Gtir Motorsport club » Gallery » Members gti-r's » French Rally Sunny GTiR
Go to page : Previous  1 ... 5, 6, 7 ... 10 ... 14  Next
Go down  Message [Page 6 of 14]
126 Re: French Rally Sunny GTiR on 14th August 2013, 1:27 pm
fred05
fred05
french connection
french connection
OIl seal at home, and new steering wheel home too!!! i will spend this evening in the garage Laughing
i found some enkei PCD 4x114.3 at a good price, so i'll will go this way and buy some adaptors at superforma Wink. i'm sure ET15 will be not as bad as i think.
MOT will be passed first week of september as tomorrow holiday begin and let's go for a 1000 kms trip to reach the Bretagne for 2 weeks What a Face !!!
127 Re: French Rally Sunny GTiR on 2nd September 2013, 7:44 am
fred05
fred05
french connection
french connection
hi all, after two weeks out of the garage, i'm back to work onmy car!
yesterday, wheelchanging to pass the MOT early this week, and re-fill the gearbox with new oil...
here some pics of the oil seal change and the inside of the car with a new gearknob and new steering wheel :
strutbrace on!, need a little clean up in the engine bay...
RRS dished steering wheel and D1 spec gearknob
oil seal....was partially destroyed, so i understand the big leak....
i receive my enkei nt03 last week...they are awesome!!
128 Re: French Rally Sunny GTiR on 2nd September 2013, 12:32 pm
fred05
fred05
french connection
french connection
mid-day update!!
gearbox is plenty of oil now
and i put the Clio steel wheel to pass the MOT...this evening will be big cleaning of the internal, and check all the levels before taking her for a little ride!
129 Re: French Rally Sunny GTiR on 2nd September 2013, 3:26 pm
Nice buy Fredric Cool
130 Re: French Rally Sunny GTiR on 3rd September 2013, 1:30 pm
fred05
fred05
french connection
french connection
Thanks Andy!
today's update, i take it for a short ride to test drive it and see how it goes!!
so, she needs a full chassis set up, an exhaust, a BOV, 4 nice wheels on, and to be slammed!!!! ah ah
she's quite powerful, but seams to be less angry than my previous one, but as it is standard i'm quite happy!!
this evening she got the right to be washed out (i cleaned it inside yesterday evening!)
thursday morning, MOT!!!! cheers cheers cheers cheers
superforma pcd converters ordered to put the enkei on!
131 Re: French Rally Sunny GTiR on 3rd September 2013, 2:42 pm
Concrete-GTIR
Concrete-GTIR
Looking forward o seeing the enkei fitted Fred Smile
132 Re: French Rally Sunny GTiR on 3rd September 2013, 2:48 pm
fred05
fred05
french connection
french connection
me too Concrete!!!! for sure it will go perfectly at the rear and fill the wheel arches, but it will be tight at the front i think, and maybe rolling the fender will be needed...let's see that soon...
133 Re: French Rally Sunny GTiR on 3rd September 2013, 3:20 pm
Hardy172cup
Hardy172cup
She's looking good Fred Very Happy
134 Re: French Rally Sunny GTiR on 4th September 2013, 7:24 am
Concrete-GTIR
Concrete-GTIR
yes i agree its goign to be tight with the width of the wheel plus your hubcentric spacers its goign to make the wheels come out quite away hopefully it will be just right Smile
135 Re: French Rally Sunny GTiR on 4th September 2013, 7:30 am
fred05
fred05
french connection
french connection
i'm sure it will looks far better with other wheels!!
yesterday evening i went for a new little ride to discover a little more the girl Wink
i noticed some faulty thing :
- all the engine buffers are worn and dead
(i already bought some poly bushes from paul so i just need to paint the supports thing because gold it's not my cup of tea! But what about the front anti-torque (they are 2 actually front and rear) buffer, are they available polybushed or stiffer than standard?
- it smells fuel after a little ride at idle Sad
maybe the fuel pipes are worn too....don't know
- after a 10min idle, then cut, she is diffucult to start up...she seems to be fuel filled...
136 Re: French Rally Sunny GTiR on 4th September 2013, 8:05 am
Did you clean out your maf Fred as didn't you have a code 12 when you got it?
137 Re: French Rally Sunny GTiR on 4th September 2013, 8:37 am
fred05
fred05
french connection
french connection
Not yet moley, she runs quite well appart these troubles, and i didn't check again after the yesterday rides.
i disconnected the battery several times so it erase the memory
i'll check at mid'day which code is flashing
138 Re: French Rally Sunny GTiR on 4th September 2013, 8:53 am
Also what did you do with regards to your compression readings?
139 Re: French Rally Sunny GTiR on 4th September 2013, 8:59 am
fred05
fred05
french connection
french connection
several starts up, and that's all for the moment, i'll check again after a few more rides Very Happy
140 Re: French Rally Sunny GTiR on 4th September 2013, 9:05 am
I doubt the readings will change much Fred, you were down by 45psi on no4 cylinder; could be a ringland failing. With the smell of fuel have you checked all your fuel lines?
141 Re: French Rally Sunny GTiR on 4th September 2013, 9:27 am
fred05
fred05
french connection
french connection
I was between 7 and 8 bar so between 100 and 120 psi!!!! Smile
and the 3 others was 10 bar so 145 psi....
rather than putting 800 quids or more in a better health engine, i prefer dreaming of good readings!!! Razz Razz
i'll check that maybe next week!
As stated elsewhere (i think it is on the OC ?!?), compression readings can be many things...ring fault or valves faults....or cylinder fault!!
142 Re: French Rally Sunny GTiR on 4th September 2013, 9:41 am
Yeah it could be a number of things Fred but whatever it is isn't gonna fix itself Wink  Just thinking better to fix a problem now before it could do more damage?
143 Re: French Rally Sunny GTiR on 4th September 2013, 9:45 am
fred05
fred05
french connection
french connection
sure you're right moley, but if it is a ringland failing, i need to drop the engine out and dismantle it....as it is 247000 km, i bet it doesn't worth it and i'd go for a better one (forged one?? why not!!), cheaper than a rebuild.
144 Re: French Rally Sunny GTiR on 4th September 2013, 9:57 am
Fair enough then Fred, keep us updated Wink
145 Re: French Rally Sunny GTiR on 4th September 2013, 12:05 pm
fred05
fred05
french connection
french connection
So fault code check say 55 Cool
146 Re: French Rally Sunny GTiR on 4th September 2013, 12:09 pm
Do a leakdown test then it will give you more of an insight to where its leaking ?
147 Re: French Rally Sunny GTiR on 4th September 2013, 12:14 pm
fred05
fred05
french connection
french connection
What is a leakdown test??
148 Re: French Rally Sunny GTiR on 4th September 2013, 12:19 pm
https://www.youtube.com/watch?v=WgrfT0LFMhc&feature=youtube_gdata_player
like this mate.
149 Re: French Rally Sunny GTiR on 4th September 2013, 12:35 pm
fred05
fred05
french connection
french connection
Thanks! pretty long vid mate, here the link to explain quickly LINK!!, but this test can't be done by myself as i don't have any air mean and no device adapted.
i'll take the compression back next week to see if something moved, and than go to the leakdown thing if i can find a mechanic who can be do this...but is really not an easy test !
150 Re: French Rally Sunny GTiR on 4th September 2013, 12:51 pm
You can pick them up for around £70 not sure what that is in euros  but then atleast you have the tool instead of paying somebody to do it  for the same sort of money .
Back to top  Message [Page 6 of 14]
