Restoration Project
Go down  Message [Page 5 of 6]
101Restoration Project - Page 5 Empty Re: Restoration Project on 22nd June 2016, 10:09 pm
Clutch pedal not sticking mate, the noise happens 2/3's the way down but comes back up easily.
102Restoration Project - Page 5 Empty Re: Restoration Project on 23rd June 2016, 3:58 am
Like I said before likely be pressure plate as when shaft slightly inserted you put lot of stress on it if struggling with box,
Not a great quality plate if hub has cracked from that, normally they buckle at hub join or crack plate joining hub .
Camera quality don't look bad, you should add link for that in tools :-)
103Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 5:16 pm
Nearly there, got the engine out from start to finish in 3 1/2 hours
Restoration Project - Page 5 F22E10B6-1562-457B-AF95-754D3EA025C6_zpspc0h5b7i
Restoration Project - Page 5 00B0F954-6FB8-486E-B9FA-5D704610C254_zpscw6jzesq
Restoration Project - Page 5 15D7E6A7-BD94-4553-93F5-56F135A67EB8_zpsohh8efw5
Hoping to get the box off later and find out what the damage is.  The wife let me in that garage but the deal was if the baby woke Id have to come back in Laughing Laughing under the thumb or what!! Laughing  guess what got the engine out and she text Laughing
104Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 6:57 pm
Should of kept your baby wrench in the toolbox lol  Laughing it's like spilling water on a gremlin when get that out the tool drawer Shocked
105Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 7:19 pm
Well the plot thickens! plate fine
Restoration Project - Page 5 7E025C30-7961-4D30-BE9B-345F9BA8A71F_zpsyvrhrpxy
cover fine
Restoration Project - Page 5 108B63E3-BEDC-471F-965D-2D1DA1BC1D74_zpsn9xlbspc
although the tips of the fingers look like theyve got hot?
Restoration Project - Page 5 BE8066CA-D290-457F-9DA6-4575C12633CD_zpsdexbxb62
Restoration Project - Page 5 CF380C87-BD1A-4D41-8AB4-150148FEAB76_zpsdeg5adek
What looked like a crack was infact a bit of steel
Restoration Project - Page 5 4DCE5ABB-A1C6-440C-ACF4-B8A6594ADFC9_zps4tbsmoya
But, for some reason on the inside of the bell housing
Restoration Project - Page 5 205BC637-C185-4CF2-BBC1-61AF5D61F7E3_zpsdz2thtby
Does the cover expand when releasing? this might explain the noise, definetly been rubbing on the cover, but only when pressing the clutch pedal.
I cant see any other marks that would make the noise...  If I get chance tomorrow I'll whizz the fly off build the clutch back up and pop it on the input shaft to see if it is catching.  I'll make a brack to bolt to gearbox to keep the fly from being pushed off when operating the clutch.
106Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 7:36 pm
Can you see likely point on cover that made that contact !
You got fresh swarf from the contact over clutch ?
Does flywheel & clutch parts all run true ?
Place cover in bellhousing to get idea what contacting
Are gearbox alignment dowels & clutch cover dowels all in place ?
Possibly something wrong in cover causing it run off true as fingers loaded or cover flexing at one point ! you probably dig up a conclusion if dig around . odd one though :-S
107Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 7:48 pm
Can you see likely point on cover that made that contact ! Nope
You got fresh swarf from the contact over clutch ? The swarf was from when I caught the input shaft trying to get it on
Does flywheel & clutch parts all run true ? dont know yet
Place cover in bellhousing to get idea what contacting Planning on building it all up and mounting gearbox in car connecting hydraulics and seeing whats what
Are gearbox alignment dowels & clutch cover dowels all in place ? yep all there
Possibly something wrong in cover causing it run off true as fingers loaded or cover flexing at one point ! you probably dig up a conclusion if dig around . odd one though :-S Ive kept the original Nissan cover so can compare against
Will keep this updated with what I find, was hoping to see a gouge in the friction plate and a buggered finger Laughing
108Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 8:01 pm
No sign of block tin plate catching on ring gear teeth then ! (wondering if mark anyway related to fiting grief & noise somewhere else, mark does look rotational contact gouge though ! )
I would manually just put cover in bell housing to get position idea & contact idea of cover ! I'm curious lol :-)
I assume cover tilting or flexing off square as fingers loaded slightly :-S
won't sleep tonight now lol :-/ I need answers or sleeping pills lol ...
109Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 8:29 pm
After Johnny said the other day about the tin plate catching I checked it when I took the box off and its fine.  I did cut it either side where the starter goes throughb but made sure it fitted correctly when first installing the box.
Out of interest how many times can the fly bolts be reused? I didnt renew them, last time.  If I remember correctly I think you replied to a post about torquing them less than factory spec? Sure I replied on the same thread but cant find it!  Will check straightness of the cover and plate tomorrow morning.
110Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 9:07 pm
Just for you Mr B, I went back out to the garage to solve the mystery! Couldn't bear you not sleeping Laughing
So up ended gearbox, put the cover on the release bearing, got it near enough center as I could and well....
Restoration Project - Page 5 FB10432B-C42B-4241-A0B5-CD858ECDD092_zpsu7uedbue
Restoration Project - Page 5 05BA3554-23E9-47D5-90CC-9700E650BDEF_zpsudjyxmwh
Looks as though when I thought the chain tensioner was goosed and letting the chain droop causing engine to lock when rotating by hand, it was actually the cover plate hitting the casing Shocked  so when priming the engine it cut the groove, then was fine until operating the clutch obviously that must move out slightly and causes the noise.
