Gtir Motorsport club » Tech room » Help and Advice » Help needed on manifold Bolt
Go to page : 1, 2, 3  Next
1 Help needed on manifold Bolt on 1st April 2014, 8:08 pm
Turbazz
Managed to remove all the bolts on the manifold apart from one. Counting from the right towards the left its number four!
Should I use any specific tools?
2 Re: Help needed on manifold Bolt on 1st April 2014, 8:36 pm
I cut a spanner in half
3 Re: Help needed on manifold Bolt on 1st April 2014, 9:38 pm
If you have no ac pump fitted you can get a ring spanner on from the underside
Then if you use a lever bar such as an old screwdriver you can use that to lever the spanner through the gap in the top until it's loose enough to undo by hand with the spanner
4 Re: Help needed on manifold Bolt on 1st April 2014, 10:04 pm
Turbazz
I have a/c lol. Friend mentioned a socket to me which pivots on a ball he is going to bring it around tomorrow to try.. Anybody know what he's on about?
5 Re: Help needed on manifold Bolt on 2nd April 2014, 9:47 am
Sounds like a knuckle socket ???
6 Re: Help needed on manifold Bolt on 2nd April 2014, 10:28 am
Turbazz
He just sent me a picture of it he is bringing it round later how do I upload pictures on here
7 Re: Help needed on manifold Bolt on 2nd April 2014, 10:40 am
Turbazz
http://www.ebay.co.uk/itm/Genius-1-4-dr-Universal-Joint-Imperial-Socket-Set-Premium-Quality-Product-Offer-/330710798851
Like this but six sided
8 Re: Help needed on manifold Bolt on 2nd April 2014, 11:27 am
Thats its mate its a knuckle joint socket .... if you want to upload pictures use something like photobucket ...
9 Re: Help needed on manifold Bolt on 2nd April 2014, 11:33 am
Turbazz
Do you reckon it would work? Going to try it tonight..
I tried one of these sockets yesterday. The difference in this one is you don't have to add the socket on at the end. It comes on the joint. If that makes sense. So I am saving length
10 Re: Help needed on manifold Bolt on 2nd April 2014, 12:10 pm
Trouble with them ive found is trying to keep the socket on straight without twisting it off while trying to undo it if that makes sense .... hopefully you find that being case fella.
11 Re: Help needed on manifold Bolt on 2nd April 2014, 12:36 pm
yeahthats the trouble with them. whatever you do don't round that nut off or youll have a nightmare job on your hands  Wink
12 Re: Help needed on manifold Bolt on 2nd April 2014, 1:14 pm
If like the link, they are generally not that useful, walldrive ones on compact wabble joint rather than the pinned UJ are little better but as stated already if slips & rounds head off badly you got an even trickier job.
13 Re: Help needed on manifold Bolt on 2nd April 2014, 8:37 pm
watoga
ecu technician
ecu technician
Is it possible to leave the dreaded "bastard bolt" off when refitting? Or is it 100% required for a proper seal?
Cheers,
Dave
14 Re: Help needed on manifold Bolt on 2nd April 2014, 8:56 pm
Turbazz
Its off!!!! But I have another problem it snapped off. manifold came off the ,stud left inside. Now I need to remove it Sad any ideas.
15 Re: Help needed on manifold Bolt on 2nd April 2014, 9:04 pm
How much if any of the stud is poking out of the head ?
16 Re: Help needed on manifold Bolt on 2nd April 2014, 9:05 pm
Have you got a pic .... as there is a few ways depending on what your faced with ???
17 Re: Help needed on manifold Bolt on 2nd April 2014, 9:17 pm
Turbazz
No I haven't got a picture unfortunately.
That socket was working absolutely fine it decided to snap due to un even pressure maybe.
Anyways the stud is sticking over an inch out.. The bolt is completely off..
Where do I get a new one from Nissan?
18 Re: Help needed on manifold Bolt on 2nd April 2014, 9:21 pm
You don't need to put that one back with a cast manifold as the one sitting next to it is enough to draw it in tight. Plus if you ever have to take it off again it makes the job much easier.
Make sure you use a new gasket though
19 Re: Help needed on manifold Bolt on 2nd April 2014, 9:27 pm
Turbazz
Oh really.. It wouldnt leak at all?
Very Happy good to know I have a cast manifold
Yes I have a new gasket.
Anyways bob i've got to the actuator now!! I looked in the Turbo for cracks and if there was any play.
Penny all looks fine..
Now I just need to connect a decent pump to the actuator. I did connect a foot pump. The rod was moving fine is hard to tell what pressure it's opening.
Should it start to open at 0.4 then be fully extended at 0 .7?
20 Re: Help needed on manifold Bolt on 2nd April 2014, 9:31 pm
Think it's 0.6 standard opening pressure but I could be wrong there so best to check.
Is the turbo spinning freely?
21 Re: Help needed on manifold Bolt on 2nd April 2014, 9:34 pm
Turbazz
So the rod shouldn't move before 0 .6?
Seems slightly tight don't know if that's normal..
22 Re: Help needed on manifold Bolt on 2nd April 2014, 9:39 pm
It should spin with just minor resistance if journal bearing tubby, if it's tight that could be the problem
23 Re: Help needed on manifold Bolt on 2nd April 2014, 10:11 pm
Turbazz
I don't know how to measure the tightness  Question Question
Tight to me maybe normal to you lol.
I'll play around with it more tomorrow ran out of time tonight.
Thanks for the replies though!
24 Re: Help needed on manifold Bolt on 2nd April 2014, 10:43 pm
If you ever decide to remove the broken stud best way i found is weld a nut on top of it then it will budge ..... standard actuator opens at 0.5 i thought ???
25 Re: Help needed on manifold Bolt on 2nd April 2014, 11:09 pm
Turbazz
My mate has this wrench which grips anything super wrench its called.
Probably heat it up a bit,then go for it. Not bothered if it gets chewed up. Because I don't need it again...
