Gtir Motorsport club » Tech room » Help and Advice » Help needed on manifold Bolt
26 Re: Help needed on manifold Bolt on 3rd April 2014, 10:19 am
yeah your right Leighton its .5
thing is you say you pulled the actuator pipe off and it still only hit .3 boost which rules your actuator out the equasion unless the wastegate penny was flapping open and maybe the actuator arm had come off the peg (rotten e clip)
that kind of narrows it down to turbo not spooling as it should assuming theres no big cracks around the wastegate penny!
so if I were you I would get it checked out if your not sure on the impellor being too tight
27 Re: Help needed on manifold Bolt on 3rd April 2014, 10:55 am
Turbazz
Is hitting 0.378. With the pipe pulled off or on. I assumed it may be a soft spring in the actuator.
The e clip and the rod were secure.
Regards to the turbo I do not know how to check it out.
I checked for cracks though was fine
Also checked for movement and play seems solid.but seems tight when spining not sure?
Going to recheck all the vacuum hoses for splits or cracks. Remove the dump valve try it on another car
Also I'm going to test the actuator with a pump again
Argh pain lol
28 Re: Help needed on manifold Bolt on 3rd April 2014, 11:02 am
its 100% not the actuator that's causing the prob otherwise with pipe disconnected it would have run unlimited boost even if it was weak, it simply cant operate with pipe dis-connected
the only other thing other than turbo is a huge boost leak somewhere
you should have checked / removed the dump valve to try before removing the turbo then if that was ok and all boost pipes secure then has to be the tubby causing the problem
29 Re: Help needed on manifold Bolt on 3rd April 2014, 11:08 am
Turbazz
Yes i only did a quick visual check Sad
But my friend said that a huge boost leak we would have heard it straight away !
If It was the dump valve or any vacuum
And on that basis we cracked on lol
Do you know the pipe going to the actuator in a standard car where would it go the other end. Currently It's going to the EBC solenoid
30 Re: Help needed on manifold Bolt on 3rd April 2014, 12:10 pm
yeah will go to ebc solenoid then other side will go to one of the vacuum ports on plenum
31 Re: Help needed on manifold Bolt on 3rd April 2014, 12:21 pm
Do you have a fmic ?
32 Re: Help needed on manifold Bolt on 3rd April 2014, 1:10 pm
Turbazz
Yes I understand that going to the solenoid is correct but where would it go if it was standard...the hose going to the actuator the other end where does it connect?
33 Re: Help needed on manifold Bolt on 3rd April 2014, 1:11 pm
Turbazz
No I have the original top mount
34 Re: Help needed on manifold Bolt on 3rd April 2014, 2:11 pm
To the plenum mate well just under it .....
35 Re: Help needed on manifold Bolt on 3rd April 2014, 2:13 pm
36 Re: Help needed on manifold Bolt on 3rd April 2014, 9:25 pm
Turbazz
Those diagrams you sent of the vacuum mate.. Slightly confused I think one of my pipes still goes through that restrictor to the dump valve I believe..
And that solenoid is still connected to the. InTake pipe but. The other end is not connected to the actuator, think goes back up towards the plenum not sure.
I think I need to take some pictures. And upload them
37 Re: Help needed on manifold Bolt on 3rd April 2014, 9:33 pm
Yep I think you do lol
It all sounds a bit of a mess to me  Laughing
38 Re: Help needed on manifold Bolt on 3rd April 2014, 10:11 pm
Turbazz
Should there be any hose going to the restrictor pipe?
39 Re: Help needed on manifold Bolt on 3rd April 2014, 11:02 pm
I think take a few pics mate and upload them that way we can see ..... if you want me to upload them for you you can send them to me via whats app or email .... drop me a pm for my number for whatsapp or my email is nomadhardiman@googlemail.com
40 Re: Help needed on manifold Bolt on 3rd April 2014, 11:20 pm
Turbazz
Will do cheers Smile
41 Re: Help needed on manifold Bolt on 4th April 2014, 8:59 am
Pm sent fella .
42 Re: Help needed on manifold Bolt on 4th April 2014, 5:40 pm
URL=http://s695.photobucket.com/user/nomad29_bucket/media/Mobile%20Uploads/IMG-20140404-WA0004.jpg.html][/URL]
43 Re: Help needed on manifold Bolt on 4th April 2014, 5:41 pm
44 Re: Help needed on manifold Bolt on 4th April 2014, 5:42 pm
45 Re: Help needed on manifold Bolt on 4th April 2014, 5:43 pm
46 Re: Help needed on manifold Bolt on 4th April 2014, 6:25 pm
Whats the pipe strapped under brace and is heading towards the headlight and not connected to anything ????
47 Re: Help needed on manifold Bolt on 4th April 2014, 6:31 pm
Turbazz
Solenoid strapped. Hose goin to actuator.
48 Re: Help needed on manifold Bolt on 4th April 2014, 7:04 pm
Spark plug spike
I can't understand why you have the standard solenoid still connected up and what looks like a manual Dawes device (strapped to the strut brace) connected as well ???
I would take the standard solenoid out then connect the Dawes device up on its own to see what happens then?
49 Re: Help needed on manifold Bolt on 4th April 2014, 7:15 pm
This is what i have suggested after talking to him..... remove standard boost soleniod  re do vac lines as according to hes mate previous owner has t pieced all over the place ...
50 Re: Help needed on manifold Bolt on 4th April 2014, 8:27 pm
Spark plug spike
Also the vac pipe from the FPR is T-pieced as well but can't see where it goes so that would concern me especially for running lean.
I also think the carbon canister needs to be removed to make it less cluttered as well.
You can't go wrong if you follow the diagrams that Leighton linked previously in this thread.
