Gtir Motorsport club » Tech room » Help and Advice » Hesitation and knocking from brakes
51 Re: Hesitation and knocking from brakes on 29th September 2013, 6:57 am
seems the pressure pipe from the fuel pump is leaking and corroded, basically my fix didnt work for very long so fuel tank getting dropped and pipes fixed
52 Re: Hesitation and knocking from brakes on 29th September 2013, 8:03 am
Good luck with it. Is that a next weekend job?
53 Re: Hesitation and knocking from brakes on 29th September 2013, 4:13 pm
well the garage discovered it when they were fitting the fuel pump so just told him to sort it and get it running properly, only an extra 100 on top of the bill to sort it
54 Re: Hesitation and knocking from brakes on 30th September 2013, 5:16 pm
garage found lots of boost leaks from the intercooler pipes and metal particles too so think this gonna sting a little lol
55 Re: Hesitation and knocking from brakes on 30th September 2013, 5:17 pm
Still, hopefully found before any damage done.
56 Re: Hesitation and knocking from brakes on 30th September 2013, 6:15 pm
yeah hope so, whats the reppecusions of boost leaks? and the particles could it be from the intercooler or the compressor?
57 Re: Hesitation and knocking from brakes on 30th September 2013, 6:39 pm
and where exactly is the restrictor for the 1 bar loop?
58 Re: Hesitation and knocking from brakes on 30th September 2013, 9:00 pm
The restrictor is normally in the rubber pipe between inlet manifold and the metal pipe attached to the top mount. Think it has a green band on the rubber pipe.
59 Re: Hesitation and knocking from brakes on 30th September 2013, 9:04 pm
Yeah it has the green band Wink
60 Re: Hesitation and knocking from brakes on 30th September 2013, 10:29 pm
what if theres a fmic should it still be in the same place, my car was making a solid 1.1bar of boost when i done the loop without the walbro so does that sound right? sorry for all the questions im usually a computer geek Sad
61 Re: Hesitation and knocking from brakes on 30th September 2013, 11:07 pm
Same bit of pipe mate ......why is it not making boost or holding ....or do you not know as it was leaking ?.
62 Re: Hesitation and knocking from brakes on 1st October 2013, 12:37 am
guy done a smoke test or boost leak test and found a few leaks from intercooler pipes and a small leak from dump valve, he asked if the loop should make a bar of boost but he aint road tested it yet
