Gtir Motorsport club » General Discusion » Gtir related Discussion » boost pressure 1 bar mod
1boost pressure 1 bar mod Empty boost pressure 1 bar mod on 26th October 2013, 9:12 am
pulsarmad20
pulsarmad20
Hi all
I would like to know how todo it as i havent got the restricter and have silicon hoses ?? i did find somewhere i can use a mig welder tip and put in the line but wat size?
any help appriciated
thanks
sam
2boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 10:01 am
try a 1.2mm tip thatll put you just fractionally over a bar
3boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 11:49 am
pulsarmad20
pulsarmad20
ok thanks bob will go buy one thiss afternoon thanks
sam
4boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 4:07 pm
You can still get the restrictor from nissan .... there is also a picture in the how to section under useful diagrams ..if that helps Wink
5boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 7:52 pm
my local nissan said yes to supplying restrictor pipe untill they went to order it and could not get it. If anyone else knows different let me know please as i want one
6boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 8:11 pm
You got the part number for that johnny ?
7boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 8:30 pm
Err pass did have a few month ago give me 5 mins
8boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 8:42 pm
22320-54c00
9boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 8:46 pm
Thanks matey ...
10boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 26th October 2013, 9:11 pm
http://www.online-parts.co.uk/nissan/shopping_cart.php#.Umwr56O3Mb0
11boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 27th October 2013, 8:54 am
pulsarmad20
pulsarmad20
just realised that as i didnt have a restrictor pipe that i have only been running 0.5 of boost for the last year is that right ? and i thought that was quick lol coudnt get a 1.2mm tip had to get a 1mm and i have 0.8 of boost Smile big difference from before
12boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 27th October 2013, 9:37 am
Just drill it out a bit bigger ...
13boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 27th October 2013, 10:46 am
yep as above its only copper so easy to drill
14boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 27th October 2013, 11:11 am
pulsarmad20
pulsarmad20
im going to leave it like that as i dont wont to blow it up lol and 0.8 is alot quicker than before for me i know its nothing compared to what some of you are running but i like it and as its my only car i cant afford any more repairs this year!!!
15boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 27th October 2013, 11:05 pm
Whytie
Whytie
Just buy a dewes device, they are cheap and work as they should
16boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 28th October 2013, 9:29 am
fred05
fred05
french connection
french connection
i don't understand, what is this restrictor pipe exactly?? scratch
17boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 28th October 2013, 10:38 am
its a lengh of pipe from the out take pipe of the plenum around 6'' long with either a green or mauve band round it. if you look inside the pipe you will see a plastic restrictor where the printed band is
18boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 28th October 2013, 10:45 am
fred05
fred05
french connection
french connection
aaaahhh ok! and the restrictor means higher or lower boost pressure regarding the size of the hole?
19boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 28th October 2013, 10:48 am
yep that's correct
was an old trick years ago to run higher boost by fitting a mig welding tip in vacuum pipe to actuator which obviously works on -&+ pressure
20boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 28th October 2013, 2:55 pm
fred05
fred05
french connection
french connection
ok, so if i understand well, the little is the hole of the plastic part in the pipe, the bigger is the pressure?
do you have a chart or somthing with the hole size vs. pressure given?
21boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 30th October 2013, 10:00 pm
@nomad wrote:http://www.online-parts.co.uk/nissan/shopping_cart.php#.Umwr56O3Mb0
Few days later mate
Unfortunately Nissan UK have informed us that this part number is no longer available. We can check for an alternative but would need the VIN/ChASSIS number.
22boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 30th October 2013, 10:37 pm
I think its the same as another nissan motor when i was checking ....
23boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 5th March 2018, 11:05 pm
venom42
venom42
Sorry to resurrect an old thread (seems that I what I have done every time I have posted?)... Based on the info here, I purchased a 1mm MIG tip to replace the missing restrictor on my car (it was running .5 bar when I got it). I am getting at least 1 bar with it (I back out of it before it gets there because I do not want to blow it up). .8 bar (or around that) is what I am comfortable running, as this is my daily driver and I do not want to modify the car more to run higher boost. There seems to be conflicting info on different threads here in the forums as to the appropriate size tip to use. Am I correct in understanding that the larger the hole diameter, the less boost you will run? Do I have that backward? Some of the other threads seem to indicate the opposite (a larger tip will lead to more boost). The only size that my local hardware store has in stock is the .8mm, so I need to order whatever size I need, assuming the 1mm tip I have in there now is the issue, and not something else (I have been thinking it was a failing boost control solenoid). Should I look for a 1.4mm tip, since some of the other posts seem to indicate that the 1.2mm yields just over 1 bar, or is it the .8mm tip that I want?
I am very close to just saying F it and going with an aftermarket controller set to 12psi (I like the innovate one with the integrated wide-band). I just really wanted to try and keep it mostly stock if possible.
24boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 6th March 2018, 3:29 am
venom42
venom42
After doing more research, it appears the stock restrictor is 1.7mm. 1.2 yields a little over 1 bar, so I'm hoping 1.4 will be about .8 bar.
25boost pressure 1 bar mod Empty Re: boost pressure 1 bar mod on 6th March 2018, 8:51 am
I'm not sure on the prices of welder tips but, they can't be much more or less than the cost of a dawes device. I've got one on my R and it performs faultlessly regardless of what boost you want.
At least then you could set the boost to whatever you want very easily...
one of these:
https://www.ebay.co.uk/itm/TURBO-MANUAL-BOOST-CONTROLLER-BALL-AND-SPRING-VALVE/220537042109?hash=item33590834bd:g:CYkAAMXQDnpTYh-Q
