Gtir Motorsport club » Tech room » Help and Advice » Nissan Sunny GTI-R upgrades and compatibility
1 Nissan Sunny GTI-R upgrades and compatibility on 21st October 2013, 10:48 am
Morksky
My nissan sunny GTI-R 1993
Current specs:
- FMIC
- 3" exhaust from turbo
- Electromotive engine management
- Electromotive coilpack with moroso ignition leads
- HKS iridium spark plugs
- Turbsosmart boost tee
- Adjustable dumpvalve
- Walbro fuelpump 255 l/h
- Innovate LC-1 wideband controller
- Open airfilter K&N
- Triggerwheel kit
Shopping list:
http://www.nengun.com/engine/
http://www.deatschwerks.com/
Tomei - Nissan  SR20DET - Adjustable cam pulley, Intake or Exhaust 13024R310
Tomei - Nissan  PS13/RNN14 - Procam Solid Type Intake - 260 Duration - 12mm Lift 1435260120
Tomei - Nissan  RNN14 - Procam Solid Type Exhaust - 260 Duration - 12mm Lift 43K260120
Tomei - Nissan SR20DET-RNN14 Head gasket, Bore 88mm, Thickness 1.2mm 11044R302G
Tomei - Nissan Pulser RNN14 SR20DET Valve spring (Doulble Spring) 13203R301
Deatschwerks - 550cc injectors
Does these upgrades require big modifications? or is it more or less bolt on?
What about the compatibility with these parts?
Is it top feed injectors on the Sunny GTI-R or side feed?
Any other upgrade recommendations? What turbo to choose in a +/- 350bhp setup?
2 Re: Nissan Sunny GTI-R upgrades and compatibility on 21st October 2013, 11:15 am
Electrocompotive engine management
never heard of one so know nothing about them but assume you have someone to map it? as it will obviously need mapping.
injectors are topfeed
and if i were you i would use a cosworth mls head gasket
hks plugs are just rebranded denso iridiums but double the price so wouldn't bother with those
3 Re: Nissan Sunny GTI-R upgrades and compatibility on 21st October 2013, 11:38 am
Morksky
Thanx for the response
Embarassed Electrocompotive = electromotive, i was far far away when i wrote it.
Just bought the car, it hasn`t been mapped after installation of the eletronic fuel injection system, but i will ofcourse do this as soon as possible Smile
The HKS plugs were already installed.
Regarding the injectors, should i just go for a bigger type like 700cc or is 550cc big enough for these specs?
4 Re: Nissan Sunny GTI-R upgrades and compatibility on 21st October 2013, 12:01 pm
ah right i see
ok assuming your only looking for 350-360bhp (dependant upon turbo your running) youll only need 550-560cc injectors they will cope easily at that power level.
don't know whether you want new or secondhand but i have a good s/h set in stock, if needed just drop me a pm
watoga
ecu technician
ecu technician
@Morksky wrote:Any other upgrade recommendations? What turbo to choose in a +/- 350bhp setup?
If you are 100% sure that 350 BHP is your upper limit (and you'll not be tempted to venture further up the scale), then as Bob says, 550-560cc injectors will work just fine and keep your injector pulsewidths manageable. You can source 550-560cc injectors off a secondhand Mitsubishi Evo if you want a cheap alternative to big name brands. Just please note that:
Evo MDL510 injectors have a yellow connector and are single jet items (DO NOT USE THESE!)
Evo MDL560CC injectors have a maroon/brown connector and are dual jet items (YES USE THESE!)
So when sourcing Evo injectors, make sure they are the top-fed ones with maroon/brown connectors. Also, if you venture much higher than 350 BHP you'll soon run into the ceiling of the standard MAF. Most people opt to replace the OE MAF with one from a Z32 (i.e. a twin-turbo 300ZX). These MAFs are good for around 500 BHP, but a cheaper alternative would be the Q45 MAFs which you can pick up relatively cheaply. They can't handle as much air flow as the Z32s, but will happily handle 350-400 BHP.
Note that when you change the injectors and/or MAF, you will also need to adjust the 'k' constant within your ECU's fueling tables to make sure everything works in harmony.
Cheers,
Dave
Scooby_killer
Some great info there Dave am not hijacking this threat or any thing but one question about the maf's are the 300zx twin turbo and 300zx N/A maf's the same or different
watoga
ecu technician
ecu technician
@Scooby_killer wrote:Some great info there Dave am not hijacking this threat or any thing but one question about the maf's are the 300zx twin turbo and 300zx N/A maf's the same or different
I'm not 100% sure, but I think all Z32 300zx's (twin turbos, N/A's, and automatics) use the same MAF, specifically an N62 MAF. Some earlier models (and Nissan Maximas) seem to use the N60 MAF which has an upper limit of around 350-400 BHP, rather than the 500 BHP normally associated with the N62 model. I think some sellers, particularly on eBay try to fob off N60 MAFs as "300zx MAFs" to try and get people to buy them assuming they'll be the Z32 (i.e. N62) MAFs, while they'll most likely be the earlier N60 models. Just be careful when ordering one and make sure it's the N62 model.
Cheers,
Dave
and not a fake one as their ccccrap lol
ive got injectors and q45 if needed
Morksky
Thanx for some useful info here Dave Smile
GTI-R US: i have already ordered the deatschwerks 550cc injectors, but im very much interested in the Q45 MAF.
