Gtir Motorsport club » Tech room » Ecu related section » ecu chip???
ecu chip???
1ecu chip??? Empty ecu chip??? on 18th November 2013, 4:49 pm
just hunting through some parts and come across this chip in a box which appears to be brand new and never fitted, with the fixing for daughterboard and plug in wire.
anyone know what it is as im gonna sell it????
ecu chip??? 6ke0Uploaded with ImageShack.com
2ecu chip??? Empty Re: ecu chip??? on 19th November 2013, 2:12 pm
watoga
watoga
ecu technician
ecu technician
I certainly do!!!!!! It's an EPROM board off this product line:
ecu chip??? BigMAZDANISSAN1
and made by Technosquare. I haven't seen any before, but the functionality of switching maps would be useful! Was this off a GTiR? Or another Jap car?
Good find,
Dave
3ecu chip??? Empty Re: ecu chip??? on 19th November 2013, 3:23 pm
cheers dave
was in a box in sealed static bag from back of a gtir we bought some time back.
obviously the guy sent off for it but never got round to fitting the chip
so is it remappable or a twin chip for a stock and go faster generic map which would be switchable?
4ecu chip??? Empty Re: ecu chip??? on 20th November 2013, 9:53 am
watoga
watoga
ecu technician
ecu technician
I believe there are 2 different chips; one containing the stock map, while the other contains a re-mapped version. Being EPROM chips they will be re-programmable, but not quite with the same ease as NIStune (for example) which can be linked with the existing diagnostics plug. You might be able to do this with some EPROM chips, but others may require the chip to be physically removed from the ECU to re-burn a new map. I'm not 100% sure as I've not seen these chips before. Technosquare's website doesn't seem to have been updated in many years, but there is some information regarding re-programming here:
Technosquare Flash Reprogramming
Seems like there may be some faults with their software/hardware, but I don't see why local tuners wouldn't be able to re-burn newer maps onto the existing chips.
Cheers,
Dave
5ecu chip??? Empty Re: ecu chip??? on 20th November 2013, 7:40 pm
This is same type as what i found in my ecu the one i spoke to you about but without the wires dave
6ecu chip??? Empty Re: ecu chip??? on 20th November 2013, 10:51 pm
cheers dave
would think the wires just go to a switch johnny so you can switch between stock and modded map
7ecu chip??? Empty Re: ecu chip??? on 21st November 2013, 7:10 am
pretty much a normal daughterboard, twin chips are normally 2 8bit chips to work with nissan 16bit bus ecu. Maps are not on each chip but combined on both with binary data logically split between the chips. Can use 16bit eprom chips but not the usual due to cost/chip sourcing.
Not sure how map switching would work (probably binary pulses) or how you know what map you are on but assume a small switch controller & status led is required. Would also assume no real time mapping can be done with this daughterboard & chips need removing for editing ...
8ecu chip??? Empty Re: ecu chip??? on 12th December 2013, 3:09 pm
weblizzer
i have mine which is switchable but it's different one. I got it from nismotronic website. And they use moates board. http://support.moates.net/nissan-20x2-boards/
