int(8) patrick the pulsar - Page 4
patrick the pulsar
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Go down  Message [Page 4 of 9]
76patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 5:26 pm
GTIR James
Today I took the bottom end into work to strip & check for damage etc.
removed lower sump & upper sump, oil pump, water pump crank pulley. Timing chain & guides. Oil pickup, baffle plate, mains & journals.
The crank doesn't look in to bad condition apart from one of the flywheel bolt treads being knackered ( got a polished & balanced crank to go in) the bottom end shells mains & journals have very slight wear as do the thrust washers.
Main & journal shells will be replaced anyway.
Pistons were removed & still look pretty shiney, just slightly carboned up (nothing a bit of brake cleaner won't sort)
Now for the shocking part, whilst checking the bores it would appear there is a lot of pitting on the cylinder walls. I'm pretty surprised the damage hasn't snapped a piston ring. Unfortunately the damage isn't going to come out with a hone so now I will need to source a new block to accept my 86mm cps as I don't want to go overbore.
I personally think the damage was caused from the engine sitting for a long period of time without a squirt od wd40 down the bores.
77patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 5:30 pm
GTIR James
patrick the pulsar  - Page 4 Image_zps0ee9086d
patrick the pulsar  - Page 4 Image_zpsc264df6d
patrick the pulsar  - Page 4 Image_zps1c4e7ffa
patrick the pulsar  - Page 4 Image_zpsdc0e99cc
patrick the pulsar  - Page 4 Image_zpsfd01d2fd
patrick the pulsar  - Page 4 Image_zps9b74ce87
78patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 5:32 pm
GTIR James
patrick the pulsar  - Page 4 Image_zps5f5dbf4f
patrick the pulsar  - Page 4 Image_zps18b5a79d
patrick the pulsar  - Page 4 Image_zpsa90a80c6
79patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 5:33 pm
GTIR James
patrick the pulsar  - Page 4 Image_zps41ed640b
80patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 5:39 pm
GTIR James
I also pulled the end case off the gearbox removed selector forks & rods. Just need to strip input shaft & main shaft but from what I can see of the gears & synccros etc it all looks pretty good.
Will take this into work & press the gears & synchro hubs off & see what's what.
patrick the pulsar  - Page 4 Image_zps850093ea
patrick the pulsar  - Page 4 Image_zpsaeeded09
patrick the pulsar  - Page 4 Image_zps14736dce
patrick the pulsar  - Page 4 Image_zps6362f471
81patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 6:14 pm
Well done for getting stuck in there  Wink  If you do need a replacement block whats that gonna cost against a set of 86.5mm cp pistons?
82patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 6:23 pm
Gl3nnGTIR
Gl3nnGTIR
Nice to see you getting on mate Smile
83patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 7:02 pm
GTIR James
@pulsarmoley wrote:Well done for getting stuck in there  Wink  If you do need a replacement block whats that gonna cost against a set of 86.5mm cp pistons?
Will pm bob tomorrow but his away till new year now.
86.5 cps will cost £350 plus shipping but then I need a rebore & hone probs £120
If I get a new block I only need new piston rings
84patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 28th December 2013, 7:07 pm
The cost of the replacement will be the determining factor then. You will probably have to hone the replacement as well for piece od mind but I suppose you have a honing tool?
85patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 29th December 2013, 6:39 pm
fred05
fred05
french connection
french connection
what about the gearbox? is it easy to verify all the stuff inside? i'm a bit afraid of rebuild mine....
86patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 22nd January 2014, 9:23 pm
GTIR James
@fred05 wrote:what about the gearbox? is it easy to verify all the stuff inside? i'm a bit afraid of rebuild mine....
Sorry Fred I've only just seen your post. To be honest I think our gearboxes are pretty straight forward to strip etc
Get stuck in.
87patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 22nd January 2014, 9:35 pm
GTIR James
Haven't updated for a while. But today I got the gearbox pretty much back together (just the end case to go on)
Stripped all gears & cyncros etc. all looks in extremely good shape.
The gearbox that I'm using now is the one the car originally came with. (Hopefully be better than the old so called rebuild one......)
I'm just waiting on parts to be delivered then its time to crack on.
Bob has kindly sorted me a bottom end which I will be picking up shortly.
I can now see why people just buy a second hand forged lump. All the parts work out pretty expensive, saying that I am pretty anal & replace things that possibly don't need it
Parts so far
Timing chain & tensioner genuine
Thermostat genuine
Cyclinder head, ported & flowed, 3 angle seats, bronze guides, cc matched, shimed
Hks 264 cams
Rocker stoppers
Cosworth head gasket
New cp riston rings
Acl main bearings
Acl rod bearings
Acl thrust
Arp big end bolts
Brand new oil pump genuine
Brand new sump pan genuine
The list goes on. Hopefully be worth it
88patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 22nd January 2014, 9:54 pm
At least if you've sourced and fitted the bits its gives you peace of mind. When do you reckon you will have it back on the road?
89patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:08 pm
GTIR James
Update time. This build has take forever.............. But I should be finishing off the engine tommorow & picking it up from work ready to put back in the car.
Clean pistons
patrick the pulsar  - Page 4 3b118afa82194350f4017d2b3e66a21a_zps147bc27e
The head
patrick the pulsar  - Page 4 4b450f48a0f224fe15d06ccdad5735d6_zps4c5ef5ae[/URL
[URL=https://smg.photobucket.com/user/Rolls/media/James%20engine%20build%202014/24078f16ae7b39b1c038412054ff3ffa_zps2927b581.jpg.html]patrick the pulsar  - Page 4 24078f16ae7b39b1c038412054ff3ffa_zps2927b581
patrick the pulsar  - Page 4 4d1bb68725404e5ad8e78e43945faac4_zps4a48e76b
patrick the pulsar  - Page 4 E952808ed36c17ab80d4385a986bee00_zps061f493a
[URL=https://smg.photobucket.com/user/Rolls/media/James%20engine%20build%202014/36162e050b2fc62b02eb37ac32b9c1a9_zps12551054.jpg.html]patrick the pulsar  - Page 4 36162e050b2fc62b02eb37ac32b9c1a9_zps12551054[/URL
90patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:10 pm
GTIR James
The block.
patrick the pulsar  - Page 4 1898b022a437f0e413ca27f205bcd9ec_zps68511a1b
patrick the pulsar  - Page 4 3dc756748ac01b0b325b88d91cdb3003_zps4778ada6
patrick the pulsar  - Page 4 B212317315c3ea0e0b90164e70ca2380_zpsaf63efe1
91patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:13 pm
GTIR James
patrick the pulsar  - Page 4 3b8257dab7f12d4661da384b827f1c0a_zps8d588c95
92patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:14 pm
GTIR James
patrick the pulsar  - Page 4 3aa735f6b10d0896b243864051be50e6_zps9a09df5f
93patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:14 pm
Nice work james
94patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:17 pm
GTIR James
patrick the pulsar  - Page 4 59644ce7d9faeefc1635104a68f99397_zpsc5c112f8
patrick the pulsar  - Page 4 F2735c68f4efcfbc514f66852a7cc034_zpsca9ebd75
patrick the pulsar  - Page 4 799c2f1372bdbb916ebc4c68a4aa71ef_zps5f1a0392
patrick the pulsar  - Page 4 Ca625332bbc5f67548c15384e2d6947e_zpsdf382d20
patrick the pulsar  - Page 4 695d362b1b397fc2c265a1e28f0ebd25_zps37bcb4ef
95patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:18 pm
GTIR James
patrick the pulsar  - Page 4 909f75ad9cad823badd4168d636c28ee_zps619808f0
patrick the pulsar  - Page 4 50e6c5a91cc37545b38e30f522f4881a_zpse06e39d3
96patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:22 pm
GTIR James
patrick the pulsar  - Page 4 Af47486a46dd8f7c7a3ab6eb57b1d6d3_zps036425d5
patrick the pulsar  - Page 4 A1400eb49dcbf902e346c7321cfdaebb_zpsd7d12552
patrick the pulsar  - Page 4 808a762946514deaa8642b421aa5a155_zpscee83f68
patrick the pulsar  - Page 4 0cdefe92b5337ab02037853e3aa77466_zpsd9f714a5
97patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:25 pm
GTIR James
Purchased new stack oil pressure & boost gauges. Expensive but look the tits......
patrick the pulsar  - Page 4 Ae5c52603de531265442764a22c216fe_zps7128d411
98patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 8:31 pm
GTIR James
It's been a long process with lots of problems along the way & I now have a empty wallet...... To be honest tho I love these cars & think building them is part of the fun but can see why people buy a ready build engine. I will 100% agree it's cheaper to buy one already build & stress free.
I'm up again early tomorrow to go into work to bolt the gearbox, transfer box & engine loom on & it should be back in the car by tommorow afternoon.
God I'm looking forward to having a lay in on Monday. I've been up at just gone 5 for the past week to get into work early to get it built. Good fun mind,
99patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 9:00 pm
Great effort mate well done will be worth it when its running
100patrick the pulsar  - Page 4 Empty Re: patrick the pulsar on 2nd May 2014, 9:03 pm
Some nice work james ..... i know who to call when i want mine rebuilding  Wink  ...
Back to top  Message [Page 4 of 9]
