Gtir Motorsport club » Tech room » Ecu related section » Buying a new ecu help!
1Buying a new ecu help!  Empty Buying a new ecu help! on 20th December 2013, 2:22 pm
Rot box revival!
Right going on Bob's advice i'm ditching the old HKS super AFR and replacing it but I'm not sure what to buy. I want to learn a lot more about mapping and what it involves so something user friendly and i would also like to be able to store two maps and switch between them. One for noising up the rich and clueless and one for goin to the shops! Hahahaha Another plus would be if it could display the AFR to save me buying wideband.
This could all be totaly impossible but i'm new to it all so go easy man!
Cheers
2Buying a new ecu help!  Empty Re: Buying a new ecu help! on 20th December 2013, 3:25 pm
danr
danr
old PLMS (nistune) board with 4 map switcher. bob had my old one, dunno if they still about.
works with nistune but you cat live map.
dunno if nistune now allows multimap switching?? if yes then nistune Wink (unless im now out of date!)
3Buying a new ecu help!  Empty Re: Buying a new ecu help! on 20th December 2013, 3:34 pm
yes ive still got that board dan
wondered where that came from as only found it the other day
yes that would work if you want a cheap upgrade which can be mapped! think it has a stock map and a tuned map on it
4Buying a new ecu help!  Empty Re: Buying a new ecu help! on 20th December 2013, 3:38 pm
danr
danr
yh, has a ed@fusion 350bhp @1bar map (damn i miss it!)
and a sneaky 3000 rpm rev limit map for when you leave it with any garage!
and a cute little 4 button microswitch box
5Buying a new ecu help!  Empty Re: Buying a new ecu help! on 20th December 2013, 3:44 pm
is this the one dan?
Buying a new ecu help!  6ke0
6Buying a new ecu help!  Empty Re: Buying a new ecu help! on 20th December 2013, 3:58 pm
that 3000rpm limit is an amazing idea!
7Buying a new ecu help!  Empty Re: Buying a new ecu help! on 20th December 2013, 4:03 pm
danr
danr
hmm, i honestly cant remember what it looked like bob. it had a flat ribbon cable plugged into mine with a little black/white/red box with 4 little buttons.
http://www.plmsdevelopments.com/daughterboards.shtml
8Buying a new ecu help!  Empty Re: Buying a new ecu help! on 20th December 2013, 5:24 pm
Rot box revival!
So the one you had dan, had four maps on it? Like the sound of this! Is that the one you have for sale Bob?
9Buying a new ecu help!  Empty Re: Buying a new ecu help! on 20th December 2013, 5:37 pm
no the one I have is the one in pic above
I thought it was dans one as it came in the back of a car we bought a while back now with a load of other bits which ive only just come across a week or so ago
ive also got 2 chipped ecu's and a fully remappable ecu
a power fc with commander and a motec standalone ecu but il be using one of these for my new project car were building
