patrick the pulsar
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
Go down  Message [Page 9 of 9]
201patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 26th November 2014, 12:14 am
Sure you've got the vacuum pipe plumbed in James and its pulling vacuum?
Could well be the regulator seized but that's quite unusual with stock regulator
202patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 26th November 2014, 8:59 pm
GTIR James
Yep vacuum is on & seems ok. I've had the regulator off & blown it out & it does open. Will check the pipes from the pump etc.
seems strange tho as the regulator controls the pressure
203patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 26th November 2014, 9:01 pm
Kinked pipe or the inside is collapsed if its double walled or braided lines ?
204patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 26th November 2014, 9:08 pm
GTIR James
Could be Johnny. I'm using double walled at the tank end & braided lines in the bay.
Will take the return pipe off from the tank & see if fuel comes out.
205patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 30th January 2015, 7:31 pm
GTIR James
In the end I fitted a adjustable fuel pressure regulator.
I don't realy like them but it has sorted my fuel pressure issues.
206patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 30th January 2015, 7:37 pm
GTIR James
Gave the old girl a good clean. (Was filthy just siting there)
Snow foamed the car. Love this stuff.
patrick the pulsar  - Page 9 Imagejpg59_zpsb3aeaea7
patrick the pulsar  - Page 9 Imagejpg56_zps267f2ca4
patrick the pulsar  - Page 9 Imagejpg60_zps35e5415f
patrick the pulsar  - Page 9 Imagejpg85_zpsaf18fb4b
207patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 30th January 2015, 7:43 pm
GTIR James
Fitted the nomad pillar pod & stack egt gauge. Will get that flocked at a later stage
Think that's enough gauges now
patrick the pulsar  - Page 9 Imagejpg75_zps477ee594
patrick the pulsar  - Page 9 Imagejpg72_zpse964ec56
patrick the pulsar  - Page 9 Imagejpg77_zpsdd069e32
Set idle speed. Checked timing etc. got idle speed down to where it should be
patrick the pulsar  - Page 9 Imagejpg93_zps72638531
Omex shift light wired up
patrick the pulsar  - Page 9 Imagejpg71_zpsc5ac81a1
208patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 30th January 2015, 7:45 pm
GTIR James
Will need to get the bumper repainted as it's had a reaction.
I got a quote from my local body shop we use at work & they want £300 to spray a bumper..... Sod that
patrick the pulsar  - Page 9 Imagejpg65_zps952d5ad6
209patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 30th January 2015, 8:01 pm
Looks like a very nice car. Could you try respraying the bumper yourself? Would be alot cheaper
210patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 30th January 2015, 8:34 pm
GTIR James
I painted it myself already mate but it's hard to get the a nice spray from rattle cans for bigger bits like bumpers etc, I may buy a small compressor & have a bash.
211patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 31st January 2015, 5:37 am
Nice update mate, getting stuff done thumbsup yeah screw paying that much. I need to paint my side skirts and front bumper. Think I'm going to give some colour matched spray cans a go for now.
212patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 31st January 2015, 7:49 am
GTIR James
Thanks mate. Worth a go with rattle cans. I did my side skirts & they came up well without any paint reaction. I find the spray pattern from rattle cans not wide enough for bigger panels.
213patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 31st January 2015, 11:01 am
Woody you got a compressor, if you not already got one get a cheap but half decent lvlp spray gun, charcoal mask, water trap & have a go with some 2 pack as results can be real good & spraying small parts such as bumper & sideskirts easy place to start learning gun etc. End result will be much better/durable plus not expensive as paint/primers will be cheaper over cans.
214patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 31st January 2015, 11:39 am
Yeah B I've got a compressor, I would just have to outlay on the kit you mentioned above, maybe its time for me to man up and learn the gun Smile
215patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 31st January 2015, 11:57 am
Yeh I think worth spending on the kit as not that expensive & cheap but decent gun will give better & easier results than cans.
Easy practice a bit on some old junk & small bits like u painting easy to setup environment for gun painting & reckon you will enjoy doing it & the results ...
216patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 31st January 2015, 12:26 pm
if you rub the bumper down where its reacted with some soapy water and 400 wet n dry then bring the car down to me il paint it for you and compound / polish it up on the same day, will do the whole thing for a oner including plastic primer paint and so forth and will be as good as new when finished
£300 is ridiculous
or as said have a crack at it yourself, baring in mind you do need to use a plastic primer or youll have probs
cars looking very good though james, hows the engine now hes redone it?
217patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 31st January 2015, 4:18 pm
We're are you based James?
218patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 4th February 2015, 10:19 pm
Hows the car going any updates ?
219patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 5th February 2015, 9:59 pm
GTIR James
I may take you up on that bob. I'm going to have another bash at painting it over the weekend. It seems the reaction was in the clear coat. I've rubbed it down with. Soap & 400 & it's gone so shouldn't be to bad.
I'm based in south east bones.
I will update over the weekend Johnny.
Cars still blowing a bit of smoke from cold start but I had the car mapped yesterday. It made 370hp with the boost tailing off. So will sort the boost & smoke then it should do 400hp.
At least I can drive it now. Pulls pretty hard now Very Happy Very Happy Very Happy
220patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 13th January 2016, 9:39 pm
GTIR James
Not undated for a while, main reason being me & my misses have just bought our first house so the house has become the priority over the car.
They say good things come to those who wait........ The car finally has a nice sized garage big enough for the car, to work on the car & all my spares.
Unfortunately the engine isn't looking good. This rebuild I had done by PEC rob @ (performance engine components) has been a smoker from the off.
Obv I'm not mege impressed with this. Now the car is in the garage I will pull the lump out & see what is wrong
patrick the pulsar  - Page 9 3303a7ec3b76fcc1fb93c1ee88b0441a_zpsk8ayy6vz
221patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 14th January 2016, 7:32 pm
About time fella, only joking. Shame about the your engine, you looking to do the work yourself this time?
222patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 14th January 2016, 7:46 pm
Sorry to hear the engine troubles. ..
Good to hear you have a decent sized garage to work on the old girl. Major jealous Laughing
I need to get me one of those wing covers to work on my car.
223patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 24th January 2016, 5:12 pm
GTIR James
Yep going to do the engine myself Pete. I don't trust the place who did it before & don't fancy going through all that again
224patrick the pulsar  - Page 9 Empty Re: patrick the pulsar on 24th January 2016, 5:17 pm
No i dont blame you, keep us updated on your progress
Back to top  Message [Page 9 of 9]
