Gtir Motorsport club » Gallery » Projects » My grey gtir
My grey gtir
Go down  Message [Page 2 of 4]
26My grey gtir - Page 2 Empty Re: My grey gtir on 12th September 2013, 6:36 pm
I could certainly do with them at the moment, would make working on the floor plan so much easier. Looks a decent bit of kit mate
27My grey gtir - Page 2 Empty Re: My grey gtir on 12th September 2013, 7:09 pm
So how do they work then you jack the car up then slide them into the tubes you have welded ? If so what is the benefit over an axle stand ?
28My grey gtir - Page 2 Empty Re: My grey gtir on 12th September 2013, 8:37 pm
It was a system designed for rally cars so all components underneath the car were easily accessible incase of failure and required replacing during stages and there was a fixed position to support the car rather than having to lose time checking you was in a well supported area.
29My grey gtir - Page 2 Empty Re: My grey gtir on 12th September 2013, 9:59 pm
Greygtir
Hope this clears up some questions. Yes they do come as standard on gtirs. (Nme only)
My grey gtir - Page 2 Null_zps09670e63
My grey gtir - Page 2 Null_zpsf00d1b6b
My grey gtir - Page 2 Null_zpsb952c948
30My grey gtir - Page 2 Empty Re: My grey gtir on 12th September 2013, 10:01 pm
Greygtir
@buckym120 wrote:It was a system designed for rally cars so all components underneath the car were easily accessible incase of failure and required replacing during stages and there was a fixed position to support the car rather than having to lose time checking you was in a well supported area.
Not to mention they are safer. The full stand has its own specific place. Designed exactly for the car.
And yes they would be handy if you are willing to fit them.
31My grey gtir - Page 2 Empty Re: My grey gtir on 12th September 2013, 10:12 pm
But they sit the car way up in the air  so how do you jack it up per axle  or per wheel im just intrested in what stops it from say tipping backwards  with momentum if you jacked the back up then lift the front is there a notch like a woodruff key in the tubing that inserts  into the sill ...... ?
32My grey gtir - Page 2 Empty Re: My grey gtir on 12th September 2013, 10:19 pm
Greygtir
Because unlike an axel stand which is resting somewhere. The stand is in a tube so it acts like a pivot or hinge. The tube in the car is tight so the car wont rock. Im not a wrc expert so my vague explanation of the system is not as good. Teams have used these for decades and still use them today. On top of this they will have to pass fia. Good enough for wrc good enough for me ill ip load a vid in next week or so
33My grey gtir - Page 2 Empty Re: My grey gtir on 12th September 2013, 10:57 pm
Im not knocking it at all  was just gathering an understanding of it .... so do you weld the sleeve  inside the seal or can you mount it on the outside  under the seal but beefed up  ..... i guess bmw have the same system but with a winding jack instead of fixed triangle .
34My grey gtir - Page 2 Empty Re: My grey gtir on 13th September 2013, 5:51 am
Greygtir
My grey gtir - Page 2 A77d25c71cf1dc66cf6bd25edcac1cfe
My grey gtir - Page 2 F6d631c846166e9826aafef4d46bb6ff
The tube is welded in the sill through the sill to the other side. U cant see the front obe in tonys car tho
35My grey gtir - Page 2 Empty Re: My grey gtir on 14th September 2013, 6:41 pm
its a very good idea and as you say much safer than using avle stands and you have good clearance and access to everything too
be interesting to keep updates coming on this project
36My grey gtir - Page 2 Empty Re: My grey gtir on 16th September 2013, 5:04 pm
Greygtir
Nothing much to update bit of bodywork though
My grey gtir - Page 2 Null_zpscfaa1560
Got it down to 5.6kg
37My grey gtir - Page 2 Empty Re: My grey gtir on 16th September 2013, 8:07 pm
fred05
fred05
french connection
french connection
Is it the standard doors cut or some fiberglass ones?
