Gtir Motorsport club » Tech room » Ecu related section » Bin for base tune
Bin for base tune
1Bin for base tune Empty Bin for base tune on 6th October 2013, 7:31 pm
weblizzer
Hello everyone!
Had anyone had a good base tune for gtir I can use at? like i'm planning to use for chip ecu?
2Bin for base tune Empty Re: Bin for base tune on 6th October 2013, 8:15 pm
Can you eleborate a little .... are you after just a basic running map with no mods  that you want to flash on to your ecu ?
3Bin for base tune Empty Re: Bin for base tune on 7th October 2013, 7:17 pm
weblizzer
I have a chip programmable ecu.. it has daughterboard so I was wondering I can use a base map for my gtir with much better fuel and timing map, where I can start off?
4Bin for base tune Empty Re: Bin for base tune on 7th October 2013, 8:33 pm
Any clues to what daughterboard it is ..... is it seconhand ...preloaded with a map ?
5Bin for base tune Empty Re: Bin for base tune on 8th October 2013, 6:59 am
fred05
fred05
french connection
french connection
daughter board is like nistune ECU, piggy back ECU, a little card plug in the genuine ECU box....
many ECU are with daughter board inside, but are not programmable....Nistune is, Mines not for exemple...
6Bin for base tune Empty Re: Bin for base tune on 11th October 2013, 6:50 pm
weblizzer
thanks for input fred. like mine i do have a basic chip ecu. more like Calum ecu but mine is on nismotronic b13 chipped. as it's quite cheap.
