Gtir Motorsport club » Tech room » Help and Advice » Radiator
Radiator
1 Radiator on 26th January 2014, 5:37 pm
Size of the rad inet or outlet take it there the same size ? Or inside diamiter of pipe. I am fitting aftermarket gauge need the alloy insert with adaptor for sensor that fits in  the pipe
Please ?
2 Re: Radiator on 26th January 2014, 5:50 pm
34.60mm or 1.361inches thats what my aftermarket rad hoses inner diameter is ...
3 Re: Radiator on 26th January 2014, 5:58 pm
What make is that mate ?
4 Re: Radiator on 26th January 2014, 6:42 pm
Cant remember mate tbh they are only cheapy ones but inside diameter cant be that far out ....
5 Re: Radiator on 26th January 2014, 6:53 pm
True So if i get 34mm adaptor it should be fine seem to do 32 34 36 38
6 Re: Radiator on 26th January 2014, 6:55 pm
GTIR James
Mine was 36mm mate. Don't want a baggy fit
7 Re: Radiator on 26th January 2014, 6:59 pm
Nice one shit i was thinking backwards i want the pipes to strech over not the other way thanks
Cheers leighton aswell sure i spell your name wrong everytime lol
Sure you have been called worse tho
8 Re: Radiator on 26th January 2014, 7:35 pm
GTIR James
If you fitting a sensor for a temp gauge rather than butchering a coolant hose remove alli connector from block drill & tap a hole & fit sensor with sealant. Looks much nicer. I will post some pics in a bit
9 Re: Radiator on 26th January 2014, 7:41 pm
GTIR James
You can just about see what I'm talking about here. (Just below intercooler pipe on upper coolant hose)
10 Re: Radiator on 26th January 2014, 7:43 pm
GTIR James
11 Re: Radiator on 26th January 2014, 8:12 pm
Thanks pictures are spot on dose look good will probably do that thanks and its a good place to take a reading i take it ?
