Gtir Motorsport club » Tech room » Help and Advice » consumption
consumption
1 consumption on 8th November 2013, 1:13 pm
fred05
french connection
french connection
Hi all,
yesterday i put some gas in the tank, full tank, to verify how many kilometers i can do with a full tank before putting the walbro in...
i've done 55km since and i loose 1quarter tank. (without pushing it too, putting the 5th gear on half of the 55km done...
normal or not?what do you think Suspect
more than that, i have some difficulties to start it up, like if it was full of gas in cylinders....
before stoping, i leave it run 20sec before cutting
2 Re: consumption on 8th November 2013, 1:36 pm
Hardy172cup
Sounds a bit excessive, I think I did about 200 miles to just over half of a tank of petrol when I collected my car from bobs which I think is good because now I have the car home and im being a bit heavier on the right foot I'm probably seeing less than 200 miles to a full tank lol
3 Re: consumption on 8th November 2013, 1:41 pm
fred05
french connection
french connection
200 miles = 320 kms so not bad, as i do before with my previous R.
maybe i have some troubles with the gauge too...., i will see when i'll be empty!
i do have misfireing sometimes, and other so it is maybe the same problem....
4 Re: consumption on 8th November 2013, 1:53 pm
Hardy172cup
You should look at getting a Wideband AFR gauge installed Fred.
They are brilliant pieces of kit to help diagnose faults and can potentially save an engine, if a fault occurs with fuelling you see that your AFR is wrong from the gauge before any real damage is done.
5 Re: consumption on 8th November 2013, 1:55 pm
Hardy172cup
The only downside is that you become paranoid and constantly monitor the gauge Laughing
They are realy handy thing to have though. I don't think I will ever have a car without one now that I have used one.
6 Re: consumption on 8th November 2013, 2:00 pm
fred05
french connection
french connection
I do have an Innovate on the shelf, i didn't have the time to plug it yet, i need to make the thread bung welded, pass the cable, gauge (where to put the gauge? i don't know without drilling all the dashboard on my mint car!!!!!!)
7 Re: consumption on 8th November 2013, 2:35 pm
<span id="sceditor-start-marker" class="sceditor-selection sceditor-ignore" style="line-height: 0; display: none;"></span><span id="sceditor-end-marker" class="sceditor-selection sceditor-ignore" style="line-height: 0; display: none;"></span>
@fred05 wrote:I do have an Innovate on the shelf, i didn't have the time to plug it yet, i need to make the thread bung welded, pass the cable, gauge (where to put the gauge? i don't know without drilling all the dashboard on my mint car!!!!!!)
&nbsp;&nbsp;
buy a set of a pillars and make a gauge pod, and keep your old pillars for when you put it back to standard
8 Re: consumption on 8th November 2013, 2:39 pm
yours has the rb box fred or am I mistaken?
if so then theres your reason for poor fuel consumption but obviously as above make sure all is as it should be regarding afr's and timing
9 Re: consumption on 8th November 2013, 3:14 pm
fred05
french connection
french connection
Twisted Evil  really nice idea!!
10 Re: consumption on 8th November 2013, 3:16 pm
fred05
french connection
french connection
@GTI-R US wrote:yours has the rb box fred or am I mistaken?
no, RA box.
about timing, i do have a strobe timing light but it is not adjustable. so i can only look and the marking on the engine thing in front of the pulley.
do you know which bar is 20° one?
11 Re: consumption on 8th November 2013, 3:44 pm
yep last on the right looking at it from the top is 20 degrees
12 Re: consumption on 8th November 2013, 3:50 pm
fred05
french connection
french connection
so the last from the front or from the rear of the engine bay?
13 Re: consumption on 8th November 2013, 4:12 pm
regarding the walbro aswell, i didnt actually notice a difference in fuel consumption after fitting mine, i use the same amount of fuel for my work journeys with the walbro as i did with the std pump, sometimes it feels a little better on the fuel
14 Re: consumption on 8th November 2013, 4:22 pm
@fred05 wrote:so the last from the front or from the rear of the engine bay?
yep the one nearest the front of car looking in from the top
15 Re: consumption on 8th November 2013, 5:04 pm
The only thing I notice with fitting the walbro is I can't let the tank go much below a quarter or it starts getting fuel starvation.
Before I had it fitted, the best I managed was 310miles on a tank, now I get at best 200miles to 3/4 of a tank.
16 Re: consumption on 8th November 2013, 5:17 pm
fred05
french connection
french connection
Ok, so she is not good, it is set to the timing mark before the last one.
17 Re: consumption on 8th November 2013, 5:44 pm
Did you not angle the pump down pete ?..
18 Re: consumption on 8th November 2013, 10:35 pm
@nomad wrote:Did you not angle the pump down pete ?..
Yeah I think I got it as low as possible, might have knocked the fuel lever sender maybe?
19 Re: consumption on 8th November 2013, 10:55 pm
why you not swap the pickup over with the standard pump?
20 Re: consumption on 9th November 2013, 7:38 am
@Digitalfaze wrote:why you not swap the pickup over with the standard pump?
I can't remember if I did, been so long since it was fitted.
21 Re: consumption on 10th November 2013, 4:58 pm
fred05
french connection
french connection
Back to my thread, to review the timing, do I need to undo the 2 bolts (on at the top of the distributor and the one at 8h down?) And then rotate it front or back, am I good with that?
22 Re: consumption on 2nd December 2013, 8:11 pm
fred05
french connection
french connection
Well to sum up. My consumption is quite normal at 320km for a tank.
23 Re: consumption on 24th December 2013, 7:23 pm
richpulsar
@pulsarmoley wrote:The only thing I notice with fitting the walbro is I can't let the tank go much below a quarter or it starts getting fuel starvation.
really pete I have a walbro fitted to mine and it doesn't matter if I run below 1/4 tank
24 Re: consumption on 24th December 2013, 7:40 pm
Bloody hell Rich, you keep popping up here and there. Maybe mine could be lowered more or something but im not messing around with it again.
25 Re: consumption on 24th December 2013, 7:48 pm
richpulsar
fair enough and yea don't worry pete im still around just haven't posted for a while, mine WILL be on the road again in the new year its been too long
