Gtir Motorsport club » Tech room » Help and Advice » Front camber alignment
1 Front camber alignment on 29th June 2013, 8:55 am
Viper911
Ok so in getting alignment done, wasn't as bad as I thought, tho the front camber has both tyres facing on by 1.2 degrees both sides. Obviously miles away from spec in sticky here and red on screen lol
Is it that bad an issue? Would assume tyre wear would become an issue at some point
2 Re: Front camber alignment on 29th June 2013, 9:04 am
Viper911
Just been told that's the setting for fast road use, but tyres will obviously wear more easily on inside
Sound about right?
3 Re: Front camber alignment on 29th June 2013, 10:12 am
r called jay
Yeah sounds about right if you're going to use it for fast road/trackdays.
If not I'd set it to more like the standard settings as, like you say, you will wear the inside edges of the tyres for no reason.
4 Re: Front camber alignment on 29th June 2013, 12:20 pm
yes agree with above 1.2 degree toe out is too much for just road use and youll eat through tyres
just get them to toe it out a fraction more than stock settings or it will feel skittish on initial turn in
