Gtir Motorsport club » Tech room » Help and Advice » Help installing manual boost coontroller
1 Help installing manual boost coontroller on 2nd October 2013, 4:20 pm
weblizzer
Hi Everyone!
I would like to ask regarding on installing a manual boost controller for gtir . As I'm not sure if I done it correctly if not. please do guide me Smile
I use a universal manual boost but not sure if this is the right thing?
Thanks
2 Re: Help installing manual boost coontroller on 2nd October 2013, 5:12 pm
Looks like you have done it right .....although i hear manual boost controller like the style you have can be troublesome as its not as reliable as say like a dawes device .
3 Re: Help installing manual boost coontroller on 2nd October 2013, 5:33 pm
no as you still have a 1 bar loop with the pipe from the oe boost solenoid bleeding off boost back into the intake. you need to blank that intake end off (both sides)
4 Re: Help installing manual boost coontroller on 2nd October 2013, 5:38 pm
weblizzer
Thanks for your replies!
I just got this temporary till i get a electronic boost controller. Currently i only have .5 so just try to race up to .7 or .8 at least.
The hose from intake is now ordinary hose. not the one with restrictor. So hopefully this would work. just making sure if i had it plumb correctly Smile.
5 Re: Help installing manual boost coontroller on 2nd October 2013, 6:30 pm
Doh i didnt see that Embarassed
6 Re: Help installing manual boost coontroller on 2nd October 2013, 6:41 pm
Scooby_killer
Sorry mate not hijacking your topic or some thing but my manual boost controller is set up the same way as the above pic aswell is mine plumed in wrong which intake pipes need blocking off.
7 Re: Help installing manual boost coontroller on 2nd October 2013, 6:50 pm
yes the smaller vacuum/boost hose that's teed in to actuator is bleeding off back into intake needs to be blanked off as the bleed valve bleeds off boost so that setup is wrong
8 Re: Help installing manual boost coontroller on 2nd October 2013, 8:47 pm
Scooby_killer
Ah I get you so it goes from the plenum to the manual boost controller from the controller straight to acutator and the intake pipe gets blocked off will get mine sorted out tomorrow now thanks bob
9 Re: Help installing manual boost coontroller on 2nd October 2013, 8:53 pm
Thats it ....... pretty straight forward  same as i have my soleniod for my blitz .
10 Re: Help installing manual boost coontroller on 2nd October 2013, 9:35 pm
coreeecccct Smile
11 Re: Help installing manual boost coontroller on 2nd October 2013, 10:28 pm
jaypjay
Be careful buying very cheap boost controllers. I has one like these off ebay for 15 bucks and quickly swapped it out for a turbo smart.
12 Re: Help installing manual boost coontroller on 3rd October 2013, 2:11 pm
knights of nee
That boost control valve in the picture is shit, I tried one on my Saab C900 Turbo and it spiked all over the place, A £19 dawes device is much better doesn't spike just fit and forget.
Maybe not shiny and bling but it works great.
http://www.ebay.co.uk/itm/Universal-Manual-Boost-Controller-MBC-Turbo-Grainger-Valve-Dawes-Device-PRV-/190918805473?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c73a5c7e1
Rob
13 Re: Help installing manual boost coontroller on 3rd October 2013, 2:34 pm
that is very true dawes device is much more stable
14 Re: Help installing manual boost coontroller on 3rd October 2013, 8:55 pm
if you only have 0.5 of boost then it sounds like your car is in safemode or maybe another problem?
15 Re: Help installing manual boost coontroller on 3rd October 2013, 9:59 pm
no it will only run .5 without the restrictor pipe in, its basically actuator spring pressure
16 Re: Help installing manual boost coontroller on 3rd October 2013, 10:07 pm
ah ok got it now
17 Re: Help installing manual boost coontroller on 6th October 2013, 8:33 am
weblizzer
After installing the boost I got increase up to 1bar, one thing i'm concern is would it be safe on stock injectors and stock ecu. for now i'm trying to reduce just aiming around .7 bar Smile.
18 Re: Help installing manual boost coontroller on 6th October 2013, 8:56 am
weblizzer
@GTI-R US wrote:yes the smaller vacuum/boost hose that's teed in to actuator is bleeding off back into intake needs to be blanked off as the bleed valve bleeds off boost so that setup is wrong
are you referring to this?
19 Re: Help installing manual boost coontroller on 6th October 2013, 10:32 am
@weblizzer wrote:After installing the boost I got increase up to 1bar, one thing i'm concern is would it be safe on stock injectors and stock ecu. for now i'm trying to reduce just aiming around .7 bar Smile.
safe on 1 bar just watch your clutch if it aint uprated and get your fueling checked
20 Re: Help installing manual boost coontroller on 6th October 2013, 12:58 pm
@GTI-R US wrote:no it will only run .5 without the restrictor pipe in, its basically actuator spring pressure
Do you still need the restrictor if running a AVCR? Not checked mine?
21 Re: Help installing manual boost coontroller on 6th October 2013, 3:22 pm
Yes thats the pipe you block off both ends  just block the intake side and remove the other end altogether either remove  the why section and just use a straight coupler or get a longer piece of pipe .....
22 Re: Help installing manual boost coontroller on 6th October 2013, 6:32 pm
no not needed gaz
23 Re: Help installing manual boost coontroller on 6th October 2013, 9:56 pm
sweet Smile
24 Re: Help installing manual boost coontroller on 8th October 2013, 7:37 pm
weblizzer
So I change the plumb for manual boost..
so i remove the t Piece which is going to intake tube go straight directly to the valve bleed. I know this is not a good manual boost but atleast i know where to update soon after i create a daves manual boost controller or get a electronic boost controller..
25 Re: Help installing manual boost coontroller on 8th October 2013, 8:09 pm
Dont nick daves boost controller he might get rather angry Laughing  have you got a aftermarket boost gauge ...if not i would strongly reccomend getting one with messing around with boost levels .
