Gtir Motorsport club » Tech room » Help and Advice » Oils and fluids?
Oils and fluids?
1 Oils and fluids? on 6th February 2014, 2:59 pm
Hardy172cup
I need some advise on what to use in my R  scratch
I'm going to change the coolant because I have no idea whats in it and I've topped it up with some stuff from halfords but since then I have read you shouldn't mix different coolants.
What coolant should I use?
Does it even matter along as I don't mix different ones together?
And how much will u need to fill the R?
I'm also going to change the gearbox, transfer box and diff oils for peace of mind.
What oils should I use for these?
how much will I need to fill each one?
Also I need some power steering fluid, what should I top that up with?
2 Re: Oils and fluids? on 6th February 2014, 3:04 pm
antifreeze was the blue one bill cant remember what its called lol
gearbox oil holds around 4.5ltr
transfer about 1.5ltr
rear diff around 1.5ltr
all from empty
use 75w/90 semi synthetic in all the above
power steering fluid is same as universal auto gearbox oil, the red stuff
3 Re: Oils and fluids? on 6th February 2014, 3:09 pm
Hardy172cup
Cheers bob, any reason you say semi-synthetic for the gear oils? Would fully synthetic be a more expensive but better option or should I just stick with semi?
I'm sure I've got some of that red auto box oil in the garrage somewhere so that saves a few quid Smile lol
4 Re: Oils and fluids? on 6th February 2014, 3:32 pm
we always have used semi synthetic never really had a problem with it and cant see the point in running expensive oil in an old worn box as it wont make a scrap of difference or make it last any longer
bit like all the additives you see everywhere, none of them really do anything other than make a bigger hole in your pockets lol
