patrick the pulsar
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Go down  Message [Page 5 of 9]
101patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 3rd May 2014, 12:19 am
How did you get on with the man and the cams /shims James?
Looking very nice fella, looks like you've done a top job there, well done
102patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 3rd May 2014, 5:40 am
Gl3nnGTIR
Gl3nnGTIR
Looking good james, cant wait to see this back on the road. Engine looks sweet Smile
103patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 5th May 2014, 6:48 pm
GTIR James
Thanks guys.
Bob I still carnt get in touch with the guy about the cam shaft but stu on the OC has said he will sort it when his back from work in Brazil.
I ended up buying a brand new hks cam. Valve clearances seem ok but will probs get bigger when the cams are run in.
I will reshim the head after the run in period
104patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 6th May 2014, 7:07 pm
fred05
fred05
french connection
french connection
really good work here mate!
105patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 6th May 2014, 9:53 pm
So wish you lived next door to me...
106patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 9th May 2014, 8:16 pm
GTIR James
Got the engine back in the car last Saturday.
Loaded in the van
patrick the pulsar  - Page 5 A0592e03d85b46b52c06baa8d0313c9a_zps56fe35c0
107patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 9th May 2014, 8:17 pm
GTIR James
patrick the pulsar  - Page 5 Bad4e3dc75d1ed689ae421cf2368a38b_zps52685bb7
patrick the pulsar  - Page 5 76332867108d9465fa341a6c44b92259_zps52f16184
108patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 9th May 2014, 8:19 pm
You had it running yet James?
109patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 9th May 2014, 8:20 pm
GTIR James
patrick the pulsar  - Page 5 9c0296df3f1b2807e7b0f66687726da9_zps79277e87
patrick the pulsar  - Page 5 Abd76909e4847fe970fe64542f1e235f_zpsce4bd866
110patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 9th May 2014, 8:22 pm
GTIR James
patrick the pulsar  - Page 5 25c2d4b915c172f2b276f2c7acb37e66_zps18a2375d
patrick the pulsar  - Page 5 39af74b6741c67e6788411fd69db1d27_zps6ac814c1[/URL
[URL=https://smg.photobucket.com/user/Rolls/media/James%20engine%20build%202014/04d4afb815e1f2028c0b5a8047a7df7b_zpse290a30f.jpg.html]patrick the pulsar  - Page 5 04d4afb815e1f2028c0b5a8047a7df7b_zpse290a30f
patrick the pulsar  - Page 5 6727ed2c8bfabb825c562e1cd1316eb7_zps366ef621
111patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 9th May 2014, 8:26 pm
GTIR James
Not yet Pete. Hopefully get the cams run in on Sunday. I am going down to bobs tommorow to pick up standard ecu & injectors & Glenn has lent me a maf so were all good to go.
Need some fuel also. It's got little in the tank but that would have gone off by now.
The plan was to get it run in or at least 300 miles on it before North Weald but that isn't going to happen.
112patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 10th May 2014, 4:30 pm
good luck with the start up tomorrow james
im sure she will be fine though as you've done a fine job on her
did you end up fully rebuilding the gearbox yourself?
113patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 10th May 2014, 5:50 pm
Gl3nnGTIR
Gl3nnGTIR
Looking good james, looks like a great clean job you've done there!!!
114patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:00 pm
GTIR James
She's running. I've started on the running in.
No leaks etc. seems a nice quiet engine at the min with good oil pressure.
I'm upto 200 miles now & all seems well. But my good is it boring running a engine in. Had a aston Martin try it on with me up a long duel carriage way...... I was so ready to drop a gear or two but thought what's the point. Off he went.
800 miles more to do then it's time to refit the nistune, 700 injectors & z32 & get it mapped.
115patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:03 pm
GTIR James
First oil change after 10 miles. Some may think this is over kill but this engine has had a fair bit of machine work & I'm not chancing anything picking up.
patrick the pulsar  - Page 5 0e43387e6bfae284113c314e15335ad7_zps7cdac605
116patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:05 pm
GTIR James
Refitted all the standard breathing stuff. Pcv valve & pipe work
patrick the pulsar  - Page 5 9bdc6a35da4d0ee7879e4978f5bec317_zps8c29004d
117patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:05 pm
GTIR James
patrick the pulsar  - Page 5 164038c3353a40cdc1079943987dd04e_zpse46892ce
118patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:06 pm
GTIR James
patrick the pulsar  - Page 5 1e41389f26a8fdbbc7fd873610b16ae4_zpsc4a73991
119patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:07 pm
GTIR James
patrick the pulsar  - Page 5 E35fea70710a7809e1af8395acd2dc76_zps7d75eb18
120patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:08 pm
GTIR James
The new koyo rad. It's huge. Should keep things cool
patrick the pulsar  - Page 5 087e81d20b0151de682c15ef91e67876_zps74e0cf73
121patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:10 pm
GTIR James
New gauges all in & working.
Using a relay to switch these as find this much safer.
patrick the pulsar  - Page 5 Bc98d2e0a18cd5dc086e529c194b96b5_zpsf48c769b
122patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:17 pm
Nice work James
Yeah don't be tempted to bury your foot into the Axminster lol
Just ain't worth it no matter what others may say
Don't pussy foot about with it but at the same time don't nail it either and as I know to well it's very easy to get lured into racing someone  Laughing
123patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:23 pm
GTIR James
Agree bob. First 60 miles were done below 3,000rpm but using lots of hills.
Now I'm up to 200miles I'm using more rpm with no boost. (Just driving it like a normal car without the boost)
By 400 to 500miles I will bring a little boost in & drive a little harder
124patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 19th May 2014, 10:45 pm
That's the kiddy James
Slowly slowly catchy monkey  Wink
Had a guy in today buying an engine from us as some place in Peterborough built him an engine which blew up after 650 miles but in all fairness to him he said he got drawn in to ragging it and ended up with melted pistons for his troubles so cost him dearly
Just ain't worth the gamble!
And your doing the right thing with oil changes as mineral oil is relatively cheap so a few changes is peanuts during the first few miles when the initial cutting in is taking place
125patrick the pulsar  - Page 5 Empty Re: patrick the pulsar on 20th May 2014, 9:02 pm
GTIR James
Agree. I was using halfords mineral but I hate paying £20 for 5 litres of shit oil. I've now found a company that supply 20l of mineral running in oil for £40
Changed oil again tonight at 200 miles & swapped to this other stuff & it defo seems smother. I've just been out in the car & I'm at 300 miles now.
I only said to my misses on Saturday I'd like to do 300 miles this week & that's done & it's only Tuesday  Very Happy
I reckon engine will be run in by end of next week. All going well.
Back to top  Message [Page 5 of 9]
