Gtir Motorsport club » Tech room » Help and Advice » Engine
Engine
1 Engine on 16th June 2013, 3:51 pm
Gti-r dannyboy
Hi there, had my pulsar a few years now my engine has always had a loud ticking noice coming from the engine its self, just wondering is this normal or not?
2 Re: Engine on 16th June 2013, 3:55 pm
Is it coming from top end of the engine?
Ticking noise is prob injectors? Tapping noise from top end will be valve clearences
3 Re: Engine on 16th June 2013, 4:16 pm
Bit more detail danny if you can if you listen can you locate the noise to any specific area at all ?
4 Re: Engine on 16th June 2013, 4:45 pm
Gti-r dannyboy
Just had top of the engine re-built head skimed, new cams( off bob). gets worse has the engine warms up.never had any effect on preformance tho. Bust a oil pipe for the oil cooler thought it was head gasket so took the head off, a very costly mistake, i new the cams had ware anyway but with the head off thought mite aswel but new 1s in.
5 Re: Engine on 16th June 2013, 4:46 pm
Gti-r dannyboy
6 Re: Engine on 16th June 2013, 4:52 pm
Did you have it re-shimmed when it was rebuilt ? If you have put different cams then it would need to be shimmed to those cams .
7 Re: Engine on 16th June 2013, 4:52 pm
Is it more of a tapping noise than a clicking sound? Sounds like you need to reshim your valve clearences
8 Re: Engine on 16th June 2013, 4:56 pm
Gti-r dannyboy
Its bin re shimmed, and yes its a tapping noice, with it being re-shimmed i thought that would cure the problem. Gaz next time i come j10 meet have a listin
9 Re: Engine on 16th June 2013, 4:59 pm
Can you hear where abouts it is more intake side or chain end .......?
10 Re: Engine on 16th June 2013, 5:02 pm
Have I met you at j10? Cant picture who you are? Laughing
Maybe post a video up on here & we can have a listen
11 Re: Engine on 16th June 2013, 5:12 pm
Gti-r dannyboy
Am doing this off my iphone regards pics and stuff have only just leant 2 speak on this fourm( thick i know) but i will try. I came last year, pulsar wouldnt start first time when leavin so we all had a good look under the hood 2nd time off tryin in worked, first and only time it has failed 2 start sods law it happended when meeting with u guys!!
12 Re: Engine on 16th June 2013, 5:16 pm
I do everything off my phone danny  send your pics and vids to something like photobucket then paste the links on here very simple or email them to me and i will post them up for you seeing as im nice lol .
13 Re: Engine on 16th June 2013, 5:19 pm
I cant remember that mate? I may not of been at that meet? lol
14 Re: Engine on 16th June 2013, 5:28 pm
Gti-r dannyboy
Well next 1 u arrange i will b there, with 1 not being 4 a while. Are you from the midlands gaz.
15 Re: Engine on 16th June 2013, 5:29 pm
just hope it aint bottom end danny as that can sound as though its coming from the top.
other stuff it could be is
stretched timing chain, defective tensioner
noisy ps pump or alternator
if it mainly does it as you feather the throttle between 2-3k under load then its more than likely bottom end which aint so good.
see if you can post a vid up of the noise
16 Re: Engine on 16th June 2013, 5:37 pm
Gti-r dannyboy
Hi bob i have thought it was bottem end from day 1, witch i still think it is, whats the damage, or shal i call u 2 morro 4 a chat. What damage is it goin course drivin it?
17 Re: Engine on 16th June 2013, 5:46 pm
No from Derbyshire mate
18 Re: Engine on 16th June 2013, 5:56 pm
if its not too bad at the mo you may still be able to save the engine and crank.
carry on driving it and youll put a rod through the side of the block then whole engine will be scrap
I need to listen to it to have some idea, trouble with noise vids though is that its hard to pick out noise as it gets distorted over all the other noises.
why don't you just drop the complete sump and undo the bigend bearing caps, will take you 2-3 hours to check them over.
if one has spun you will soon see it.
if all is good then just fit another set of shells in her and then you have piece of mind that its not that
19 Re: Engine on 16th June 2013, 6:09 pm
Gti-r dannyboy
Hi gaz derbyshire is 45 mins from me and i wouldnt mind comin up and havin a chat with you, up 2 u at the end off the day. Bob just spoke 2 my dad for half hour and with the noice being there 4 2 years he sayes if it was big end it would off died my now!!
20 Re: Engine on 16th June 2013, 6:11 pm
Yeh if you want to pop over mate its no trouble. I wont be able to sort your problem but I will be able to prob diagnose it
21 Re: Engine on 16th June 2013, 6:31 pm
Gti-r dannyboy
I know u wont be able sort the problem out. but with havin the car 4 3years and not speakin with any1 with a plusar it would be nice 2 speak 2 sum1 with the same intresest
22 Re: Engine on 16th June 2013, 6:32 pm
Yeh of course mate, will be good to meet you & have a chat, you have a PM
23 Re: Engine on 16th June 2013, 7:36 pm
Gti-r dannyboy
Pm?
24 Re: Engine on 16th June 2013, 7:39 pm
PM = private msg mate, top of the page it will say you have 1 new msg
25 Re: Engine on 16th June 2013, 7:54 pm
watch that gazz geezer he will be after some bum action:lol:
