Gtir Motorsport club » General Discusion » New forum members » Hi from The Netherlands
1Hi from The Netherlands Empty Hi from The Netherlands on 21st June 2013, 6:59 am
EricYellow
EricYellow
Since I'm new to this forum a little introduction is in place.
After doing without a GTI-R for about 7 years I've found one again.
I've been looking in the UK for a big spec one, been in contact with a few guys but somehow I didn't end up with a car.
I almost gave up but then I got a LHD car offered here in The Netherlands.
The price was to good to say no to so I bought it.
It was a red one when I got it, but the paint wasn't to good and a little rust here and there was present.
So there was a good excuse to give it a respray.
The car was fitted with some good specs when I got it.
Wiseco forged pistons
Tomei cams
gas flowed head
shotpeened rods
Greddy rocker stoppers
880cc injectors (bigger ones are ready to go in for remap)
Garrett GT2876R (now changed to GT3071R)
Custom 3 inch stainless exhaust system
Walbro 255 l/h fuel pump
JGY fuel rail
Nismo fuel pressure regulator
Nismo engine mounts
DTA S60 pro management
removed distributor, replaced by coil pack
Greddy type s blow off valve
Koyo Z radiator
Apexi air filter
Nismo radiator cap
Hybrid intercooler kit
JGY 4 puck clutch kit
Fidanza flywheel
AEM AFR kit
HKS turbo timer
B&M short shift kit (already removed)
Hi-Spec 4 piston big brake kit
50mm lowered
16 inch wheels (changed to 17 inch)
Power has been measured at 386bhp.
I'm sure I've forgotten some things, but this is the general idea of the car.
This is what it looked like when I got it.
Hi from The Netherlands Sunny
2Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:02 am
EricYellow
EricYellow
And then I got started....
Picturse say more then words Cool
Hi from The Netherlands 48D060B8-B9EF-456A-98B5-5FDB2C505F87-990-0000014A15D68769
Here's about 958 bhp on/under the lift ;-)
Hi from The Netherlands 1A2B072F-90A0-4973-A34B-E53103A5BE55-990-0000014A26F853C4
The left rear arch was quite rusty, so were the (crap...how do you call the part behind the sideskirts?) Sills?
I cut the rusted parts out and welded a new arch in and fixed the sills left&right.
The front wings also had some rust, so cut that out and welded new pieces in too.
Hi from The Netherlands Foto-1
Hi from The Netherlands Foto3-2
Hi from The Netherlands Foto4-1
Hi from The Netherlands Foto6
Hi from The Netherlands Foto9
Hi from The Netherlands Foto13
After stripping it down, it went to the paint shop.
Hi from The Netherlands 9EE4F97F-2D56-4E80-9CC2-5218AA237F23-17179-000003F8897D957C
Hi from The Netherlands 393C3A46-F731-4B6D-A8D6-F9266C341D44-17179-000003F89B69415C
Hi from The Netherlands 72E328A2-6C93-4117-990F-70170E842DFE-17179-000003F8A3482477
Hi from The Netherlands 45331F27-D5C4-45B3-9979-D265B090A217-63054-00000C0E25E953ED
Hi from The Netherlands D9B6F724-D919-482C-AB6E-96FE7F448D80-63054-00000C0E5E3D25B1
Hi from The Netherlands FA3E3CAA-B2AF-42D2-AED8-322ECC00FCA1-63054-00000C0E1005A0DB
Hi from The Netherlands AA0035C9-66D0-4EA3-A283-C72D9FD048BF-63054-00000C0E3B930B1B
Hi from The Netherlands 1223
A "newish" gearbox
Hi from The Netherlands 82FFDA27-F372-4950-BAED-21219BE000C0-10888-000001EC10E27126
Hi from The Netherlands B6F9EFB5-B374-47D6-B3C9-457C2C84DC64-10888-000001EC1BCC167F
Fitted with the STR brace
Hi from The Netherlands C98E2A1C-C62B-425B-8F5C-B00E4FDB3E7D-6930-0000062F653343DB
Hi from The Netherlands Foto1-2
Hi from The Netherlands Foto4-2
Hi from The Netherlands Foto3-3
Hi from The Netherlands 9A52783D-D8C0-4D09-9957-01D029074D7A-6930-0000062F5518A76D
Hi from The Netherlands 687D724C-2B0A-4611-AD32-2E776D2B346D-6930-0000062F38FCD745
Hi from The Netherlands 30647A12-E72D-46B3-8F35-0263B2CEBCCF-877-00000125B0D5DF87
At the moment this is how the car looks.
Most of the bodywork has been done, windows have to be put back in and then I can get started under the bonnet.
Will be quite a while before the engine can go back in since I want everything to look as good as new when I open the bonnent, so a lot of cleaning, sanding, painting will be done.
