 pm by mreguest View latest post
front crank oil seal replacement how to!
   by GTI-R US
122361on 31st March 2014, 9:32 pm by GTI-R US View latest post
high idle probs
   by Admin
02471on 28th February 2014, 5:05 pm by Admin View latest post
Turbo Scavenge pump
   by jambo_gtir
 A guide to fitting a scavenge pump
21882on 4th February 2014, 11:34 pm by Bones View latest post
track rod ends
   by nomad
171431on 15th November 2013, 1:56 am by jaypjay View latest post
How to replace the centre gauges with new 52mm items
   by watoga
215350on 28th October 2013, 10:53 pm by danr View latest post
honing/deglazing cylinder with engine in situ
   by GTI-R US
01223on 2nd September 2013, 4:56 pm by GTI-R US View latest post
engine oil
   by nomad
42396on 26th April 2013, 5:28 pm by Guest View latest post
how to ecu fault check
   by nomad
21011on 14th April 2013, 8:55 pm by nomad View latest post
arch trim repair 'how to'
   by GTI-R US
0988on 15th November 2012, 11:09 am by GTI-R US View latest post
Cheap antisurge in tank fuel collector
   by danr
31592on 18th March 2012, 1:12 am by SIR GTI-R View latest post
uprated fuel pump fitting
   by nomad
02200on 13th March 2012, 11:52 pm by nomad View latest post
Nissan pulsar/sunny gtir specs and advice
   by Admin
04086on 5th March 2012, 1:44 pm by Admin View latest post
No new posts
Mighty car mods episodes - GTIR
   by gtir_woody
213117on 23rd January 2018, 7:27 am by gtir_woody View latest post
No new posts
Nolathane Polybushing - A guide
   by wrc
 Subframe, suspension arms, links etc
171336on 27th May 2017, 7:14 pm by nomad View latest post
No new posts
removal of standard seat covers
   by Daveymeladdy
3446on 28th April 2017, 6:24 am by splmum View latest post
No new posts
Speedo cluster removal !
 [ 1, 2 ] by Cosmic73
291894on 4th April 2017, 11:18 am by mike74 View latest post
No new posts
Basic tuning with stock ECU?
   by Cosmic73
131895on 25th July 2016, 8:31 pm by Cosmic73 View latest post
No new posts
starter motor refurbishing
   by Stu
4734on 21st July 2016, 11:28 pm by GTI-R US View latest post
No new posts
How to replace standard brakes with twinpot 280mm brakes
   by Supernova
141764on 19th July 2016, 7:24 am by Stu View latest post
No new posts
How to fit front Modena lsd
   by Guest
31841on 15th July 2016, 9:20 pm by burrows1980 View latest post
No new posts
Image upload on forum
   by Andy Sunny Gti
2619on 10th March 2016, 2:35 pm by Stu View latest post
No new posts
Throttle Position sensor (tps)
   by Stu
141726on 3rd March 2016, 7:38 am by johnny gtir View latest post
No new posts
Synthetic or semi synthetic engine oil?
   by P4UL
1744on 3rd January 2016, 12:14 pm by shroom View latest post
No new posts
Learn to tune
   by gtir_woody
7984on 1st December 2015, 12:03 pm by ducie54 View latest post
No new posts
Rear Fog Bridge Original Cluster
   by shroom
10928on 27th October 2015, 6:46 am by johnny gtir View latest post
No new posts
How to remove the turbo? Also is this the 'bastard' nut?
   by Cosmic73
172058on 22nd October 2015, 4:31 pm by shroom View latest post
No new posts
Emission too high
   by boyciegtir325
4737on 13th May 2015, 9:21 pm by boyciegtir325 View latest post
No new posts
Turbo Rebuild
   by shroom
6856on 12th May 2015, 8:01 am by FPSChris View latest post
No new posts
willwood 4 pot ,310mm discs
   by sooni
 what brake fluid
8950on 29th March 2015, 4:35 am by grim_d View latest post
No new posts
relocating washer bottle
   by toaster55
71174on 2nd January 2015, 1:12 pm by stevie904 View latest post
No new posts
rear parallel link arms? and turbo elbow
   by arielgtir
7780on 25th December 2014, 5:54 am by gtir_woody View latest post
No new posts
How to fit nismo rear lsd
   by Guest
01112on 4th December 2014, 7:58 pm by Guest View latest post
No new posts
Full service manual
   by FPSChris
1921on 6th August 2014, 9:50 pm by nomad View latest post
No new posts
Crank pulley puller how to make
   by GTI-R US
141055on 9th July 2014, 6:20 am by Mr B View latest post
No new posts
Engine swap
 [ 1, 2 ] by Gti-r dannyboy
323369on 6th July 2014, 5:58 am by Gti-r dannyboy View latest post
No new posts
Swap worn out shifter bushing...
   by mreguest
01177on 1st July 2014, 1:11 pm by mreguest View latest post
No new posts
New fuel pump
   by Samgtir
8760on 26th May 2014, 7:59 pm by nomad View latest post
No new posts
reboring a maf?
   by weblizzer
2824on 17th March 2014, 4:24 pm by GTI-R US View latest post
No new posts
Wing mirror glass removal
   by Bones
0653on 6th January 2014, 11:09 pm by Bones View latest post
Topics [27]
  Back to top
Moderators : , johnny gtir, pulsarmoley, gtir_woody, Moderators
Users browsing this forum: None
You cannot post new topics in this forum
  • New posts New posts
  • New posts [ Popular ] New posts [ Popular ]
  • New posts [ Locked ] New posts [ Locked ]
  • No new posts No new posts
  • No new posts [ Popular ] No new posts [ Popular ]
  • No new posts [ Locked ] No new posts [ Locked ]
  • Announcement Announcement
  • Sticky Sticky
  • Global announcement Global announcement
