Gtir Motorsport club » Tech room » Ecu related section » Standard Pulsar vs Sunny ECUs
51Standard Pulsar vs Sunny ECUs - Page 3 Empty Re: Standard Pulsar vs Sunny ECUs on 22nd January 2014, 8:41 pm
I have pops & bangs mapped into my Nistune ecu... Basicly I rang Ed at fusion & asked him if it was possible & he told me to send him my ECU & he would see what he could do!
Anyway he said he retarded the timing on over run which Dave has explained above, & added a little more fuel on over run.
How much he retarded the timing on over run by I don't know... But basicly it only works if I rest my foot a little on the accelerator or I gently repetedly tap the accelerator... so it just starts to open butterflys in the inlet.
So if the throttle is fully closed it wont do it? Maybe a good thing in residential areas tho Very Happy
Heres a little video of mine on the motorway popping & banging, put headphones in & turn volume up Wink Not best quality tho & camera man dous decide to turn the camera the right way up half way threw  Laughing
https://youtu.be/wa8ILhLaF5o
52Standard Pulsar vs Sunny ECUs - Page 3 Empty Re: Standard Pulsar vs Sunny ECUs on 22nd January 2014, 9:40 pm
fred05
fred05
french connection
french connection
@watoga wrote:
@fred05 wrote:Ah Ah, will do that!!! so fuuuuuun!!!! lol
Also note that this will provide pretty big flames out the back too............. Just be careful though, you don't want to cook your car  Very Happy
Dave
 Or cook a cat!
53Standard Pulsar vs Sunny ECUs - Page 3 Empty Re: Standard Pulsar vs Sunny ECUs on 29th January 2014, 5:36 pm
weblizzer
Hi Dave,
Just a question, since I'm only using a tunerpro how will i able to achieve this?.. as i see on the grid. I need to change those 50 value to 20?
Hope you can help. Smile
54Standard Pulsar vs Sunny ECUs - Page 3 Empty Re: Standard Pulsar vs Sunny ECUs on 30th January 2014, 7:25 am
watoga
watoga
ecu technician
ecu technician
@weblizzer wrote:Just a question, since I'm only using a tunerpro how will i able to achieve this?.. as i see on the grid. I need to change those 50 value to 20?
No matter what software you are using, the raw values will be identical since they're read directly from the ECU. As I mentioned in my post above, I have never modified the values before on my own GTiR so I can't say exactly what will work or not work on your car. If you decide to try this I would be *VERY* careful as retarding the timing more-and-more will heat your exhaust manifold to higher temperatures (but only on an in-gear deceleration with no throttle as otherwise this timing table will be ignored). Just adjust things slowly if you want to try it out.
Let us know how you get on  Cool
Cheers,
Dave
