Gtir Motorsport club » Tech room » Help and Advice » Fuel preasure?
Fuel preasure?
1 Fuel preasure? on 4th September 2013, 1:56 am
Can someone tell me what the fuel preasure should be on a GTiR? My car is running rich on idle so going to my mates garage tomorrow to check fuel preasure with a gauge to see if that's my problem.
But could do with knowing what preasure it shoud be? Am I right in thinking it 3bar? & is there a certain way to check it once gauge is fitted?
2 Re: Fuel preasure? on 4th September 2013, 7:13 am
Think base fuel pressure is 3bar and raises with boost i.e at 1 bar of boost fuel pressure would be 4bar.
3 Re: Fuel preasure? on 4th September 2013, 7:24 am
I also thought it was 3 bar ..... think there was a discussion on here about it before ....
4 Re: Fuel preasure? on 4th September 2013, 7:30 am
Yeah 3bar according to some of the older threads and 3.7bar if the VAC line is removed, both pressures at idle
5 Re: Fuel preasure? on 4th September 2013, 7:35 am
fred05
french connection
french connection
is putting a fuel regulator the way to go?
6 Re: Fuel preasure? on 4th September 2013, 8:03 am
Not required really Fred unless your going down the route of mental horsepower.
7 Re: Fuel preasure? on 4th September 2013, 9:35 am
yes 3 bar base rising to around 3.7 on boost
stock fpr is fine unless you are running too small injectors and you want to up the pressure to compensate
8 Re: Fuel preasure? on 4th September 2013, 12:32 pm
Cheers guys Smile will let you know the outcome later
9 Re: Fuel preasure? on 4th September 2013, 2:22 pm
Gaz have you got an adjustable fpr then? If so if you adjust it to lean it off on idle, then I think it will run lean across the rev range.
10 Re: Fuel preasure? on 4th September 2013, 2:27 pm
No mate standard FPR, but ive got a direct feed to relay to fuel pump from battery! So if theres to much current then maybe ill have to run it to Ed at fusion as he will have to play with ECU Rolling Eyes
11 Re: Fuel preasure? on 4th September 2013, 2:33 pm
I thought that mod was only to help fuel supply up in the rev range when the pumps working hardest?
12 Re: Fuel preasure? on 4th September 2013, 2:36 pm
Yeh I think it is, but when I had it mapped it was on standard wiring loom & wasn't getting enough power, hence why ive done the direct feed mod! It may not be fuel preasyre that's mt problem, just want to rule it out
13 Re: Fuel preasure? on 4th September 2013, 2:37 pm
Fair enough, good luck with it Very Happy
14 Re: Fuel preasure? on 4th September 2013, 2:44 pm
@pulsarmoley wrote:I thought that mod was only to help fuel supply up in the rev range when the pumps working hardest?
i was under the impression it was to keep the volts going to the pump as the wiring is old in these cars and can lose there effectiveness
15 Re: Fuel preasure? on 4th September 2013, 2:51 pm
Yeah that's what i sort of meant; when the fuel pressure raises when on boost its working the pump harder and the old wiring etc causes a voltage drop.
16 Re: Fuel preasure? on 5th September 2013, 7:48 am
yeah i re-read it a few times and figured thats what you meant, lol my bad
17 Re: Fuel preasure? on 5th September 2013, 7:53 am
Cant always word it how I mean it Rolling Eyes
