Gtir Motorsport club » Tech room » Help and Advice » Turbo
Turbo
26 Re: Turbo on 26th September 2013, 8:11 pm
scottyboy
Is this the tool I need?
http://item.mobileweb.ebay.co.uk/viewitem?itemId=310742549515&index=21&nav=WATCHING&nid=33936852598
27 Re: Turbo on 26th September 2013, 8:40 pm
yep that's the kiddy scott
get one of those!
if your a good lad il lend you my bore gauge when your ready to take measurements on cylinder runout.
just pay the postage to you and il lend it to you but will need it back soon as you've finished with it as I use it quite often
28 Re: Turbo on 26th September 2013, 9:56 pm
scottyboy
Good lad cheers mate ill let you know when it's required Smile
29 Re: Turbo on 1st October 2013, 3:56 pm
scottyboy
Right floks that the head off the engine now
Had a look at the bores and there's no marks etc on them the only marks I can see is honing marks not took the piston out yet that's a job for tomorrow should I be worried if there's no scoring on the bore? Cheers Scott
30 Re: Turbo on 1st October 2013, 5:49 pm
No you shouldnt be worried its a good sign that the piston hasnt chuffed your bore up .
31 Re: Turbo on 1st October 2013, 10:22 pm
how did you get on?
examine the ringlands on piston, bet you one of them are cracked between the rings
32 Re: Turbo on 1st October 2013, 10:30 pm
scottyboy
Ill get the piston out tomorrow and let use know:)
33 Re: Turbo on 2nd October 2013, 1:27 pm
scottyboy
Having a bit trouble getting the sump off floks
So far I've taken all the bolts I can see out between the block and sump pan I've taken the lower sump pan cover off and behind the sump pan there another cover I've took that out also and the bolts behind that are all out also hammered a screw driver between the sump and block but its really tight like there's a hidden bolt I've checked over it 3 times for bolts it's tight at the gear box side any ideas? Cheers scott
34 Re: Turbo on 2nd October 2013, 2:12 pm
yep
have you undone the 2x 10mm bolts behind the coverplate?
do not force it or you will end up breaking the rear crank main oilseal housing then its an engine or gearbox out jobby.
once they are undone at the back of the allie sump youll see 2 threaded bolt holes that never had any bolts in.......find a long couple of bolts and thread them into those holes this will then gradually break the gasket sealant away then sump will come free.
DO NOT wedge screwdrivers or the like in there to prize it away or you may well crack it or worse still break the rear main oil seal housing
35 Re: Turbo on 2nd October 2013, 2:26 pm
scottyboy
Cheers mate I just found a write up somewhere else how to do it as we'll lol job for tomorrow now it raining Sad
36 Re: Turbo on 2nd October 2013, 7:46 pm
scottyboy
X1 piston out =fu*ked lol
37 Re: Turbo on 2nd October 2013, 9:33 pm
cracked ringland?
38 Re: Turbo on 3rd October 2013, 12:20 am
scottyboy
Sure is ill drop you a pm tomorrow about the piston mate
39 Re: Turbo on 5th October 2013, 10:33 pm
scottyboy
You think it's worth taken the other 3 pistons out to check them even though they had good compression ?
40 Re: Turbo on 5th October 2013, 10:37 pm
yes seeing as its apart it would be crazy not to
they may have fine cracks so examine them carefully but they may be ok
41 Re: Turbo on 5th October 2013, 10:44 pm
scottyboy
I thought that would be best Smile
42 Re: Turbo on 6th October 2013, 11:32 am
scottyboy
Will I need to rehone the other 3 cylinders or just put the pistons back in?
Is there a certain way the rings have to sit? It's there anything elsie I should be looking for?
43 Re: Turbo on 6th October 2013, 4:58 pm
scottyboy
Bob?
44 Re: Turbo on 6th October 2013, 5:23 pm
If you have not got any scores in the block then you should be ok as each one has bedded in each cylinder so aslong as you know which one went where you should be ok ....im no expert mind ....so you didnt find any more cracked or anything mate .
45 Re: Turbo on 6th October 2013, 5:29 pm
scottyboy
I've not took the other 3 out yet mate wanted to find out first none off my bores are scored:) which is a plus sign but I'd imagine if I was putting a new piston in placed it would need rehoned?
What about rings do they need to sit a certain way as in all the joins in line with each other or one at 12 o'clock one at 6 o'clock type thing?
46 Re: Turbo on 6th October 2013, 5:53 pm
if the other 3 pistons are ok then just put the pistons with rings back into their respective cylinders
the ring gaps should be roughly 120degrees adjacent to each other so none of them line up
if your installing a different piston with rings then you should deglaze / rehone that cylinder before fitting the replacement piston
47 Re: Turbo on 6th October 2013, 5:58 pm
I always thought it never mattered with regards to ring gaps linning up as a ring can spin round in the bore ...but  will often find its own niche so to speak
48 Re: Turbo on 6th October 2013, 6:05 pm
it does matter a lot Leighton because if they line up your gonna have big troubles with loss of compression and blowby.
the rings will move slightly as there is always more wear on the thrust side of piston obviously so they will settle in that position but if there is movement they will all move so the gaps will remain roughly the same
49 Re: Turbo on 6th October 2013, 6:07 pm
scottyboy
Cheers guys one piston is ok hoping to do the other two tonight :)and idea on the torque settings for the end caps?
50 Re: Turbo on 6th October 2013, 6:12 pm
il have to let you know tomorrow as cant remember off top of my head but think its 20nm then 60 degrees but il have to check on that
