Gtir Motorsport club » Tech room » Ecu related section » Nissan consult & nistune softwhare?
1Nissan consult & nistune softwhare? Empty Nissan consult & nistune softwhare? on 22nd January 2014, 10:21 pm
Ok after reading Daves thread about ECU's I was thinking about getting a consult cable & nistune softwhare so I can datalog my nistune ecu etc.
Now what do I need exactly? is it just a consult cable & Nistune softwhere I need? & how much am I looking at for the nistune program?
Is this consult cable right?
http://www.ebay.co.uk/itm/Diagnostic-Interface-14-pin-RS232-Cable-Consult-Port-for-Nissan-vehicles-Seat-/261310267546?pt=UK_Diagnostic_Tools_Equipment&hash=item3cd74e409a
Cant find nistune softwhare?
2Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 22nd January 2014, 10:38 pm
Thats it gaz .... you can download the nistune software as a 180 day trial thing when it runs out just download it again  Wink
3Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 22nd January 2014, 10:42 pm
http://www.nistune.com/support-downloads.php
on this page fella  Wink
4Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 22nd January 2014, 10:46 pm
Ahh sweet, so which parts do I download? lol & is that consult cable ok?
5Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 22nd January 2014, 11:09 pm
I would think its the 1.1 exe   as the others say obd2 support  ... and yes mate cable looks ok ... you could just buy the cable it will be cheaper  its only the driver for the cable and i would of thought nistune software will have the driver in that .
6Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 22nd January 2014, 11:16 pm
Ok cool thanks, ill put it on my mates laptop... Be abit awkward trying to carry a pc out to the car lol
7Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 22nd January 2014, 11:25 pm
Either that or make sure it a fooking long cable  Laughing
8Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 23rd January 2014, 12:41 am
gtirx2
gtirx2
I think you only get 3-4 10min trials before you have to re download it to reset it so don't waste them lol
9Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 23rd January 2014, 12:58 am
Ahh realy? im going to do some reading up on how to use it properly before hand. I don't want to change something by accident & risk blowing it up :/
10Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 23rd January 2014, 12:21 pm
watoga
watoga
ecu technician
ecu technician
In terms of data logging, you just need NIStune and the consult cable. The consult cables I have always used are these:
CONSULT CABLE
The good thing about them is they are directly USB compliant, whereas many other cables use an RS232 link which then needs to be converted to a USB output for easy plugging into a laptop (not too many modern laptops still have RS232 ports!). I've never had one fail and the drivers are easy to install. But feel free to go down any route that offers a cheap solution. I think most modern-day consult cables should be fine, just remember to buy an RS232-USB adapter if you need one.
If you want to physically make changes to the ECU, then you'll need to splash out on a NIStune daughterboard (which needs soldered into the main GTiR ECU) and a NIStune licence. A single-user licence is good for tuning as many GTiRs as you like, but you'll not be able to tune other Nissans should you move on to new pastures. The good thing about the single-user licence is it's a LOT cheaper than the tuner's licence..................... Sometimes you see GTiR ECUs that already have a NIStune board installed come up for sale (either here or on eBay), and these would be your cheapest way of getting a ready-to-map NIStune ECU. Failing that, I get discount on NIStune boards, cables, and licences direct from NIStune so if you decide to go down that route give me a shout first and I'll see how much discount I can get you.
The NIStune forums are a very good way of learning how to tune safely and efficiently.
Let me know if you need any help.
Cheers,
Dave
11Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 23rd January 2014, 1:19 pm
Cheers for the info Dave Smile ive alrady got a nistune daughter bourd in my ecu, mapped by ed at fusion.
Just going to learn abit more about data logging & get myself a consult cable Smile
12Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 24th January 2014, 9:40 am
watoga
watoga
ecu technician
ecu technician
I'm not sure what laptop you're going to use, but it is normally possible to tweak the settings so the laptop doesn't go to sleep when you close the lid. I set mine to stay awake even with the lid closed, which means you can strap the closed laptop into the car somewhere and drive like a maniac, with NIStune all-the-time recording your parameters. This is particularly good for track days.
Good luck and let me know if you need anything.
Cheers,
Dave
13Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 24th January 2014, 1:14 pm
Cheers for the info Dave Smile it will be in the next few months I get it, as got gearbox to sort yet before its back on the road.
But will let you know if I need help, which I probably will...  Laughing
14Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 24th January 2014, 2:09 pm
groundscraper
Nothing against nistune, i actually negociating used one right now, it covers my needs... but of you don´t have a nistune yet you might consider Nismotronic, SA, pretty similar, more features, more tuner friendly, MAP sensor possibility, etc...
Just another option to consider...
15Nissan consult & nistune softwhare? Empty Re: Nissan consult & nistune softwhare? on 24th January 2014, 3:11 pm
Ive alredy got nistune matey