10 Re: Nissan Sunny GTI-R upgrades and compatibility on 21st October 2013, 8:16 pm
Morksky
What do you think about the rest of the shopping list? Procams? Any experiences? Should i also upgrade the throttle body? ?
11 Re: Nissan Sunny GTI-R upgrades and compatibility on 21st October 2013, 8:28 pm
watoga
ecu technician
ecu technician
For BHP around the 350 mark, most people swear by the HKS 264 cams. They are reasonably common (perhaps Bob might even have a set?) so you can normally pick up a set cheaper than you'll find the Tomei ones.
Again, for 350 BHP I wouldn't bother touching the throttle bodies. The quad throttle bodies are quite good in OE form, and I can't imagine 350 BHP will bother them.
Cheers,
Dave
12 Re: Nissan Sunny GTI-R upgrades and compatibility on 21st October 2013, 8:35 pm
Morksky
Ok, again much appriciated info Smile any cheap retailers in the UK to recommend?
13 Re: Nissan Sunny GTI-R upgrades and compatibility on 21st October 2013, 10:45 pm
Bob (gtirus) is pretty much the no1 breaker for pulsars  ..... and you can always have a look in are useful links section ....as these are links for various parts that we have come across and used etc .
14 Re: Nissan Sunny GTI-R upgrades and compatibility on 23rd October 2013, 3:18 am
Morksky
Talked with customer service on Deatscwerks, they recommended 800cc injectors for a 350-400hp setup, instead of the 500cc i ordered.
But im not there yet, maybe i got around 300hp now, are 800cc to big then, and how does installing to big injectors effect the performance?
15 Re: Nissan Sunny GTI-R upgrades and compatibility on 23rd October 2013, 6:00 am
watoga
ecu technician
ecu technician
@Morksky wrote:Talked with customer service on Deatscwerks, they recommended 800cc injectors for a 350-400hp setup, instead of the 500cc i ordered.
I suppose they are saying this to allow for a little overhead - better to have larger injectors running at 50% duty compared to smaller injectors running flat-out. The standard 444cc injectors can normally flow enough fuel for 330-350 BHP before the pulsewidths (and duty cycles) become too large. In reality, you could change the standard injectors for 1200cc items, so long as you told the ECU you had done so (i.e. by changing the 'k' constant and scaling some of the enrichment tables). You basically need injectors which can flow enough fuel for your BHP goals. If you are below those goals, then the same injectors will have an easier time since they will only be flowing a fraction of their upper limit.
Cheers,
Dave
16 Re: Nissan Sunny GTI-R upgrades and compatibility on 23rd October 2013, 6:23 am
Morksky
Thanx, this clearify things alot for a newb like me Smile Then i will go for the 800cc without a doubt, and install them before the mapping.
17 Re: Nissan Sunny GTI-R upgrades and compatibility on 23rd October 2013, 5:48 pm
Morksky
What thicknes and diameter to choose on a cosworth headgasket?
18 Re: Nissan Sunny GTI-R upgrades and compatibility on 23rd October 2013, 9:43 pm
all depends on compression ratio you want to run with and what boost your planning on running at.
also if the block is decked and head skimmed will all be relative factors in determining hg thickness.
19 Re: Nissan Sunny GTI-R upgrades and compatibility on 24th October 2013, 3:01 am
Morksky
Ok, in this case its a original block, running on some higher boost and guess the compression ratio is original spec.
20 Re: Nissan Sunny GTI-R upgrades and compatibility on 24th October 2013, 8:53 am
well if your going to fit an mls head gasket I would at least get the head skimmed as surfaces need to be 100% straight and flat.
so baring that info in mind I would go for a 1.5mm thickness if your running a 2860-2871r sized turbo at high boost
21 Re: Nissan Sunny GTI-R upgrades and compatibility on 24th October 2013, 8:59 am
Morksky
Thanx, 1.5mm ordered from sumopower Smile
22 Re: Nissan Sunny GTI-R upgrades and compatibility on 21st November 2013, 9:35 am
fred05
french connection
french connection
Morsky, how did you route your wideband innovate LC1 cable? i have one i need to put on...
23 Re: Nissan Sunny GTI-R upgrades and compatibility on 27th November 2013, 12:02 am
Morksky
@fred05 wrote:Morsky, how did you route your wideband innovate LC1 cable? i have one i need to put on...
Hi Fred, the LC1 cable is routed through the firewall on the passenger side, the com cable i got in the glovebox and the
instrument is mounted beside the boost gauge in the center console.
Im currently offshore, but i can send you some pictures when i get back home Smile
24 Re: Nissan Sunny GTI-R upgrades and compatibility on 27th November 2013, 12:11 am
gtirx2
Just to add if you get the head skimmed you want to mention it to the shop that you are using a mls gasket, as in most cases the ra (roughness average) needs to be a lot smoother.
Most times you will get away with it depending how rough it is, but a mls gasket is not as forgiving to surface finish as a stock type gasket.
25 Re: Nissan Sunny GTI-R upgrades and compatibility on 27th November 2013, 12:14 am
Morksky
@gtirx2 wrote:Just to add if you get the head skimmed you want to mention it to the shop that you are using a mls gasket, as in most cases the ra (roughness average) needs to be a lot smoother.
Thanks for the advice Smile
