patrick the pulsar
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Go down  Message [Page 2 of 9]
26patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 8:32 pm
GTIR James
Dash flocked. I'd been thinking of this for a while but couldn't decide on just getting the main dash or everything. Went down the route of getting the lot done.
patrick the pulsar  - Page 2 Image_zps16aaccbf
patrick the pulsar  - Page 2 Image_zpse7efae98
patrick the pulsar  - Page 2 Image_zps55704994
patrick the pulsar  - Page 2 Image_zps3e82a7d1
27patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 8:33 pm
Good power then, this will be the turbo I get next so should see similar figures. What's your next plans for it?
28patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 8:34 pm
GTIR James
Battery to the boot in enclosed box with fuel pump relay.
patrick the pulsar  - Page 2 Image_zps701ef7bb
29patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 8:52 pm
GTIR James
Metal door handle pulls fitted for the time being. Will make some flat carbon door cards soon.
patrick the pulsar  - Page 2 Image_zps620fb55d
30patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 8:55 pm
GTIR James
@pulsarmoley wrote:Good power then, this will be the turbo I get next so should see similar figures. What's your next plans for it?
Is a good turbo mate. Glad I didn't go down the 3071 route. If I was you I'd look at the new range of turbos depending on power & lag expectations. The new gtx range look like a good route;)
31patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 8:59 pm
GTIR James
Uncut front bumper fitted. Had to trim a fair bit off but kept all the slates. Mounted oil cooler behind front grill
patrick the pulsar  - Page 2 Image_zps496bfc3e
32patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 9:01 pm
GTIR James
Custom made pillar pod which is also flocked. Consisting of 3 60mm defi gauges. Was a bitch to make.
patrick the pulsar  - Page 2 Image_zpsecdfc40b
33patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 9:08 pm
car looks fantastic james, top job you've done there with mucho attention to detail, well done fella
34patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 9:27 pm
Wouldn't want more than 380hp I reckon but I'll check what's available cheers
35patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 9:30 pm
GTIR James
New rear exhaust box with roll down tip. This is pretty tight under there but it's been done so the rear diffuser can still be fitted
Excuse the rear bumper. I need to go pick one up from bob as this one has loads of cut outs
patrick the pulsar  - Page 2 Image_zps9618c39e
patrick the pulsar  - Page 2 Image_zps831475b9
36patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 9:38 pm
GTIR James
@GTI-R US wrote:car looks fantastic james, top job you've done there with mucho attention to detail, well done fella
Thanks bob. The car will be finished one day. Ps haven't done a list of other bits I need but will sort it.
37patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 28th August 2013, 10:32 pm
Nice work james ....whats all the gaffer tape all about ?
38patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 7:51 am
fred05
fred05
french connection
french connection
Flocked dash is awesome, i love the way you go too.
Uncut front bumpers are really Nice!
Will you fill the exhaust natural side hole? Same question as nomad, why the tape is made for?
39patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 6:28 pm
GTIR James
Yep I need to pop down the bobs & pick up a rear bumper. The gaffer tape is there to cover the original exhaust cut out & centre exit I had fitted. Original exhaust cut out will be filled etc
40patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 6:32 pm
GTIR James
Front arches have been cleaned & undersealed, new track rod ends & boots fitted.
patrick the pulsar  - Page 2 Stuffforsale024-4
patrick the pulsar  - Page 2 Stuffforsale022-3
patrick the pulsar  - Page 2 Stuffforsale043-2
41patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 6:34 pm
GTIR James
Under the bonnet
patrick the pulsar  - Page 2 Stuffforsale020-1
patrick the pulsar  - Page 2 Carpics062
patrick the pulsar  - Page 2 Copyofenginebuild068
42patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 7:43 pm
fred05
fred05
french connection
french connection
Nice work, awesome car!
43patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 7:59 pm
Wow super clean james ..... with your hub nut i noticed you dont have the castle nuts but it doesnt appear to be a locking nut ?
44patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 8:12 pm
GTIR James
Good spot. Yep that was a picture taken before it all went back together. Hub nut has a locking plate with a split pin through the middle:lol:
45patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 8:38 pm
Just wonderd as want to get some new hub nuts so wasnt sure if you had purchased them after .
46patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 29th August 2013, 9:20 pm
GTIR James
Hub nuts should be easy available from nissan mate. The locking plates are not available. Good job I found some new ones in the tool box at work.
47patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 30th August 2013, 12:16 pm
fred05
fred05
french connection
french connection
When i changed my bearing, the castle hat for the nut was in the box, with the pin sto secure all after install. The nut is not a castle nut himself.... ;-)
48patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 30th August 2013, 1:06 pm
Concrete-GTIR
Concrete-GTIR
nice car mate liking all the flocking Wink
49patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 26th November 2013, 11:42 am
GTIR James
Had a few days & evenings on the car. Also managed to go down to pick up some bits I needed.
Fibreglassed & filled the hole on another bumper I got off bob. Pretty happy with the results. Just need to get it painted now.
patrick the pulsar  - Page 2 Image_zps7bc68430
patrick the pulsar  - Page 2 Image_zpsbd39235f
patrick the pulsar  - Page 2 Image_zps5a73a61a
patrick the pulsar  - Page 2 Image_zpsb86b3aa7
50patrick the pulsar  - Page 2 Empty Re: patrick the pulsar on 26th November 2013, 11:47 am
GTIR James
Got the roll cage welded in on its foot plates
patrick the pulsar  - Page 2 Image_zps32fa7913
patrick the pulsar  - Page 2 Image_zps93f5b132
patrick the pulsar  - Page 2 Image_zps67460a29
Back to top  Message [Page 2 of 9]
