Gtir Motorsport club » Tech room » Ecu related section » Ecu question
Ecu question
1Ecu question Empty Ecu question on 13th October 2013, 1:58 pm
Just had a ecu off bob and im thinking about taking it all the way down to edd as you lot seem to say he's about the best unless someone knows one nearer me in the midlands( nottinghamshire)?  Had a look at his web site and have i got it right , its £200 for the rollers and then £75 per hour???
2Ecu question Empty Re: Ecu question on 13th October 2013, 2:01 pm
There is also street racers in liectershire, who is very good but unsure on what ecu's he can map?
3Ecu question Empty Re: Ecu question on 13th October 2013, 2:06 pm
GTIR James
Thought it was £150 for the remap on a nistune & £200 on other ecu plus dyno cost
4Ecu question Empty Re: Ecu question on 13th October 2013, 2:17 pm
Dont know what my ecu is yet, bob might know but im still away on holiday so if need be i will open it when i get home
5Ecu question Empty Re: Ecu question on 13th October 2013, 2:27 pm
Wondering about fittiing a wideband and setting to 1.2 bar and seeing how its running. I do have a afr which i can adjust through the rev range if needed. What do you lot think??
6Ecu question Empty Re: Ecu question on 13th October 2013, 2:35 pm
Don't wonder about fitting a wideband... DO IT lol its the best thing you can fit to save your engine & also fault finding etc
7Ecu question Empty Re: Ecu question on 13th October 2013, 2:47 pm
How can u tell if yr engine is detting, ? Does it go into limp mode or is there a warning light? I know there is a det sensor cos ive seen new ones for sale
8Ecu question Empty Re: Ecu question on 13th October 2013, 6:32 pm
im sure that ecu I sent you Darren is a generically chipped ecu (similar to mines) these are non mappable.
most people run 1.2 bar boost from them, some have run 1.4bar with no problems.
if you do not have a wideband fitted then I would strongly advise getting and fitting one because as said above its one of the best diagnostic bits of kit you could ever buy and there not expensive at around £150
if not then just take the car to a rolling road and ask them to set the boost controller up for you and to monitor afr's etc when they do the run.
any half descent rr will be able to do this and it should cost you no more than £120 in total and that will include a dyno print out with your power, torque and afr graph
9Ecu question Empty Re: Ecu question on 14th October 2013, 12:09 pm
Im getting confused lol, so whats the differance between these and a standard ecu? If i turned my boost up to 1.2 on a standard ecu then had the fueling altered to suit would that not be the dame or are you not able to alter the fueling without one of these ecu's. i will be fitting wideband before evu and i can adjust fueling on apexi afr.
10Ecu question Empty Re: Ecu question on 14th October 2013, 12:31 pm
watoga
watoga
ecu technician
ecu technician
Darren hawkins wrote:Im getting confused lol, so whats the differance between these and a standard ecu? If i turned my boost up to 1.2 on a standard ecu then had the fueling altered to suit would that not be the dame or are you not able to alter the fueling without one of these ecu's. i will be fitting wideband before evu and i can adjust fueling on apexi afr.
Darren,
A standard ECU cannot be modified. On standard ECUs, there are pre-defined fuelling and ignition maps, as well as additional fuelling and ignition maps which are used in the event that the engine detects knock. These maps are burned into the ECU chips and cannot be altered, even with fancy software. You'll also see (if you check the comparison I put up recently) that these maps are far from ideal. Because they supply a large amount of fuel as standard, you can normally get away with a boost hike without running into difficulties. For example, I ran 1 bar of boost on my standard Pulsar ECU for 3 years without complaints. I also ran 1.2 bar on my standard Sunny ECU with no problems. However, some other tuners (such as Mines) place a daughterboard inside the standard ECU which allows the car to run off the Mines maps instead of the standard ones. These have been altered in some way (perhaps fuelling, timing, load tables, etc.), but are again completely locked preventing more modification. Other daughterboards, from companies such as NIStune, are completely open and can therefore be updated as many times as you like.
Getting a wideband A/F gauge is an absolute *MUST* in my opinion. You will be able to see exactly where your maps need adjusting, and will also get some warning should you begin to lean out as a result of running too much boost.
Hope this helps,
Dave
11Ecu question Empty Re: Ecu question on 14th October 2013, 12:35 pm
Thanks Jedi bob thats made everything much clearer. Hopefully that info will also help lots of others understand ecu's a bit better
12Ecu question Empty Re: Ecu question on 14th October 2013, 4:28 pm
Mate, thats Dave not Bob.
13Ecu question Empty Re: Ecu question on 14th October 2013, 4:39 pm
yep dave not me
you may call him davevader if you wish Laughing
14Ecu question Empty Re: Ecu question on 14th October 2013, 6:03 pm
Dave vader Razz
15Ecu question Empty Re: Ecu question on 14th October 2013, 7:00 pm
@nomad wrote:Dave vader Razz
Dave Vader, runs the Death Star Laughing
16Ecu question Empty Re: Ecu question on 14th October 2013, 7:31 pm
watoga
watoga
ecu technician
ecu technician
LOL Laughing You guys are nuts Surprised In fairness I've been called much worse, so Dave Vader it is LOL
Darren, glad that cleared things up for you Cool
Back to my Death Star...............
Dave
17Ecu question Empty Re: Ecu question on 14th October 2013, 7:51 pm
Check this out, will make sense near the end Wink
http://m.youtube.com/watch?v=Sv5iEK-IEzw
18Ecu question Empty Re: Ecu question on 14th October 2013, 8:10 pm
watoga
watoga
ecu technician
ecu technician
@pulsarmoley wrote:Check this out, will make sense near the end Wink
Death by ECU it shall be.............. Very Happy
19Ecu question Empty Re: Ecu question on 14th October 2013, 8:11 pm
Nice one Very Happy
20Ecu question Empty Re: Ecu question on 14th October 2013, 8:29 pm
Is that a name change i hear you say dave Wink
21Ecu question Empty Re: Ecu question on 15th October 2013, 10:50 am
Better than davebender lol
22Ecu question Empty Re: Ecu question on 15th October 2013, 10:51 am
watoga
watoga
ecu technician
ecu technician
Darren hawkins wrote:Better than davebender lol
LOL, absolutely! At least by being Dave Vader I get to polish my helmet all day...................................
I can sense this topic is entering a downward spiral LOL
Dave
23Ecu question Empty Re: Ecu question on 15th October 2013, 12:12 pm
Ecu question Davevader
24Ecu question Empty Re: Ecu question on 15th October 2013, 12:13 pm
Looks quite catchy dont you think Wink
25Ecu question Empty Re: Ecu question on 15th October 2013, 12:21 pm
watoga
watoga
ecu technician
ecu technician
@nomad wrote:Looks quite catchy dont you think Wink
You are awesome LOL! Just sorted out my new profile pic too cheers
Cheers,
Dave (Vader)
