Gtir Motorsport club » Gallery » Members gti-r's » French Rally Sunny GTiR
Go to page : Previous  1 ... 7 ... 11, 12, 13, 14  Next
Go down  Message [Page 12 of 14]
276 Re: French Rally Sunny GTiR on 21st October 2013, 6:42 pm
fred05
fred05
french connection
french connection
yep, i just ordered it at 38 euros posted so around 30 pounds. fair enough!!
277 Re: French Rally Sunny GTiR on 21st October 2013, 7:04 pm
Very fair, not worth messing around when new that cheap.
278 Re: French Rally Sunny GTiR on 24th October 2013, 12:46 pm
fred05
fred05
french connection
french connection
I'd like to share my hapiness as my R, with many things done on it last 2 months, just passed through the French MOT with nearly all the problems solved (just remains the slight rust mentionned and the rubber cracks around the transmission axle bearings). Rolling Eyes cheers cheers
next steps will be :
- clutch master cylinder changes
- main carpet
- verifying the 4th cyl pressure (to see if the 7bar has moved up!)
- arc dump valve
- TMIC re-cored and samco hoses
- deleting the last alarm cables remaining
- corbeau revolution and willans 4 point 3" harness (i had it on the shelf since i take it off my mini!!)
- 4 points whiteline underbrace
- mountings of the engine and gearbox poly bushes
plenty of work still to do, but all is here in the garage so, enough to do at mid-day!!! Laughing
stay tuned guys!!!
279 Re: French Rally Sunny GTiR on 24th October 2013, 2:18 pm
Glad to hear you passed mate, hopefully you can have some happy motoring and begin to enjoy the car.  Looks like a nice list of modifications you have planned so keep the updates coming
280 Re: French Rally Sunny GTiR on 24th October 2013, 2:24 pm
fred05
fred05
french connection
french connection
thanks bucky!
actually, it's just simple things to do...i'd like to have my car i good overhaul condition first, than mod it a little. i dont expect any beast things, i put things here and there to get it beautiful and looked after.
more important things to do is to maintain it correctly to avoid big troubles...but i'm sure to have some soon (gearbox issue for exemple, and maybe engine), but if it is that, and that all is perfect around, that will be ok!! Very Happy
281 Re: French Rally Sunny GTiR on 24th October 2013, 2:55 pm
Sounds good, I could live with doing an engine build or gearbox but rust & sh1t paintwork would be the love breaker for me. Not keen on resprays either really especially lacquer finished as never lasts well, but engine if crank good etc can easily be built to good spec & last.
282 Re: French Rally Sunny GTiR on 24th October 2013, 3:00 pm
fred05
fred05
french connection
french connection
paintwork will be done, but as i'm not a painter, it will cost me an arm....when i'll get a good rear bumper and good side skirt, i'll be giving the parts to a friend of mine for painting. rest of the shell is in good condition (no rust at all exept little points underneath, and under the front RH wing trim too).
283 Re: French Rally Sunny GTiR on 25th October 2013, 12:44 pm
fred05
fred05
french connection
french connection
updates :
i've received my new IC today, really nice work, weldings are really beautiful!!
and ive received my clutch master cylinder.
so....i've removed the other one!! tight job actually because, on LHD cars, it is behind the left struts tower!!!! that's why i just got the time to drain and remove it than.
284 Re: French Rally Sunny GTiR on 25th October 2013, 2:06 pm
See thats what happens when your car is all backwards Laughing  ......any pics of your new tmic then ?
285 Re: French Rally Sunny GTiR on 25th October 2013, 2:17 pm
fred05
fred05
french connection
french connection
Here some pics!
Mysterious TMIC Laughing
And the clutch master Cyl.
286 Re: French Rally Sunny GTiR on 25th October 2013, 7:48 pm
Who does the intercooler re-core Fred ? ...
Got quite a bit done, hopefully you can have some fun driving it know you got the MOT ...
287 Re: French Rally Sunny GTiR on 26th October 2013, 9:44 pm
fred05
fred05
french connection
french connection
The same guy who did the knight of knee one!
Clutch bleed is ok, but the feeling is not the same as before...
I adjusted the rod as per the old one...may I need to Re set the length now? The return is very close the the ground...(I'm not sure about the translation of this phrase! Ah ah)
288 Re: French Rally Sunny GTiR on 27th October 2013, 9:42 am
@fred05 wrote:The same guy who did the knight of knee one!
Can you supply me a name & number for that !?
