Gtir Motorsport club » Tech room » Help and Advice » Runnig rich
Runnig rich
1 Runnig rich on 5th February 2014, 6:28 pm
I had an old topic about this but cant find it?
Anyway I had a problem where I was running realy rich on my wideband... 10.9 on idle & 11.4 - 12.5 off boost & 10.9 on boost @WOT. But now ive put a RA gearbox on instead of the RB it seems to be a little more rich? Maybe cos revs arnt as high & gear ratios are longer?
Where idealy I should be around 14.5 on idle & 14s - 16s off boost & 11.5 - 12.4 on boost @WOT
So for some reason im running masivley rich right threw the rev range? Ive spoke to Ed at fusion a while back & he reckons fuel preasure is to high? But now ive thought about it im only running standard FPR.
So has anyone got any ideas what it could be? The car was mapped 3 years ago by Ed & the fueling graph is perfect & where it should be. So something else has to be causing this?
2 Re: Runnig rich on 5th February 2014, 6:34 pm
vacuum leak
boost leak
dodgy injectors
in-correct ignition timing
should really be around 16 at idle as you don't need much fuel
light partial load should also be around stoich
as boost starts should then linearly drop to around 11s or high 10s on full boost
3 Re: Runnig rich on 5th February 2014, 7:01 pm
Checked vac lines & cant see any leaks. Ive got good vacuem according to my AVCR -350
Checked all boost pipes when I did gearbox at weekend, But suppose there could be a leak at inlet but car runs fine?
Timing is at 20 degrees
I had injectoers cleaned & tested a few years back but maybe they could of broken down? Ill get them tested again.
4 Re: Runnig rich on 5th February 2014, 7:10 pm
Afm? It's been standing for a while so could have damp in it? Or corrosion?
5 Re: Runnig rich on 5th February 2014, 7:12 pm
Yeh but it was like it before I blew the box? Could re'earthing it help?
6 Re: Runnig rich on 6th February 2014, 2:05 pm
could possibly be the maf but somehow I very much doubt it as youll have problems with hesitation and stuttering as car comes on to boost.
wont hurt to splice into the earth though and run another wire to a good ground on the body
other things to check are the ecu temp sensor, inlet air control valve if your 100% positive everything else is as it should be
7 Re: Runnig rich on 6th February 2014, 3:12 pm
Ok, sorry for sounding thick but where abouts is the ECU temp senser & inlet air control valve positioned?
8 Re: Runnig rich on 6th February 2014, 3:34 pm
ecu temp sensor is the one on back of throttle bodies near brake master cylinder
iacc valve is right at the back of throttle bodies near the vacuum chamber pot
9 Re: Runnig rich on 6th February 2014, 3:55 pm
Cheers Bob, ill take a look
10 Re: Runnig rich on 23rd July 2014, 10:34 pm
grim_d
Sorry to dig up and old thread but did you sort this out gaz? Might shed some light on my rich running.
