Gtir Motorsport club » Tech room » Help and Advice » cleaning injectors
cleaning injectors
1 cleaning injectors on 4th September 2013, 8:01 pm
as title says anyone know of a good{and cheap if possible) place to get some injectors sonically cleaned
2 Re: cleaning injectors on 4th September 2013, 8:17 pm
engine cleaner a sander and ratchet strap a plastic tub check it out on you tube.........
3 Re: cleaning injectors on 4th September 2013, 8:33 pm
I got standard injectors cleaned for about £80 .. Bloke in Southport
4 Re: cleaning injectors on 4th September 2013, 8:44 pm
funnily enough I was gonna make an injectot cleaner myself as ive seen one before at a mate of mines garage that he made up and they work fine plus you can measure the flow rates and spray pattern
5 Re: cleaning injectors on 4th September 2013, 8:48 pm
dont think id want to do the diy you tube method but as ive a few sets i might try,dont think they need cleaning but just to be sure really.dont think id want to pay £80 as one of them is just a standard set so may well try the diy method
6 Re: cleaning injectors on 4th September 2013, 11:16 pm
You can buy ultrasonic cleaners from aldi or lidl for 20-25 quid so no messing about Wink
7 Re: cleaning injectors on 5th September 2013, 1:22 pm
don't suppose you have a link to that do you Leighton?
the injectors still need to be linked to some form of power and fed through a fuel rail in order to clean them properly.
just dropping them in a sonic cleaning bath of sorts is not sufficient other than making them look pretty.
8 Re: cleaning injectors on 5th September 2013, 6:47 pm
http://mobile.maplin.co.uk/module.aspx?moduleno=223108
This one is from maplins at 40 quid ......
9 Re: cleaning injectors on 5th September 2013, 6:51 pm
link not working mr l
10 Re: cleaning injectors on 5th September 2013, 6:56 pm
Thing ones I've found are pricey
http://mobile.maplin.co.uk/search.aspx?criteria=Sonic+cleaners
11 Re: cleaning injectors on 5th September 2013, 6:58 pm
http://www.amazon.co.uk/gp/aw/s/ref=pd_sl_l4v47vn3e_b?rh=i%3Aaps%2Ck%3Aultrasonic+cleaner&keywords=ultrasonic+cleaner&ie=UTF8&hvnetw=g&tag=hydrukspg-21&hvadid=25387972887&hvptwo=&hvpone=&hvpos=1o3&hvrand=181070399944637810&hvdev=m&hvexid=&hvqmt=b
 few more and cheaper  than first link ..... i saw on the you tube vid he hooked the injector  up to a battery charger while it was being cleaned .
12 Re: cleaning injectors on 5th September 2013, 7:01 pm
Think they are more for cleaning the outside rather than cleaning internals
13 Re: cleaning injectors on 5th September 2013, 7:37 pm
Whats the difference surely if the part is say open or like a tube it will clean inside and out regardless ? Lots of reviews on these smaller cheaper cleaners are quite good .
14 Re: cleaning injectors on 6th September 2013, 12:24 pm
Difference is huge, ultrasonics on pro units are multi frequency & powerful enough to make holes in cooing tin foil. also the cleaning solvents are of importance & have seen at least 3 types used in stages of cleaning on real dirty injectors.
Easy enough to make a rig to flow test for matching injector sets & view spray pattern etc but real ultrasonic cleaning requires very good equipment & experience to get good results.
Average price is around £15 per injector.