Restoration Project - Page 5 73877831-51CB-4D01-B38E-34B7C6B9EAAF_zps8ocwcfnj
Comparing it to the OEM cover, that bit is bigger on the blue print one, OEM one is smaller and more curvy, plus sits further forward away from the casing.
Restoration Project - Page 5 7ADA4928-FB53-47C1-B9A3-B5D079AE1727_zpsu8hywuyx
Hard to see in that picture, but it's no where near the casing.
Restoration Project - Page 5 FF2B3F08-B3A4-46B8-8934-C8B41A060FFC_zpslbnk8fdk
OEM on the bottom
Restoration Project - Page 5 E329F72F-075C-47C7-8B57-903A835165CB_zpsilmeufla
Don't know what to do now, either grind a bit of the casing away or grind the BP cover (risking unbalancing it) or lob the OEM one back on after cleaning it up?
111Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 9:24 pm
Thank buddha for that mr burrows Restoration Project - Page 5 Wai2 I been tossing & turning, counting sheep & all sorts :-)
Think I would grind housing just to tidy up the gouge then take bit off the cover to be sure it clears, If remove lot of material then can always pop it in a shop for a balance but doubt it will be out of acceptable balance range unless unlucky .
least it not really your fault from fitting so you in the clear there, might be worth putting up specific thread on that for ADN clutch so others don't get same problem .
Think i'll be comparing & inspecting clutcches more thoroughly from now ... Restoration Project - Page 5 Wai2
112Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 9:30 pm
I'll pop a thread up, it might just be a bit of excess cast in my box, as long as theres not something gear internals a few mm the other side of that!
Am I right in think that part thats catching must move when the release bearing pushes on the fingers?
113Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 9:36 pm
You can use a lath to remove equal amounts. But I'd grid the casing, that's how I got the big ass clutch to fit in mine.
114Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 9:43 pm
Yeh I would only smooth off the gouge rather than cut deeper.
You got 3 of those rivet to spring plate position pieces so if re-work each one close to oem cover it should be fine & still balanced quite well as not doing it just at one point .
as clutch pressed the steel plate in the cover will move back a bit towards gearbox casing, If looks iffy trying re-work it good enough then sourcing another cover would be safer than another removal :-S
115Restoration Project - Page 5 Empty Re: Restoration Project on 25th June 2016, 10:02 pm
Cheers guys, shame my lathe is only a 5" bed height Mad I'll grind the casing tomorrow, tidy it up see what clearances I can get. Dont particularly want to build it back up and happen again Sad
116Restoration Project - Page 5 Empty Re: Restoration Project on 26th June 2016, 6:12 am
I never thought of it here mind just with been the engine,box and clutch it was but is what had to be done when I fitted my new primera p10 box to the sunny Gti running pulsar sr 20 Det lump. But I knew this as was pre grinded marks on the old box so copied them before I fitted it
117Restoration Project - Page 5 Empty Re: Restoration Project on 26th June 2016, 1:25 pm
Heres a vid of the cover catching
Looks an easy fix to be honest.  Will get it done one night this week and get it all back together.
Need to find the missing driveshaft spring clip in the transfer box Shocked noticed its no longer on the shaft, doh!
118Restoration Project - Page 5 Empty Re: Restoration Project on 26th June 2016, 4:12 pm
Spark plug spike
Spark plug spike
Which driveshaft is missing the clip? As one has a clip the other doesn't?
The longer shaft doesn't have one fitted its in the box.
Last edited by Spark plug spike on 26th June 2016, 4:27 pm; edited 1 time in total (Reason for editing : More info added)
119Restoration Project - Page 5 Empty Re: Restoration Project on 26th June 2016, 4:38 pm
Ahhh cool saves me looking then Laughing it's the long one I noticed didn't have it. Cheers matey
120Restoration Project - Page 5 Empty Re: Restoration Project on 1st July 2016, 7:27 pm
Bolted the box on before, but before doing that I painted the area I ground red so easier to see with the endoscope!
Restoration Project - Page 5 ED347A57-327D-4F79-A8C2-004DE4CBDCF8_zpsplxaoagg
Bolted box on and put the endoscope in to check the clearances
Tomorrow will get the engine mounted and bolt slave cylinder back on, operate the clutch and check clearances again..  Hopefully there should be no problem this time round!
Restoration Project - Page 5 WIN_20160701_18_31_23_Pro_zps9vefk3s4
Restoration Project - Page 5 WIN_20160701_18_31_34_Pro_zps07iaynim
121Restoration Project - Page 5 Empty Re: Restoration Project on 1st July 2016, 7:41 pm
Fingers crossed mate Smile
122Restoration Project - Page 5 Empty Re: Restoration Project on 1st July 2016, 8:07 pm
Hopefully mate Neutral
123Restoration Project - Page 5 Empty Re: Restoration Project on 2nd July 2016, 6:00 pm
Chucked engine back in this afternoon, hooked up slave cylinder got my mate to operae clutch while I watched with the endoscope, and thankfully looks like it clears it now. Rotated the engine with the clutch pedal to the floor and seems ok
124Restoration Project - Page 5 Empty Re: Restoration Project on 8th July 2016, 7:33 pm
Got a spare 5 minutes to day to start the car up and check wether the clutch issue is now cured..
Thankfully works a treat now, get the rest of the front end built up now, maybe MOT end of summer Very Happy
125Restoration Project - Page 5 Empty Re: Restoration Project on 8th July 2016, 8:22 pm
Nice one, glad its all sorted out, Very Happy
Back to top  Message [Page 5 of 6]
