Gtir Motorsport club » Tech room » Help and Advice » Cant seem to get the car to idle
1 Cant seem to get the car to idle on 20th January 2014, 11:32 am
Gl3nnGTIR
Hi
I am having problems getting my car to idle, once power applied its fine, also when very lightly touch throttle has slight misfire. can anyone think of anything? I have looked at vacum hoses all seem ok?
Thanak Glenn
2 Re: Cant seem to get the car to idle on 20th January 2014, 11:43 am
maybe your dump valve has a leak, block it off and see if it makes a different
3 Re: Cant seem to get the car to idle on 20th January 2014, 11:45 am
gtirx2
How many bends are in your inlet pipe?
I read that you was using 60degree bends but dont know if your running 1 or 2 bends?
Just guessing really but have read the z32 maf can be abit sensitive to this and show problems with the idle?
4 Re: Cant seem to get the car to idle on 20th January 2014, 8:47 pm
Gl3nnGTIR
Thanks for quick response this morning i had far bigger issues in the afternoon which are now sorted Smile i managed to get to run ok i found a vacum off rocker cover split. Sealed it and idles low but it idles so hopefully off to rollers on thursday and see how its fueling etc
5 Re: Cant seem to get the car to idle on 20th January 2014, 8:56 pm
GTIR James
Glad you got it sorted Glenn. Did sound like a vac pipe. Get yourself a wideband, one of the best gauges for diagnosing faults. If its idles low. Try adjusting the Iacv screw out a tad.
6 Re: Cant seem to get the car to idle on 21st January 2014, 7:21 pm
How much will it cost to have the fueling checked as that's my next thing to do after I fit the wideband Santa got me
