Gtir Motorsport club » Tech room » Ecu related section » Uprated ecu
Uprated ecu
1Uprated ecu Empty Uprated ecu on 1st April 2012, 7:30 pm
Ajay.
Right then what would be the best Ecu plug and play to get that actually is noticeable and aggressive, power wise iv currently got some hks 272 cams fitted so top end is sorted just lower end seems  not quick enough only running  a bar of boost for now,any idears blitz,mines,etc
Not looking for big power but just somefink with a bit more grunt at lower revs.
Thanks all.
2Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 7:46 pm
Kate&tim
Kate&tim
You can get a couple of differant ecu's the Mines I think is the main one .
Its basically has a differant map on it , you can have your std ecu re-mapped by edd at fusion by adding a new board to the ecu ( nistune).
This is a bespoke map for your car and mods etc , around £500 but its worth it.
3Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 8:08 pm
Ajay.
Was thinking about popping down to fusion,just looking for different views on the plug and play ones as what ones the best one to go for and makes a difference.
4Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 8:35 pm
Kate&tim
Kate&tim
With a plug and play like the Mines , it's well advised to have the car rolling roaded to make sure your car is getting on with it this is another cost to consider.
Also having someone who knows what there looking for!
5Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 8:47 pm
Ajay.
Correct fueling is defo important raising the boost or mapping or any plug and play ecu,will have to give edd a call I think.
6Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 9:15 pm
the mine, blitz and many of the other are all pretty much the same tbh althogh the blitz and mines are the most common.
both are chipped to be able to run 1.2 bar but as aid it pays to get the cars fuelling checked on the rollers (its only an hours dyno time youll need) at least this will highlight any faults you may have in your ign and fuel system...if any!
others have run 1.4 bar on these ecu's with no probs
7Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 9:21 pm
Ajay.
Bob do you have any ecu,s, drop me a pm If so may well be intrested.
Thanks
8Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 9:29 pm
hi aj
all i have in at the moment is a nistune ecu thats been mapped by ed....not removed this from the car yet though as im still running round in it
9Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 9:33 pm
Ajay.
Not a problem if you do get any blitz or mines drop us a pm as iv made my
Mind up now lol
10Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 9:38 pm
will do aj, you missed out on the other blitz we had but il give you a shout soon as we get one in fella
11Uprated ecu Empty Re: Uprated ecu on 1st April 2012, 9:40 pm
Ajay.
Cheers Smile
12Uprated ecu Empty Re: Uprated ecu on 3rd April 2012, 2:09 am
danr
danr
nemu nismotronic! lol probably a bit ott but worth a mention
13Uprated ecu Empty Re: Uprated ecu on 3rd April 2012, 5:36 am
skiddusmarkus
skiddusmarkus
Those cams are total overkill for that boost, no wonder it fells a bit gutless lowdown.Unless you are running 1 bar on a gt3076 or summat.
Have you had them dialled in or were they already fitted when you bought the car?
14Uprated ecu Empty Re: Uprated ecu on 3rd April 2012, 11:43 am
Ajay.
had them a while back not to sure got them fitted at gtirus.
15Uprated ecu Empty Re: Uprated ecu on 3rd April 2012, 12:42 pm
yeah we did fit the cams for you aj, will be better with more boost but will always be laggy off boost tbh
cams can only really be dialled in on the rollers its a pig of a job to do as rocker cover needs to keep coming on and off, plus every engine setup is slightly different so we set them at 20degreesbtdc.
see how they are with chipped ecu and upping the boost
16Uprated ecu Empty Re: Uprated ecu on 3rd April 2012, 12:51 pm
skiddusmarkus
skiddusmarkus
Hah, foot in mouth moment then Very Happy.What I meant was its a waste of the cams at only 1 bar unless its a big turbo and you are making much more power that a T28 would.
17Uprated ecu Empty Re: Uprated ecu on 3rd April 2012, 1:22 pm
nah thats fine sye lol
on a road car they are ok with upped boost, wpuld benefit by a bigger tubby though.
i wouldnt use them on a circuit based car (used to be fitted to mine) its all or nothing and right at topend of rpm range which is no good on exit from an apex, we just needed a wider spread of power and minimal lag which i near enough have now.
18Uprated ecu Empty Re: Uprated ecu on 3rd April 2012, 1:29 pm
Ajay.
I see,Im still waiting for that ecu bob dnt forget lol,I will up the boost to 1.2bar with a ecu on the rollers and hopefully should get abit more grunt at lower revs.
19Uprated ecu Empty Re: Uprated ecu on 3rd April 2012, 1:37 pm
i wont forget you aj
as soon as we have another in stock il give you a shout.
they are a lot more aggressive lowdown and midrange, my white uk sunny now feels quite mundane since i flogged it
20Uprated ecu Empty Re: Uprated ecu on 23rd July 2012, 4:46 pm
TurboTom
ajay wouldnt you rather get an ecu fitted with a nistune already then get ed to map it? cheap way of doing things, and its not expensive to get the map changed
I say this becuase in my old starlet i had a toms ECU fitted (meant to be the best) and i just didnt trust it, i had the same setup as was recommended but it just never seemed right if you know what i mean, seemed to be running quite rich a lot of the time, and the difference between standard and that was minimal
21Uprated ecu Empty Re: Uprated ecu on 23rd July 2012, 5:06 pm
Ajay.
I actually bought a ecu from Bob tested 2 of them and picked the one I was happy with,it did make a diffrence as I was chuffed on the way home,not only that I'm only just runnin 0.9 bar so not even 1 bar yet,il be down at Eds soon for 1.2 bar on the rollers so hopefully that will please me more afro
22Uprated ecu Empty Re: Uprated ecu on 23rd July 2012, 5:47 pm
TurboTom
ah fair enough mate!
might just be a starlet thing then. We are all lucky to have bob ey!
what ecu did u get mate
23Uprated ecu Empty Re: Uprated ecu on 23rd July 2012, 6:24 pm
Ajay.
It was chipped ecu can't remember the name maybe bob might remember,i was looking for a mines or a blitz but I heard there's not much of a diffrence between them all, and there pretty much slightly all the same,but yeh Bob is defo a good chap and a laugh and sorted me a good deal
