Gtir Motorsport club » Tech room » Help and Advice » Coolant pipes
Coolant pipes
1 Coolant pipes on 24th August 2013, 2:14 pm
gazgstar
Anyone got pics of the rear of the engine? Got coolant leaking from there after a long run but just cant get in to see anything
2 Re: Coolant pipes on 24th August 2013, 2:17 pm
Inlet manifold off jobby Wink Have fun... Laughing
Had mine off 5 times in the 3 years ive owned it for damn water leaks Mad
3 Re: Coolant pipes on 24th August 2013, 2:31 pm
gazgstar
Bastard Mad. Aha. I was hoping there was a way of just reaching round. May aswell ask how to get the inlet manifold off then because that doesnt look easy without moving the engine forward??
4 Re: Coolant pipes on 24th August 2013, 2:49 pm
If you can find the pipe that's leaking you may be able to reach round & struggle? Bit min was the 1 that goes to OE oil cooler so I had to take it off!
5 Re: Coolant pipes on 24th August 2013, 7:31 pm
you can get to those pipes without removing the inlet manifold providing the dreaded Y brackets not fitted.
youll need to remove the oil filter and the ex downpipe though to get to them so a choice of two evils lol
6 Re: Coolant pipes on 24th August 2013, 9:36 pm
gazgstar
Lol nice 10 minute job then Smile. Yeah that bracket got well and truly binned when the engine was out lol
7 Re: Coolant pipes on 24th August 2013, 10:11 pm
Best place for it aswell ..... if you take the wheel off drivers side where the track rod end comes through the body you can see the pipes .
