Gtir Motorsport club » Tech room » Help and Advice » Pulsar timing
Pulsar timing
1Pulsar timing  Empty Pulsar timing on 6th November 2013, 5:49 pm
scottyboy
Any one know the timing marks on a pulsar gtir?
Crank and cams
2Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 6:11 pm
is the engine in or out in bits?
3Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 6:13 pm
scottyboy
In the car haha
4Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 6:18 pm
scottyboy
I think my timing is out a tooth but I only had the marks I made when I took the head off it
If I unplugged the maf runs perfect if I plug the maf in cuts out etc
With the maf plugged in and for the car to run I need to de advance the ignition timing for it to run
With the maf unplugged I can have the ignition timing bang in the middle will run idle etc plug in the maf cuts out hunts when you rev it the turbos boosting also and a loud dump out the dump valve
5Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 6:39 pm
ok its not quite so simple to check engine timing if the oil pump covers on unless you know exactly what your doing and its a bit hard to explain by typing it out.
get a timing gun on it first as the second mark from left on crank pulley (looking at it from the top is tdc.
set the gun to 20 degrees and the mark should there or thereabouts line up with the pointer on the timing cover, if you cant get the 20 degrees or somewhere near it with moving the dizzy back and forth then the engine timing will be out or possibly the damper and outer pulley has moved on crank pulley giving you a false reading.
if its out youll need to phone me and il try explain over the phone how to do it but as said its quite difficult unless you have a good knowledge of cam position etc
6Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 6:42 pm
scottyboy
I think I know what your talking about with cam position one should be coming of the rock and the other should be going on it or something along they lines? Lol
7Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 7:56 pm
yep you've got it in one but still easy to get it a tooth out unless you know exactly where the pulleys should be
il take a pic for you if I get time on Friday of a head that's off but with cams fitted so you can see exactly where the sprockets are at @ tdc
then all you have to do is make sure your crank is on the pointer at tdc on no1
8Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 8:16 pm
Try and make time please bob done it before but will refresh me for sunday
9Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 9:31 pm
Spark plug spike
Spark plug spike
Here you go mate hope it helps.
Pulsar timing  Image
10Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 9:36 pm
Yes as i thought thanks
11Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 9:43 pm
scottyboy
bfc10 wrote:Here you go mate hope it helps.
Pulsar timing  Image
Good lad thanks very much and crank pulley should be 2nd notch?
Thank you aswell bob
Could maybe make this a sticky for future use?
12Pulsar timing  Empty Re: Pulsar timing on 6th November 2013, 10:14 pm
yep that's spot on
basically use the front of the head as a line guide and all 4 holes should line up and cam lobes will be adjacent to each other with ex cam on the rock and starting to open.
yes crank pulley should be on 2nd mark from the left which is tdc.
as long as you get the ex cam correct you cant really go wrong with the in cam but il explain fully in the write up
if you could put that pic in how to section please spike il do a proper write up for everyone
13Pulsar timing  Empty Re: Pulsar timing on 7th November 2013, 8:34 pm
Spark plug spike
Spark plug spike
@GTI-R US wrote:yep that's spot on
Picture posted in the how to section Bob.
14Pulsar timing  Empty Re: Pulsar timing on 7th November 2013, 9:47 pm
Thank you mate Cool
15Pulsar timing  Empty Re: Pulsar timing on 7th November 2013, 11:22 pm
yep cheers spike il do awrite up soon as I get a spare 10 minutes
16Pulsar timing  Empty Re: Pulsar timing on 8th November 2013, 7:48 am
fred05
fred05
french connection
french connection
here to help, the page on the maintenance manual (for the removal of the timing chain...)
hope this help too.
Pulsar timing  Manual10
(for putting it back in)
Pulsar timing  Manual11
17Pulsar timing  Empty Re: Pulsar timing on 10th November 2013, 2:18 pm
scottyboy
Sorry I had to fully advance my timing to run sound like it's out a tooth to you?
18Pulsar timing  Empty Re: Pulsar timing on 10th November 2013, 6:24 pm
yes iwould say so tbh
19Pulsar timing  Empty Re: Pulsar timing on 31st December 2017, 10:04 am
Bandyleg
Bandyleg
@fred05 wrote:here to help, the page on the maintenance manual (for the removal of the timing chain...)
hope this help too.
Which manual did you find that in....
20Pulsar timing  Empty Re: Pulsar timing on 31st December 2017, 10:47 am
hope this help too.
http://www.workshopservicemanual.com/m007225-nissan-pulsar-almera-n14-1990-1995.html
Try this bud
21Pulsar timing  Empty Re: Pulsar timing on 31st December 2017, 12:18 pm
page 210 of Service Manual Part 1
22Pulsar timing  Empty Re: Pulsar timing on 2nd January 2018, 10:35 pm
Bandyleg
Bandyleg
Thank you, i checked it this evening.
