Gtir Motorsport club » Tech room » Help and Advice » Removing the gearbox, Is it easier to lift the engine slightly or better to leave in the mounts as is ?
mikewazowski
Hi guys, im slowly starting to plan my clutch fork replacement mission and im just wondering if its easier to shift the engine abit and lift it up slightly or is it better to just leave it in the mounts? I wouldnt want to remove the engine entirely but just undo the mounts and lift it up etc.
thanks
why would you want to lift it up?
the gearbox comes out through the bottom of the car so if anything you need to drop it slightly if doing it with engine in situ
GTIR James
Agree. Put a axle stand or jack under the Ali sump & drop gearbox side slightly. Have fun if your doing it on the floor.......
here you go fella, heres a how to for you just click the link below
http://www.gtir-motorsport-club.com/t1645-change-clutch-how-to
mikewazowski
Thanks guys, well i can get access to a engine crane and i heard that there are some bastard bolts to undo etc so i thought maybe shifting the engine abit to get more access would help Smile
Yeah its going to be pretty fun just doing it on my driveway, been waiting for some decent weather to come but i guess its going to be a while still ;//
ditch the crane you don't need it
all you need is a couple of descent trolley jacks, axle stands and a lump of wood around 4ft long bit of 3x3 or similar will be fine to span behind front arb points
GTIR James
Waiting for the weather. Blimey, your be lucky. The bastard bolts aren't that bad to get out.
mikewazowski
thanks guys! really big help, ill post a thread when i get to swapping the clutch fork on my R Smile
bastard bolts are easier with 2 people, use a spanner on the bolt, someone underneath the car with another spanner hooked on to it providing pressure, then just give it a few hits from topside and the bolts will come loose
