Gtir Motorsport club » Tech room » Help and Advice » induction pipe
induction pipe
1 induction pipe on 13th November 2013, 4:49 pm
Right so Ive decided to make my own induction kit using the one off my old sunny, which consists of alloy tubes and blue rubbers etc, spent a few hours today putting it together and looks tidy tbf, better than the oem black plastic one, got a few Q's though:
Do the alloy pipes need a ridge to stop the silicone pipe blowing off? (thought they would be ok as the turbo is sucking not blowing on that side????)
What do I do with the valve solenoid pipe? (small pipe from solenoid located at the rocker cover?) Do i need to weld a small flange into the alloy pipe?
What to do with the rocker cover breather pipe which originally goes into the induction pipe, can I just put a breather filter on the end?
cheers Tom
2 Re: induction pipe on 13th November 2013, 7:33 pm
I would say your ok without ridges as you say its intake. Up to you personally i would keep the pipe rocker cover breather pipe although alot of people dont. Did you have two 45 pipes on your intake ?
3 Re: induction pipe on 13th November 2013, 9:52 pm
no from turbo ive got:
silicone reducer- 90degree alloy- alloy straight- 90 degree silicone and alloy to maf.
4 Re: induction pipe on 13th November 2013, 10:21 pm
You avoid 90deg angles  as it will give you turbulance  ....you would be better with 45' bends ...
5 Re: induction pipe on 14th November 2013, 4:52 pm
oops too late :/ will try it for now got to run in engine first before boosting or anything, so can change it later
cheers lads
6 Re: induction pipe on 14th November 2013, 6:52 pm
yep as Leighton said but we generally use 60 degree bends as its a bit tight with 45s but either will do fine
7 Re: induction pipe on 14th November 2013, 6:55 pm
cheers bob, will keep my eye out for cheap pipes in future Smile
