Restoration Project
Go down  Message [Page 4 of 6]
76Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 3:23 pm
So today was the day I would start the engine!!
I can confidently say it went well very well, well kinda!  Cranked the engine for a while with fuel pump disconnected and plugs out, watched the oil pressure rise and stabilise.  Put the plugs in, IC back on and nervously turned the key, couple of cranks and she fired up straight away Very Happy  Oil pressure fine, timing bang on, power steering noisey Laughing sorted that later, all air locks removed.  Ran it to operating temp, rad fans kicked in around 95c once they went off, killed the engine and let it cool before checking the fluids.
This is genuinely the forst startup as you can here from the powersteering pump Laughing again uploaded in HD but looks pants Mad
Ok so now heres the problems, engines got to come back out Sad  for some strange reason when pressing the clutch pedal down a grinding noise can be heard?? almost like trying to select a gear when clutch not used! Ive ordered an endoscope to see whats going on before removing, I can only think when I man handle the box back on with the trans still atached to the box ive damaged the splines on the pressure plate?  What I dont get when the engines running, no grinding noises can be heard only when the clutch is starting to be pressed, id say after half of the travel?
Turned engine off and selected first, started engine up let it idle but could hear some strange sound from the near side rear wheel Crying or Very sad while its rotating a clicking tapping noise is present, think its a wheel bearing issue, grrrr, possibly not fitted it right or its faulty.  All 4 brand new from ICP..
Finally while it was in gear I expected all 4 wheels to rotate, but the front drivers doesnt?  is this something I should be concerned about?
Other than that alls good Laughing  The idle after doing the throttle bodies is bang on, throttle response is crisp too.
Dodgy quality video of OBD Scan Tech data while it was running, I did upload in HD but looks pants for some reason?
77Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 3:30 pm
Update:
When turning the drivers front wheel manually the rear wheels move, the brake calipers binding on the front, maybe reason why it's not turning in gear transferring power to left front?
78Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 4:21 pm
front driver wheel not turning nothing worry about, that just because open diff & like you pointed out yourself more binding that side possibly and also longer shaft & support adds resistance too .
79Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 4:37 pm
Another issue solved, the bearings fine its the brake pads Laughing I havent put the metal shims in yet so the pads are loose
Hence the noise when wheels rotating..
Onto the clutch, I think when I tried to get the box on I have bent a spline on the pressure plate, as the bearing pushes onto it when putting foot on clutch pedal, the bent spline is hitting the friction disc! I'll no more when the endoscope arrives next week!
80Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 4:45 pm
I reckon you right on clutch too, likely friction plate bent & when cover pressed enough to release it you can here it catching against cover intermittently as it like a buckled bike wheel lol .
least both nothing overly major although doing clutch again sucks but beats a bottom end rattle & low oil pressure :-)
Least you'll be able able admire your shiny handy work when doing correction work & you won't get dirty but may need wear gloves to avoid finger print marks ...
81Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 4:57 pm
Your defo right there mate, glad it is only a clutch!
82Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 5:18 pm
pressure plate could be fine as reasonably hard bend fingers, hub twisted on friction plate is normal one to happen.
either way not a life changer and you'll be buzzing so much from sweet engine it won't be any burden put right .
Some more porn shots for us too so everyone happy lol .
83Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 5:28 pm
Well done clutch is a bitch but as B says if that's the worst of your problems your doing alright
84Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 8:12 pm
What part of the friction plate could bend?
Edit: It sounds like when you put a playing card in bike spokes..
Restoration Project - Page 4 C7D5E0A5-60A2-4528-8964-030F1D76215C_zpsf8wwtfps
Restoration Project - Page 4 CBBD22BB-0DB6-4122-87A6-B4E6EC591773_zps5q4rmsws
Restoration Project - Page 4 C61AE5A0-B09E-469D-913F-05A8EEA4386B_zpsucfr2nt2
Definetly a learning curve! not to rush in future and not to try and lift the box and transfer on my own Laughing
85Restoration Project - Page 4 Empty Re: Restoration Project on 19th June 2016, 8:32 pm
86Restoration Project - Page 4 Empty Re: Restoration Project on 20th June 2016, 8:40 am
Dude that sounds nasty lol glad you are making progress though.
