Gtir Motorsport club » Tech room » Help and Advice » Exhaust gaskets
Exhaust gaskets
1 Exhaust gaskets on 29th August 2013, 10:12 am
Keensie
Are the mongoose gaskets a different size to standard exhaust?
2 Re: Exhaust gaskets on 29th August 2013, 11:36 am
Wich sections are you on about mate ? If you mean from down pipe back then yes as its larger bore pipe .
3 Re: Exhaust gaskets on 29th August 2013, 12:08 pm
Keensie
The two for the decat as I have a standard elbow that should be ok.
4 Re: Exhaust gaskets on 29th August 2013, 1:37 pm
I think the decats are 2.5 the standard ones may fit but you would have to check the diameter of the bore .
5 Re: Exhaust gaskets on 29th August 2013, 7:35 pm
Keensie
Just measured the decat 2 1/2 inches and the front pipe is smaller to fit the standard elbow.just need to replace the flexi part before fitting.
6 Re: Exhaust gaskets on 29th August 2013, 7:39 pm
A proper mongoose downpipe is still 2.5 mate ....