289 Re: French Rally Sunny GTiR on 27th October 2013, 6:09 pm
fred05
fred05
french connection
french connection
yep pm'd you
290 Re: French Rally Sunny GTiR on 28th October 2013, 1:38 pm
fred05
fred05
french connection
french connection
Well so todays job is to remove the old bov which be changed by the arc bov i bought from Paul in here, remove the genuine catch can to give it a touch of paint, and to put the new tmic.
I just finished to remove all, and begin to put the bov on.
The good thing of this one is that it can be in recirc position, or not. Ill put it in the recirc position because i've not any bing put blank the pipe...
I noticed some pipes was not so good, aspecially the one on the top of the fpr...and the one with the restrictor inside...here some pics for the moment.
Ill finish that all in the evening.
And the location of the clutch master Cyl on a LHD car...
291 Re: French Rally Sunny GTiR on 28th October 2013, 1:39 pm
fred05
fred05
french connection
french connection
Where does the top fpr pipe goes to exactly?
ok i got the reply, it goes to a 3 way thing down the plenum!
292 Re: French Rally Sunny GTiR on 28th October 2013, 6:12 pm
yes that's correct then it tees off and goes to boost gauge sensor located on inner wing, nothing else should be directly fed from this pipe such as a dv etc
293 Re: French Rally Sunny GTiR on 28th October 2013, 9:23 pm
fred05
fred05
french connection
french connection
Thanks bob! Actually the fpr pipe was in good state on all the length, just the bottom was cracked, so i cut a little pièce of it.
So all is finished, i'm just waiting for a new tmic cover because mine is cracked. I will get it from a friend early in november, with other little parts...
Here some pictures :
294 Re: French Rally Sunny GTiR on 29th October 2013, 1:10 pm
fred05
fred05
french connection
french connection
shitty thing arrived....i destroyed the clutch master cyl thread (where goes the metallic clutch pipe), so it's leaking....i need to change it again...Mad Mad Mad Mad Mad Mad Mad
295 Re: French Rally Sunny GTiR on 29th October 2013, 5:14 pm
lol, on the up side - it will be easier job second time round :-S
296 Re: French Rally Sunny GTiR on 30th October 2013, 1:21 pm
fred05
fred05
french connection
french connection
repaired!!!!
297 Re: French Rally Sunny GTiR on 4th November 2013, 1:18 pm
fred05
fred05
french connection
french connection
Well, today's job was to change tailgate struts i just got from bob today with other bits (walbro, nismo oil cap, poly engine and box mounts and rear whiteline swaybar) Rolling Eyes
i took her to go to work today, and it is so powerful (comparing to my mini lol!!!)
298 Re: French Rally Sunny GTiR on 10th November 2013, 2:25 pm
fred05
fred05
french connection
french connection
Little update, today the snow was calling so i worked in the garage.
Nan was to change the Engine and front box genuine mounts, by one nismo for the Engine and one powerflex for the box.
Engine was quite easy to replace, box is shite!
Engine mount was totally disasemble, replaced by the nismo one is now far better. Better for the gear changing, etc...
Putting the box mount was quite hard.
First of all, you need to remove the battery and the battery tray, and then you have acces to the mount. Undo all and remove the old is not so hard, but the new one....I pass nearly 1 hour and half to bolt 2 screws...I do not reach to put the 2 other on the left side.
You have a little piece of metal to remove from the support if not, you never get to get the new on....
I'll try to put the screws missing on after a little ride.
I'll try to change the timing by the end of the day.
299 Re: French Rally Sunny GTiR on 22nd November 2013, 5:03 pm
fred05
fred05
french connection
french connection
back on the car after riding it a whole week trying to empty the tank to fit the walbro.
now fuel is down, so i can put my hand inside!!!!
so this evening job is putting the walbro, and if i have time, removing the old carpet and put the new one (without any holes!!)
i'm looking for parts to continue the project and upgrade it :
- pillar cover (left side) to fit a gauge (so if you have one already moded i'm in!)
- tool kit
- right hand side of the parcel shelf (the RH flap is broken on mine)
thanks for any proposal
cheers
300 Re: French Rally Sunny GTiR on 22nd November 2013, 11:14 pm
fred05
fred05
french connection
french connection
Well, so 4 hours to change the main carpet...and i remove the remaining parts of the alarm. Electric wires insulated with paper...wow!
Of course i remove all and put spécial tube wich down size with beat. Far better...
Back to top  Message [Page 12 of 14]
