Gtir Motorsport club » Tech room » Help and Advice » Engine bay - What is this small tank?
1 Engine bay - What is this small tank? on 1st November 2013, 2:40 pm
FPSChris
Hi, finally on an inspection.
Noticed this small bottle was low, what is it and what do I put in it? (attached)
Need to find out where the excess has gone too Sad
On another note, my power steering has gone mad. It squeals like a pig when turning left or right at low revs and still at higher revs but not as much. Ideas?
2 Re: Engine bay - What is this small tank? on 1st November 2013, 2:50 pm
Is it a black or clear bottle? Black, located on side of drivers side strut = power sterring... Clear located on bulk head = brake or clutch master cylenders.
But we could do with some more info about the bottle realy before you go & put the wrong stuff in.
Sqweaky power stearing will be just your belt needs adjusting/tightening
3 Re: Engine bay - What is this small tank? on 1st November 2013, 2:59 pm
Welling_AL
check power steering fluid !!
mine was making the same noises and it turned out it was nearly empty Rolling Eyes
quick trip to Halfolds - job sorted
as Gaz said - black bottle - will be by bulk head - drivers side - when you take lid off it should have a mini dip stick type thing
4 Re: Engine bay - What is this small tank? on 1st November 2013, 3:12 pm
FPSChris
Sorry, thought I'd attached a picture.
Re-done via image shack.
The small clear one on bulkhead, doesn't have any markings so it could need baby oil for all I know. The one closer to the strut has DOT 3 on the top and bigger - That one is fine.
What go's in this? Just narrowed the noise down to that rear belt, seems like water dripping onto it making it slip
5 Re: Engine bay - What is this small tank? on 1st November 2013, 4:23 pm
That would be your clutch fluid  pot mate if you look underneath you should be able to see the pipe going off
6 Re: Engine bay - What is this small tank? on 1st November 2013, 5:48 pm
FPSChris
Case closed! Thanks Nomad. Will grab some tomorrow
7 Re: Engine bay - What is this small tank? on 1st November 2013, 5:57 pm
Your welcome mate Wink
