Gtir Motorsport club » Tech room » Help and Advice » Help installing manual boost coontroller
26 Re: Help installing manual boost coontroller on 8th October 2013, 9:34 pm
yep that's right. you need to block the hole on intake because it will pull in unmetered air on the wrong side of afm so will mess with your afr's
and as said I take it you are running a gauge to monitor over factory boost settings
27 Re: Help installing manual boost coontroller on 9th October 2013, 2:02 pm
weblizzer
Thank you so much for your replies. Yes, I do have a greedy boost guage which i plumb dedicate from the quad throttle.. I just made a test run and it turns back to .5 boost so I'll try to adjust on it.
