Gtir Motorsport club » Tech room » Help and Advice » Oil catch can
Oil catch can
1 Oil catch can on 3rd November 2013, 2:11 pm
Scooby_killer
Hi guy dose any one no how to install an oil catch can properly I've had a look around done a few searches and every on has then installed differently some people say remove the black box but some people say not to remove it any one got any pictures of how to install it and what pipe to connect where
Thank you
2 Re: Oil catch can on 3rd November 2013, 4:22 pm
You can keep both but it not needed and keep the  piece that goes into the intake .
4 Re: Oil catch can on 4th November 2013, 9:38 am
FPSChris
Thanks Nomad & Scooby_killer!
Just sorting mine out too so this saves me the question. Hard to find a decent pic of a set up similar to mine but this nailed it
5 Re: Oil catch can on 4th November 2013, 5:52 pm
No problem Wink
6 Re: Oil catch can on 4th November 2013, 8:20 pm
gtirx2
Tbh I am not entirely sure that pic is correct,but to be fair its been a while since I have thought about it lol
I assume that T from the original seperater go's back to the intake pipe then tank?
If so I think its making the catch tank not as effective as the blowby from the hose in the block can just get sucked straight back into the inlet before it even makes the tank?
I don't think there is any really problem venting both from there but instead of the T I would run another fitting off the can back to the intake if you want to stay recirc.
You maybe ok as you have keep the seperater but there also should be a restrictor after the seperater really,more for track bias cars but worth noting nonetheless.
There mention of it in this thread.
http://www.gtiroc.com/forums/showthread.php?63541-Oil-starvation/page4&highlight=restrictor
7 Re: Oil catch can on 4th November 2013, 8:24 pm
I set this up as reccomended by bob a while back ....
8 Re: Oil catch can on 4th November 2013, 8:28 pm
gtirx2
It will work and its good you have kept the seperater but I would lose the T and get another fitting on the catch tank to vent back to the inlet pipe.
9 Re: Oil catch can on 12th December 2013, 4:38 pm
does it have to have the T piece to the intake pipe or can i just run both pipes from rocker cover to catch can?
can you get a flange or something that actually threads/screws into the intake rather than welding one on? if so what are they called?
10 Re: Oil catch can on 22nd January 2014, 1:23 am
mikewazowski
nomad, what have you done to the solenoid and the sensors that mount onto the tmic bracket?
