Gtir Motorsport club » Gallery » Members gti-r's » French Rally Sunny GTiR
Go to page : Previous  1 ... 8 ... 12, 13, 14  Next
Go down  Message [Page 13 of 14]
301French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 26th November 2013, 4:47 pm
fred05
fred05
french connection
french connection
Well, i've received my GT2860RS turbo today!!! i would be pleased to run max 330bhp with quick spool.
what do you think about the spec i think about :
- WRC type TMIC (already on)
- GT2860RS disco potato Turbo (bought but not yet on the car)
- 2,5" mongoose exhaust (catback and downpipe) (already on)
- Arc Recirc BOV (already on)
- Bogdan 3" elbow (not yet bought) (i'll think about changing the exhaust if i run it)
- 560cc injectors (not yet bought)
- AFR innovate and wideband sensor and gauge (bought but not yet on the car)
- EGT sensor and gauge
- Jam sport ECU (bought but not yet on the car)
- walbro 255lph
using all between 1.2 and 1.4 bar pressure
not sure using the Jamsport ECU, i'm thinking of buying nistune and tune the ECU myself.
any thoughts?
302French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 26th November 2013, 5:19 pm
GTIR James
Sounds a nice spec that Fred. Your need a z32 afm as well tho.
Should make slightly more power than that with the 2860rs
303French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 26th November 2013, 5:57 pm
yep agreed
z32 maf and go with nistune or other standalone ecu then map it
should see between 350-370 then
304French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 26th November 2013, 6:00 pm
knights of nee
@fred05 wrote:Well, i've received my GT2860RS turbo today!!! i would be pleased to run max 330bhp with quick spool.
any thoughts?
Is that one of my Intercoolers mate ?.
Nice set up by the way should spool very quickly.
Rob
305French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 26th November 2013, 6:16 pm
fred05
fred05
french connection
french connection
@rob, yes didn't you saw my pictures upwards?
ok guys! thanks for the help
what do you think about the 3" elbow and the 3" exhaust?? would that helps to get some bhp up?
what about EGT? can i plug it to nistune or not?
306French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 26th November 2013, 6:39 pm
knights of nee
@fred05 wrote:@rob, yes didn't you saw my pictures upwards?
No I hadn't Fred, I'm really glad more people are following my lead with re coring the top mount let me know how it performs.
The 3" elbow and a 3" down pipe will definitely help with spool up mate, You'd be OK running a 2.5" system though with the power levers you're going for and it would be a tad quieter hopefully.
Rob
307French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 26th November 2013, 6:46 pm
What sort of egt you got is it not just to a gauge ?
308French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 26th November 2013, 6:52 pm
fred05
fred05
french connection
french connection
i don't have any EGT at the moment, i'm just thinking of putting one or not...will it help me to set up the car propperly or not?
309French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 1st December 2013, 7:46 pm
fred05
fred05
french connection
french connection
Well, walbro fitted!
and after a good ride with my mates, my troubles with the reverse gear came back....i really have not any clue of what it really is...i think i will rebuild my gearbox as soon as possible...
my clutch pipe is leaking, and my slace cyl too, so i ordered a braided one and a new slave cylinder....Suspect
310French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 1st December 2013, 9:35 pm
If the slave cylinder is leaking fred move it away from the gearbox you dont want it leaking onto the pressure plate ....
311French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 2nd December 2013, 5:48 am
fred05
fred05
french connection
french connection
Good note nomad! Ill do.
312French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 13th December 2013, 2:21 pm
fred05
fred05
french connection
french connection
updates! not many time these days due to large amount of work
- Apexi EGT gauge and sensor
- A pillar + pod to put the AFR gauge
- upper column cowl to EGTstick the EGT cauge
- 4 560cc injectors (Do you know where to buy new seals?)
- ECU with Nistune board inside
French Rally Sunny GTiR  - Page 13 IMAG2433_zps721a5b8a
I'm waiting for a Z32 MAF with the blitz supa dupa mega magic power filter
As i didn't sold my Hispec kit, i will try to rebuild it...
- cleaning / blasting the bells + anodising
- new screws and nuts everywhere between bells and discs
- skimming on the discs
- cleaning blasting of the caliper brackets + anodising
- complete rebuilt of the calipers with new seals and pins
- new DS2500 or mintex 1144 pads
I began to cut some brackets for my kevlar bucket seat too, but not any time to finish them and bend them....
Well, so some work for Xmas!!!  Laughing
313French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 13th December 2013, 3:33 pm
nice work fred Smile thatll keep you busy
314French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 13th December 2013, 3:42 pm
fred05
fred05
french connection
french connection
yep! thx, but for the moment, i only gather things!
tomorrow it's mini time, i need work on it to bleed the brakes and make it runs!
i hope to work on the GTiR in the evening and sunday
315French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 13th December 2013, 4:16 pm
im in the same boat as you for time being fred ...........gathering and collecting things  Laughing
ive 2 huge boxes of uprated parts already to start on my project next week, oh plus an engine in a thousand pieces that needs re-assembling
bring it on  Cool
316French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 13th December 2013, 4:20 pm
fred05
fred05
french connection
french connection
yep Bob, good time building projects thinking about the pleasure you will have riding the powerful monsters!!! (i'm talking about minis of course  Laughing )
317French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 22nd December 2013, 8:07 am
fred05
fred05
french connection
french connection
I finally put the compmos on...suits really well actually!
French Rally Sunny GTiR  - Page 13 IMAG2435_zpsc40b82dc
French Rally Sunny GTiR  - Page 13 IMAG2436_zps2907d7ff
318French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 22nd December 2013, 8:47 am
Gl3nnGTIR
Gl3nnGTIR
Looks very nice fred Smile
319French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 22nd December 2013, 9:21 am
No, what about the white enkeis (spelt wrong I bet)?
320French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 22nd December 2013, 12:53 pm
fred05
fred05
french connection
french connection
Still in the garage Andy! it will look better with the bumper guard  Laughing,  Ill keep the enkeis for next spring...
Thanks, but still lots of things to work on!
321French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 27th December 2013, 8:20 pm
fred05
fred05
french connection
french connection
Here we go, blitz and z32 maf
French Rally Sunny GTiR  - Page 13 IMAG2462_zps5f7ab552
I stripped it to clean the filter, but after 2 wash in hot water and soap, shit is still stick on the filter, and it is still oily...
Do you have a tip that clean better?
322French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 27th December 2013, 9:04 pm
Something like wd then brake cleaner ? Then i use contact cleaner on z32 wire
323French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 27th December 2013, 9:20 pm
fred05
fred05
french connection
french connection
Don't know if We will help to clean the dirt....do you use that on your filter Johnny?
324French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 27th December 2013, 9:27 pm
I use carb cleaner on my z32 which cleans it then contact cleaner as that evapourates and takes the greasy like residue with it. Whats your filter made of ?
325French Rally Sunny GTiR  - Page 13 Empty Re: French Rally Sunny GTiR on 27th December 2013, 9:34 pm
fred05
fred05
french connection
french connection
It's cotton fabric like k&n filter and i don't have any special spray cleaner for air filtres...
Back to top  Message [Page 13 of 14]
