Gtir Motorsport club » Tech room » Help and Advice » Dump Valve and vacuum hosing
1 Dump Valve and vacuum hosing on 6th April 2014, 1:31 pm
Turbazz
Finally got my car boosting more than 0.4 bar!!
After taking the turbo manifold and actuator off all the vacuum piping nearly!!
Following some of the diagrams given to me done the vacuum hoses best to my knowledge.
Just few questions!
How do I put the dump valve in propley??
Are there any images? AlSo how does the stock circulating one plumb in just curious?
Anyone has images of both Smile so I can get a good idea
Another thing what should my boost gauge show at idle speed minus..how much
Last question on the intake I have a hole after removing the standard solenoid ?
Leighton when you read this can you post a picture of my dump valve currently. Thank you!
2 Re: Dump Valve and vacuum hosing on 6th April 2014, 1:56 pm
3 Re: Dump Valve and vacuum hosing on 6th April 2014, 1:56 pm
4 Re: Dump Valve and vacuum hosing on 6th April 2014, 1:57 pm
5 Re: Dump Valve and vacuum hosing on 6th April 2014, 1:59 pm
this was proir to sorting out ...
6 Re: Dump Valve and vacuum hosing on 6th April 2014, 2:01 pm
Where the dump valve (large pipe ) is connected to the plenum looks correct to me .....
7 Re: Dump Valve and vacuum hosing on 6th April 2014, 2:22 pm
Turbazz
Ripped everything out.  everything back in order acording to the diagram
Just dv left.
1st picture shows how it is now blocked off
Last picture shows how it used to be
3rd picture shows the intercooler pipe.  is another pipe underneath. Is that the right one
Look at the last picture  has two vacumns. Should both be connected? How?
8 Re: Dump Valve and vacuum hosing on 6th April 2014, 4:29 pm
What is the dump valve mate ? Il see if i can find some info on it ...
9 Re: Dump Valve and vacuum hosing on 6th April 2014, 4:33 pm
Turbazz
Not sure what it's called thinking might be hks sheepdog
10 Re: Dump Valve and vacuum hosing on 6th April 2014, 4:41 pm
Ok so just found a few pics of them .... its a hks super bov ..... both ports on the dv go on the same vac line mate ....
11 Re: Dump Valve and vacuum hosing on 6th April 2014, 5:00 pm
Turbazz
Teed off one ok. That's how it was before Neutral
12 Re: Dump Valve and vacuum hosing on 6th April 2014, 9:09 pm
hows it now boosting was it piped wrong or standard solenoid ?
13 Re: Dump Valve and vacuum hosing on 6th April 2014, 9:47 pm
I was piped up shit johhny loads of t pieces etc ..... turned out to be a split pipe under the dash ....
14 Re: Dump Valve and vacuum hosing on 6th April 2014, 10:56 pm
Turbazz
Yeah loads of unnecessary piping. Sorted it out and a split hose could not see the hose because it went in the dash.
15 Re: Dump Valve and vacuum hosing on 7th April 2014, 12:29 pm
mikewazowski
dv comes out from the intake and get vacuum from the intake as well, unless you want to do the quad dv vacuum conversion Smile
16 Re: Dump Valve and vacuum hosing on 7th April 2014, 1:03 pm
I heard some mixed reviews on that method mike ....
17 Re: Dump Valve and vacuum hosing on 7th April 2014, 1:21 pm
mikewazowski
yeah and me, i was meant to do it on mine but i decided to stick with a one vacuum line. I guess it would do no harm but i also heard that it doesnt really do much difference so i decided not to install it Smile
18 Re: Dump Valve and vacuum hosing on 7th April 2014, 5:01 pm
Hardy172cup
I tried the 4 to 1 mod with my bov and it did seem to blow off easier.
The only advantage I could see was with an adjustable bov you can adjust it tighter and probably get better bov response but other than that it didn't really do anything.
I hav since ripped out the quad bov mod because I was trying to eliminate any possible vac leaks I may have.
I also found it orkward to neatly connect up all the piping for the quad mod.
Tbh it's probably more hassle than its worth because the gains are negligible. I might connect it up that way again in the future but I'm not sure if I will or not
19 Re: Dump Valve and vacuum hosing on 8th April 2014, 7:47 pm
Turbazz
4to1 mod i wont even ask and confused as it is..
If i wanted to block dump valve off.. Is it a matter of just putting a bung in that trunk and blocking the vacuum house going to it?
Is This is pretty safe to do? It does not cause no harm? Surely the stock recirculating valve has a purpose
20 Re: Dump Valve and vacuum hosing on 8th April 2014, 8:19 pm
Hardy172cup
Lol the 4 to 1 mod is were you connect the dump valve to all four throttle bodies via the vacuum ports that are usually blanked off, if you like I can try and find a link to it for you but I wouldn't bother about that now, I'd just concentrate on getting it all plumbed in correctly.
As for removing the blow off valve completely, I have heard its safe to do so but I have heard it can reduce the life span of a turbo but I have seen people claim they have run without one for many years with no adverse effects. If you don't use a dump valve you will get that turbo chatter noise you tend to hear on a lot of big powered cars and race cars etc.
I'm sure someone else could advise you on the pros and cons of not using a blow off valve because I'm only going on what I have read etc. I'm no expert on turbo cars or any cars for that matter lol
21 Re: Dump Valve and vacuum hosing on 8th April 2014, 9:45 pm
The idea of a dump valve is it stops the turbo from stalling as you go through the gears or let off ..... i think there is an arguement for either way as to regards prolonging the life of the turbo ....
22 Re: Dump Valve and vacuum hosing on 8th April 2014, 10:55 pm
Turbazz
What about blocking it off how do I do that properly..
23 Re: Dump Valve and vacuum hosing on 8th April 2014, 11:02 pm
Hardy172cup
You will need to find something to suitably block the hole on the plenum were the dump valve should go and also you need to block it up on the other side were it should recirculate back into the intake pipe and block off the vac pipe that should go to the dump valve
24 Re: Dump Valve and vacuum hosing on 9th April 2014, 7:51 am
I took a trip to the local plumbers merchant took both pipes with me .... iirc i used a 22mm cap for the intake .... and used a plastic bung fitting for the inlet cant remember what size that was though...
