Gtir Motorsport club » Tech room » Help and Advice » Bloody brakes!
Bloody brakes!
1 Bloody brakes! on 25th February 2014, 10:07 pm
Right guys need some serious help!
My brakes on my R have always been crap, Basicly I can stamp on the brakes to do an emergency stop & it just gradualy stops like your slowing down for a set of traffic lights, It wont lock up! Theres just no bight?
Its been like this for the 4 years ive owned the car & never managed to sort it no matter what I do or change? Ive tried 2 mastercylenders & a different servo & must of bled them atleast 70 times... Still never any better  Evil or Very Mad
If I hit the pedal once it dousnt sink to the floor, BUT will go down further than if I let go & hit the pedal a 2nd or 3rd time... Its like it pumps itself up the 2nd / 3rd time I pump it to slow down...
BUT if I press it to hard the pedal feels solid like I hits a stop half way down & wont go any further??? That's the scary part, feels like the pedal hits a brick wall & cant push threw it?
Its like a preasure issue? even tho ive changed mastercylender & servo... Still the same?
Could this be a proportion valve issue? Even tho im getting good flow thew all calipers when bleeding?
I need to sort this now as its been 4 years ive put up with it & had to do an emergency stop the other night & luckily managed to swerve the car infront & ended up sitting next to him on the wron side of the road  Mad
2 Re: Bloody brakes! on 25th February 2014, 10:14 pm
have you tried changing the pipe from servo to plenum?
I doubt it will be the proportioning valve
3 Re: Bloody brakes! on 25th February 2014, 10:15 pm
Yeh the 1 way valve pape? changed that aswel mate :/
I have got the fuse out of the abs as I hate abs. But I hear a lot of people do this so I don't think that would be the issue?
4 Re: Bloody brakes! on 25th February 2014, 10:29 pm
no that wont be the prob
really cant think of anything else gaz other than servo and master which you've changed
I would have said try a different set of brakes but if it was doing the same thing before it cant be those either
only other possibility is a kinked or blocked brake line somewhere.
what ever it is its no doubt a problem mainly on the front brakes so considering its already had 3 different servos and masters I guess the only thing left is the proportioning valve, perhaps its restricting the flow to front but unusual as they are diagonally proportioned
5 Re: Bloody brakes! on 25th February 2014, 10:35 pm
Im getting a good flow of fluid to each caliper when bleeding so that rules out a kinked pipe i reckon?
The car dousnt pull under braikingm its perfectly strait, But just no bight & strange how pedel hits a stop halfway down?
Could it be a fault with the ABS pump, even tho its not working coz fuse is out, fluid still has to run threw it so wonder if that's the fault?
6 Re: Bloody brakes! on 25th February 2014, 10:43 pm
GTIR James
Try bleeding to abs pump ie crack the pipes at the pump then bleed to calipers. Any chance you could get it on a brake rollers so you can see brake readings etc.
7 Re: Bloody brakes! on 25th February 2014, 10:58 pm
Ill try it james. Do i crack them off on the abs pump then pump the pedal & lock them off when fluid comes out & the re bleed the callipers as normal?
8 Re: Bloody brakes! on 25th February 2014, 11:00 pm
What calipers disk n pads you currently running ?
9 Re: Bloody brakes! on 25th February 2014, 11:06 pm
Wilwood calipers & 285mm discs, unsure on pads, but pads wouldn't cause a stop on the pedal like theres a preasure issue?
10 Re: Bloody brakes! on 25th February 2014, 11:09 pm
GTIR James
@Gaz GTiR wrote:Ill try it james. Do i crack them off on the abs pump then pump the pedal & lock them off when fluid comes out & the re bleed the callipers as normal?
That's it gaz crack them, pump pedal.
Had this ages ago on a nissan cabster. Shocking brake pedal & air was stuck in the abs pump. Some manufactures even say to activate abs when bleeding......
11 Re: Bloody brakes! on 25th February 2014, 11:17 pm
Ok cheers James Smile
Crack them 1 by 1 & start at the pipe that leads to furthest caliper & work my way in?
12 Re: Bloody brakes! on 25th February 2014, 11:29 pm
Cant you just loop it and take the pump out altogether if you think it maybe suspect and your not using it anyway ?
13 Re: Bloody brakes! on 25th February 2014, 11:32 pm
gtirnick
probably not the solution you're looking for, but i had a similar problem with the factory brake setup.
i switched to 4pot wilwoods and 280mm discs and it improved considerably but i still had abs a very long pedal and the car felt like it wouldnt stop once abs kicked in.
i would bleed the brakes often and the pedal would still remain long.
i ended up removing abs completely (kept the abs prop valve) and adjusted my brake lines to suit as well i switched up to a 1inch master from an altima. my pedal is now firm, short, and lock up is easy to induce when i want it too.
14 Re: Bloody brakes! on 26th February 2014, 12:15 am
Yep got to be something to do with abs pump... I may do that Leighton/nick, ill need to change the prop valve for a none abs one. How hard is it to get to? i heard its a inlet of job?
15 Re: Bloody brakes! on 26th February 2014, 1:14 am
gtirnick
this is basically what i did
http://s131.photobucket.com/user/Trip_gtir/media/absMod.jpg.html
sorry for posting a link to the other site
http://www.gtiroc.com/forums/showthread.php?61165-Why-to-remove-ABS/page2&highlight=abs+removal
16 Re: Bloody brakes! on 26th February 2014, 1:39 am
Cheers nick, is that photobucket link actulay a GTiR diagram? so id need to plumb it all the same as the pic?
17 Re: Bloody brakes! on 26th February 2014, 12:19 pm
Scooby_killer
I have the same problem as you gaz I've changed the master cylinder, de glazed all discs and pads and still giot the same problem as you shit brakes
18 Re: Bloody brakes! on 26th February 2014, 12:53 pm
Not just me then, Im going to try bleed abs pump at weekend so ill let you know. If you solve the problem let me know lol
19 Re: Bloody brakes! on 26th February 2014, 5:04 pm
gtirnick
i followed it as reference, but i just followed the lines from the master to actuator to prop valve and just traced the lines that way.