38My grey gtir - Page 2 Empty Re: My grey gtir on 16th September 2013, 8:18 pm
Greygtir
Fibreglass
39My grey gtir - Page 2 Empty Re: My grey gtir on 17th September 2013, 6:11 am
fred05
fred05
french connection
french connection
Twisted Evil
40My grey gtir - Page 2 Empty Re: My grey gtir on 17th September 2013, 6:42 am
Did you make them yourself ..... looks a good job Wink
41My grey gtir - Page 2 Empty Re: My grey gtir on 17th September 2013, 8:21 am
Greygtir
My grey gtir - Page 2 Null_zpsb6fb33f0
All made by me. I worked for a motorsport company and a construction company making full bathrooms out of coposite materials. What i dnt know or cant do with carbon and genral grp isnt worth knowing or doing
These moulds are not mine. I belive scooby clinic made them some time ago. I have made 5 sets for the owner of the moulds one for myself and 2 sets are sat in my garage waiting for me to do some work on them.
I was going to do carbon fibre doors but the way my car is going im loosing the trim on the side of the door so a set of moulds for 1 door is not really feaseable. On the upside im happy with 5kg a door.
42My grey gtir - Page 2 Empty Re: My grey gtir on 26th September 2013, 3:05 pm
Greygtir
Not done alot this week been really busy woth work n stuff.
Got my rad
My grey gtir - Page 2 Null_zps6b3d7d63
My grey gtir - Page 2 Null_zps2c863117
And engine mounts
My grey gtir - Page 2 Null_zps83424f23
All powdercoated Smile
Weekends job is to ginish seam welding the engine bay and all i need is dry sump tank, corsa rack and a few other things and then i will star putting frint end together Smile
A choice of coilovers has to be made next week too so recomndations welcome
43My grey gtir - Page 2 Empty Re: My grey gtir on 26th September 2013, 6:47 pm
loogs good tom, well done fella
bc coilovers take some beating and you can specify your own spring rates at no extra charge.
if you want a set we are agents for bc and you will not beat our prices anywhere so let me know if you want a set
44My grey gtir - Page 2 Empty Re: My grey gtir on 26th September 2013, 6:58 pm
Those doors are awesome. How heavy is a standard door?
45My grey gtir - Page 2 Empty Re: My grey gtir on 26th September 2013, 7:20 pm
Greygtir
Of the top of my head  i think standard doors in full trimg are 36kg. And i have a set of doors tottaly striped that weigh 14 or 15 but it dosent have a bar in it like most i have seen so dunno whats goin on there :/
Yes bob there is a company in germany im looking at too with regards coilovers thing is whats swaying me is ALOT  of time attack cars are running them. And cars that are there to win not just be on the grid
46My grey gtir - Page 2 Empty Re: My grey gtir on 1st October 2013, 8:11 pm
I was going to mention a set of meiste-r's but seeing as youve mentioned time attack spec I guess they are pretty basic compared to what I see at brands over the weekend, with the seperate reservoir per strut
47My grey gtir - Page 2 Empty Re: My grey gtir on 18th October 2013, 8:24 pm
Greygtir
My grey gtir - Page 2 Null_zps6ec73e3a
My grey gtir - Page 2 Null_zpsd11227fc
My grey gtir - Page 2 Null_zpsc21139a1
Gonna start engine work over the winter. Judt bought all my jun head parts. Already have hks adjusable cam gears so all i want is rocker stopers amd some head work and thats head done ready to rebuild
Got the inlet off you a while back bob im sure i hve traced it od a supercharged n turbocharged gtir?
48My grey gtir - Page 2 Empty Re: My grey gtir on 20th October 2013, 9:42 am
GlenR
@Greygtir wrote:Not done alot this week been really busy woth work n stuff.
Got my rad
And engine mounts
high sorry to high jak but where did you get the radiator and fittings from?
49My grey gtir - Page 2 Empty Re: My grey gtir on 20th October 2013, 10:05 am
Greygtir
The rad was buolt for pepper pig thi fitings are an20 altho mazworks does billet fittings at an16 size
50My grey gtir - Page 2 Empty Re: My grey gtir on 20th October 2013, 7:39 pm
the inlet came from a car in the north east we bought tom
guy was never on the forums but car made almost 570hp was a little bit special, no charger though just a big tubby
Back to top  Message [Page 2 of 4]
