Gtir Motorsport club » Tech room » Help and Advice » Hks boost controller install
1 Hks boost controller install on 11th January 2014, 8:07 pm
Scooby_killer
Hi guys going to be installing my hks evc 3 boost controller but I don't no where in one the vacuum pipes connect coming off from the boost solenoid could some body please tell me where I need to connect this pipe
Here is a picture below
There are two 6mm ports and one 4mm port coming off the boost solenoid the left hand port 4mm goes to the inlet plenum the center 6mm port goes to the wastegate actuator and I don't no we're the other 6mm port connect to? It say to connect to the compressor housing outlet pipe but only standard turbo I've got nowhere to to connect it to is there somewhere else I can connect this 6mm hose to
Thank guys
2 Re: Hks boost controller install on 11th January 2014, 10:04 pm
I could only dig up the same info as you mate .... from what i read port 2 should be put into the intercooler pipe .... or am i reading it wrong ?
3 Re: Hks boost controller install on 11th January 2014, 10:32 pm
Scooby_killer
Nomad your reading it right in the diagram it shows going to the intercooler pipe but I don't have any 6mm nipples on my intercooler pipe work to attach it to that's why am trying to see if I could connect it  to some thing else where no mods are required
If I don't an alternative I will problerly drill a 6mm hole in the intercooler pipe and attach a nipple for the vacuum hose to attach it to
4 Re: Hks boost controller install on 11th January 2014, 10:42 pm
I would think that will be your only option to be honest i cant see where else you can put it ....
