Gtir Motorsport club » Tech room » Help and Advice » z32 pipe run
z32 pipe run
1 z32 pipe run on 27th October 2013, 6:21 pm
Hi folks
went to group b motorsport in deeside which is only 35 min away from me they were helpful.
to cut a long story short i need to put my air flow back to normal e.g turbo, z32 then filter, as i had a blow though setup before.
any of you got time to post some pics of your pipe run as you know the z32 has a 75mm pipe run
is it wrong to have my setup like this as im sure most of you for your filter bolted straight onto the z32 were i got a a apexi filter with a 75mm neck on so i have to have a samco pipe connected to it after the z32.
hope this makes sense.
here is the pic what i have done so far it can be changed want it right before the remap.
thank you high five
2 Re: z32 pipe run on 27th October 2013, 6:53 pm
That is exactly how mine is setup
3 Re: z32 pipe run on 27th October 2013, 6:54 pm
that will be fine like that
doesn't matter how far away the filter is from the maf itself as it will simply monitor airflow through it.
what you don't want to do is fit the maf close to the turbo as it will pick up turbulent airflow which will mess with the readings to ecu
4 Re: z32 pipe run on 27th October 2013, 9:25 pm
thx good news thank you for the reply means a lot..