87Restoration Project - Page 4 Empty Re: Restoration Project on 20th June 2016, 9:11 am
Did you fit the metal spacer for the box ? It was not cut ? Some people cut them if they forget to fit It's not the fly catching it ? But you said it was not all the time
88Restoration Project - Page 4 Empty Re: Restoration Project on 20th June 2016, 9:57 am
Yeah I forgot to fit it so err cut it, but it's only when I press the clutch pedal in more than 2/3's as though the fingers on the cover are bent in slightly, as the release bearing pushes them in they start to catch on the friction plate... I cut that plate by the starter motor.
89Restoration Project - Page 4 Empty Re: Restoration Project on 21st June 2016, 7:38 pm
Spark plug spike
Spark plug spike
@burrows1980 wrote:What part of the friction plate could bend?
[url=https://s132.photobucket.com/user/burrows1980/media/GTi-R%20engine%20rebuild/C7D5E0A5-60A2-4528-8964-030F1D76215C_zpsf8wwtfps.jpg.html]Restoration Project - Page 4 C7D5E0A5-60A2-4528-8964-030F1D76215C_zpsf8wwtfps
Is the clutch plate fitted the wrong way round??? Looks like it in that picture.
90Restoration Project - Page 4 Empty Re: Restoration Project on 21st June 2016, 8:07 pm
It's the way my old one was Shocked
91Restoration Project - Page 4 Empty Re: Restoration Project on 21st June 2016, 10:16 pm
@gtir_woody wrote:Dude that sounds nasty lol glad you are making progress though.
Thats not pete in the car is it grinding gears? He is terrible
92Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 4:55 am
Plate looks right way round
Hub of plates tend get buckled if box weight hanging on them while struggling fit
Suppose you could of done similar on cover finger
Other thing due to noise description is perhaps metal plate catching on starter ring when fly loaded a bit !
93Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 7:31 am
Hoping the endoscope comes today can see what the problem is, providing i can get the camera to the problem!
94Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 8:29 am
Bandyleg
Bandyleg
This clutch noise is exactly the same as what im having, Brand spanking new clutch in mine and if its bent then thats not good really. That said im having my box rebuilt whilst its out again, if you get to the bottom of it dont forget to let us all know Smile and in case I miss it would some nice person pleeeeeease PM me the results thanks.
95Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 8:44 am
No worries mate, will post it up that what's this forums all about cheers I know I've bent something as I was stupid the way I tried to get the box on, rushing late at night not a good thing!! Best of it is as I couldn't get the bastard bolt in, I ended up taking the transfer box off to get the bolt in, and I did think I should take the box off to check I hadn't damaged anything but decided not to Neutral oh well steep learning curve!
96Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 3:32 pm
Bandyleg
Bandyleg
LOL Most of us are all on that learning curve Smile Only had the car 7 months and its the second time engine and box have been seperated ive done about 100 miles in it if im lucky lol but once its done it will be right. Unless owning a pulsar is like reaching for the stars? Very Happy
I should probably update teh project log too haha
97Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 8:51 pm
Endoscope turned up today, after checking out the wax in me ears and bogeys up me nose I went out to the garage with it Laughing
The vids still uploading to youtube, going to take another hour or so but I have got a screen shot of what I found.  I applied a small amount of copper grease to input shaft before installing onto engine.  One of the fingers has copper grease on now and just behind that finger is what looks to be a scratch/gouge or strand of metal sticking up
Restoration Project - Page 4 Clutch_zpsqfuwq2kn
Not fully sure what it is but looking at my old cover I dont think Ive bent a finger enough for it to hit the plate? think its defo engine out to properly inspect.
Will put the link up to thevid when its ready!
98Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 9:27 pm
Certainly interesting, I would have thought you would be very unlucky to bend that section. However that scratch mark you are referring to could be something.
99Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 9:48 pm
So heres the vid, not the greatest but the best i could do
you can see the scatch starting or what ever it is.. If im allowed this friday I will try and drop the lump to see what it is, but im not holding my breath tbh as the wifes still suffering Sad
100Restoration Project - Page 4 Empty Re: Restoration Project on 22nd June 2016, 10:02 pm
Looks like it might be a cracked pressure plate to me, orginating at the spline.
If so it may explain the noise and why clutch pedal sticks.
Back to top  Message [Page 4 of 6]
