Gtir Motorsport club » Tech room » Help and Advice » new clutch noises
new clutch noises
1 new clutch noises on 10th January 2014, 8:23 pm
Hi hoping someone may know, figure its gonna be box off anyway but thought someone in here may have had an issue similar, when i broke my first clutch launching the car, i replaced it with an organic exedy (genuine) and i had this problem which i just assumed was because it was a new clutch, anyway when i pull off in the car i get this horrible sound, its hard to describe but sounds like when you have noisey brakes on your bicycle (screeching sound).
this noise happens when im pulling the car off on the bite and even worse when the car is cold and the clutch has done around 10k miles probably more since it was fitted
after hearing vpulsar mention about clutch release bearings for silvias made me wonder if i have the right bearing in.
does any know what this noise could be?
Thanks in advance
2 Re: new clutch noises on 10th January 2014, 8:51 pm
Did you fit the clutch yourself mate .... ive never really heard a release bearing squelling not saying its not .... but in my experiance they tend to make more of a rattley sound wich tends to be worse on idle without the pedal depressed when you then press the pedal down it quitens off .... maybe its more the pressure plate ?
3 Re: new clutch noises on 10th January 2014, 9:04 pm
yeah me and my brother fitted it, was all torqued up correctly etc, yeah ive never heard this sort of noise before, sort of sounds like the clutch is squeeling off the flywheel i dunno
4 Re: new clutch noises on 10th January 2014, 9:14 pm
Is it definatly coming from the gearbox side .... its not powersteering pump/alternater area ?
5 Re: new clutch noises on 10th January 2014, 9:29 pm
My exeedy does this . it like a weird rattling squeal .
Doesn't do it always just now and again
my old sunny 1.4 did exactly the same with the same noise .
but when it made the noise the clutch would slip . But only while it made that noise
Again not always just now and again
6 Re: new clutch noises on 10th January 2014, 9:43 pm
yeah it feels like it slips when its cold sorts itself out when the car is warm, think its maybe an exedy problem?
7 Re: new clutch noises on 10th January 2014, 10:06 pm
My excedy single hyper carbon slips untill its had a couple launces not that i boot it from cold but if i drive till car is warm them first couple times you put your foot down it it slips untill you warm it ie launch or slip it. Its done it from brandnew and after its warm you can grief it and launch and it holds no problem.
Ps i dont launch my car everywhere
8 Re: new clutch noises on 10th January 2014, 10:46 pm
I think it's more likely a release bearing fault/noise
9 Re: new clutch noises on 11th January 2014, 8:04 am
oh well i guess its box off and another new clutch, quite irritating considering the cost and ball ache of fitting another unit
10 Re: new clutch noises on 11th January 2014, 9:36 am
my new clutch also makes a funny noise when cold, but once the car is running it stops, my mate reckons its the release bearing but said not to worry about it as its all new :/
11 Re: new clutch noises on 11th January 2014, 10:45 am
is it also an exedy you have bebb? its not too concerning its just the irritation and the looks when your pulling out a parking space or away from a junction
12 Re: new clutch noises on 11th January 2014, 6:07 pm
I can imagine not ideal when out and about but personally i would be very tempted in this case to say if its not broke dont fix it but this is me sitting writing on my phone i can not hear the noise to say
13 Re: new clutch noises on 11th January 2014, 6:41 pm
It's a horrible noise . could liken it to a combination of strangling a turkey and loud purring cat
14 Re: new clutch noises on 11th January 2014, 7:28 pm
Im voting for a video  Wink
15 Re: new clutch noises on 12th January 2014, 1:51 am
i thought it sounded a bit like a sneezing elephant
16 Re: new clutch noises on 12th January 2014, 3:23 am
Ive read about this somewhere before... & it pointed to a slightly warped flywheel, as your on the biting point the clutch is not fully making contact on the flywheel so causing exess slip on a certain point on the clutch & flywhell... But when clutch fully engaged it meets up to the flywheel as it should so sound go's away... Hence the wering noise.
I could be wrong tho? Just what ive read in the past on an old thread on another forum.
17 Re: new clutch noises on 12th January 2014, 10:35 am
Mine has a brand new fidanza flywheel
18 Re: new clutch noises on 12th January 2014, 11:11 am
Digi, are you running standard flywheel? Did you get the flywheel skimmed when you fitted the new clutch?
19 Re: new clutch noises on 12th January 2014, 2:33 pm
mines a helix organic with skimmed flywheel, but my noise sounds like the friction plate not lined up on the flywheel so sounds like a clatter :/
20 Re: new clutch noises on 13th January 2014, 11:05 am
thanks for the reply guys think i f'd it up by not skimming the flywheel so i guess its the glaze on the flywheel or what gaz says a warped flywheel, guess its replace everything time again...
