Gtir Motorsport club » Tech room » Help and Advice » Gear change bushes
Gear change bushes
1 Gear change bushes on 2nd March 2014, 9:26 pm
Has anyone tried the nylon type bushes off ebay that apparently tighten up the gear stick slop and aid gear changes cos I miss 3 rd gear a lot when giving it some so thought these might help???
2 Re: Gear change bushes on 2nd March 2014, 11:44 pm
I think fred installed these not long ago .... il see if i can dig the thread up mate ..
3 Re: Gear change bushes on 2nd March 2014, 11:59 pm
i bought some got same problem, but not got round to fitting yet as its too cold  Shocked
4 Re: Gear change bushes on 3rd March 2014, 8:37 am
fred05
french connection
french connection
i bought some red type bushes to change the bush wich is just between gearbox and rods...i opened a thread about that, and i explained all, location and so on...
i'll try to dig it out.
5 Re: Gear change bushes on 3rd March 2014, 8:39 am
fred05
french connection
french connection
6 Re: Gear change bushes on 3rd March 2014, 10:15 pm
Just read the thread but I'm no wiser as to if you thought it worked or not and how hard was the fitting??
7 Re: Gear change bushes on 3rd March 2014, 10:18 pm
GTIR James
Gear selector bush only really needs replacing if it has excessive play.
The gear stabiliser bush is normally the one to wear causing movement in the linkage
8 Re: Gear change bushes on 3rd March 2014, 10:40 pm
Are these available James and are they an easy fit?
9 Re: Gear change bushes on 3rd March 2014, 10:43 pm
GTIR James
They are available mate. Haven't seen them in the uk but you can get them off eBay.
Easy to fit its two rubber bushes with a insert that push together
10 Re: Gear change bushes on 3rd March 2014, 10:47 pm
Think this is the original item I was talking about
11 Re: Gear change bushes on 3rd March 2014, 10:52 pm
131129054666 this is the item I mean on ebay. Sorry I don't know how to make a link from ebay to here on my ipad
12 Re: Gear change bushes on 3rd March 2014, 11:51 pm
Would that be the same bush in auction items at the minute ?
13 Re: Gear change bushes on 4th March 2014, 8:39 am
fred05
french connection
french connection
yep, that's the one i bought and fit.
it's quite easy to fit, you just have to jack the car up, go under and undo the bolt, change the bush, and re tighten all.
feeling is much better.
you can change the rear bush too by making your own solid bushes, i didn't get the time to make one for me at the moment...
you can go for it, it's better for us.