Hi from The Netherlands C75B95E6-7CB4-450A-A266-C4FB0EA06580-1458-000001F04082C5EE
Hi from The Netherlands F84FBEA1-54FD-4DCA-B556-7CE54D5B4FB9-1458-000001F02F585965
Hi from The Netherlands 67F664E2-F5E3-4B39-91A9-2C7127BD3CBF-1458-000001F0380537F0
Hi from The Netherlands AC4CE1B4-EA75-4C78-AAF4-9061ACC904D2-6523-0000097A07536D52
Hi from The Netherlands 2558DA89-278C-4C4C-A257-F6CCA6FC3296-6523-00000979FF3DDF42
Time to get started under the bonnet.
Hi from The Netherlands D6CD72BF-CA2F-4A41-8D26-4F8187D4799B-2347-000003CEDB4DE036
Hi from The Netherlands 8142DF3C-2C24-426C-8AFD-BF835FD93531-6523-00000979EFDC53F0
3Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:03 am
EricYellow
EricYellow
After a period of a lot of work to just about every car but mine, I had a couple of days to get started on it again.
Put the engine back together, fitted the gearbox and put the lot back in it's place.
This is how the car is at the moment, maybe I'll get around to doing some more in the next few weeks but if the customers keep coming in like they have been the last few months, it could take a while to update this topic.
Hi from The Netherlands E9EE486A-44BA-4BA2-9103-6C92D4869CE7-40063-00001A959E41A090_zpsf3e08499
Hi from The Netherlands 582F35F7-3ECB-4AFD-B253-41AC25B9B24F-40063-00001A958C645787_zps3df27b31
Hi from The Netherlands 5503002B-E697-4DA1-BD14-6966524B0DF0-40063-00001A958473FBEF_zps193b20c5
Hi from The Netherlands 093145BA-04A9-45AC-A4AE-11A5C61D5417-40063-00001A95B14D27BB_zpsf1c10165
Hi from The Netherlands 41F8565A-A549-4967-9DCA-20FC413BFD76-40063-00001A95E89296BB_zps11c63345
Hi from The Netherlands D0869A68-7937-4763-8E03-33AA6EC83E07-40063-00001A95F8517D4B_zps68a0d613
Hi from The Netherlands 7F4994C6-B2DE-4ABD-8707-BCA0BF0C6568-40063-00001A962C75E5AC_zpsc17b9035
Hi from The Netherlands EB5A3958-D428-4E22-94FB-ED69A9CF4DBB-40063-00001A96352D41AB_zpsaf1b15ab
4Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:03 am
EricYellow
EricYellow
Slow but steady progress.....
Hi from The Netherlands Foto_zps1b855b73
5Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:04 am
EricYellow
EricYellow
The first signs of life have arrived Cool
Hi from The Netherlands Fotog_zpsf25972c1
Hi from The Netherlands Fotoj_zps478566ae
6Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:04 am
EricYellow
EricYellow
And it's time for a test drive! (without a few windows....)
Hi from The Netherlands Foton_zpsd5e78102
Hi from The Netherlands Fotoo_zps6af3f9f0
Hi from The Netherlands Fotoq_zps868adc9e
Hi from The Netherlands Fotom_zps691c5bbe
Hi from The Netherlands Fotol_zpsea23e4e7
7Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:10 am
Nice Car ...
I love the wheels in the first picture
8Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:20 am
Wow
Simply stunning!
I wasn't expecting the dramatic colour change then. It looks stunning!!!
9Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:49 am
EricYellow
EricYellow
One of the last things to do included fitting a new front windscreen and getting the rest of the windows tinted.
Hi from The Netherlands 943210_477699902311039_2039866057_n
Hi from The Netherlands 1010668_477699892311040_2068946614_n
Hi from The Netherlands 1012182_477699905644372_2147474092_n
Hi from The Netherlands 1000532_477827932298236_698819363_n
A set of brake ducts and another propshaft are still needed to finish the job.
10Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 7:51 am
EricYellow
EricYellow
Nice Car ...
Wtf??
You love the wheels??
They are yours if you want them, just have to come and pick them up Wink
11Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 8:46 am
Concrete-GTIR
Concrete-GTIR
The wheels I. The first pic look like oz volcanos or polaris's getting quite rare now not many cone up for sale
Nice car mate and welcome Smile
12Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 8:55 am
yeah welcome eric
absolute to notch work there and a stunning colour too, well done fella well done
13Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 9:26 am
Welcome pal Wink clean lokking R there
14Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 5:25 pm
welcome very nice motor
15Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 5:36 pm
Very very nice pulsar like the attention to detail with all the cleaning and repainting .Cool
16Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 6:53 pm
Beautiful car mate, reallty impressed with the engine bay and loving the new colour
17Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 8:28 pm
Girl racer
Girl racer
Wow, very nice Smile
18Hi from The Netherlands Empty Re: Hi from The Netherlands on 21st June 2013, 8:39 pm
Good write up there, love the colour. That engine bay is good enough to eat off Cool
