Gtir Motorsport club » Tech room » 'detailers corner' » T-cut?
T-cut?
1 T-cut? on 7th April 2014, 10:20 pm
Turbazz
My bodywork is not too bad at all. But when you look closely you can see very fine scratches.
I have polished the car before and clay bar.
But somebody told me I need to cut the car back what do they mean by this? Does it take a layer off the paint..
Any advice or tips thank you
My car is black by the way
2 Re: T-cut? on 8th April 2014, 1:14 am
Ajay.
I would keep away from t cut that's basically like sandpaper you'll have even more scratches with that if not used correctly,and yes cutting back the paint does remove a very fine layer of the paint,idearly if there's fine scratches use a product called limeprime by dodo juice this can be applied by hand or a foam pad or even better use a machine polisher,hope that helps
3 Re: T-cut? on 8th April 2014, 9:21 am
Turbazz
Would This do a better job than tcut? Or is it just easier to use
4 Re: T-cut? on 8th April 2014, 11:20 am
Ajay.
Yep much better and easier to use especially with a polisher
5 Re: T-cut? on 8th April 2014, 12:14 pm
Would he not be better off using Poorboys SSR 2.5  ajay ?
6 Re: T-cut? on 8th April 2014, 12:47 pm
Ajay.
Poorboys is a good choice too and outstanding results but personally i see this being more of a filler rather than a cutter,limeprime on the other hand has a slightly more better cut into the paint especially by using a machine so basically better to remove scratches instead of filling.
7 Re: T-cut? on 8th April 2014, 1:01 pm
And thats why your the proffesional and im not lol ...
8 Re: T-cut? on 8th April 2014, 1:14 pm
Ajay.
Haha I try my best easiest way to explain to the owners there so much to it but I won't go into detail otherwise think I'm mad lol
9 Re: T-cut? on 8th April 2014, 3:53 pm
Indy
Mr nomad the ssr 2.5 is good but does cause marring on our top coat if we are not carful with it as Ajay said line prime is very good
10 Re: T-cut? on 8th April 2014, 6:19 pm
just get a broom and give it a damned good scrubbing with a bit of strong detergent
don't listen to ajay or indy there just detailers and don't know anything  Laughing
btw im joking about the detergent  drink
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
11 Re: T-cut? on 8th April 2014, 6:38 pm
Whats marring ?
You forget the brillo pad bob  Laughing
12 Re: T-cut? on 8th April 2014, 7:04 pm
Indy
Lol @ brush and detergent
Mr nomad marring is a form of smudging of the top coat due to excess machining where the compound being used has broken down soo much and it's physical property has changed .... Er just read that back to myself lol I'm confused
Basically it's smudging of the top coat if too much or too little product is used for a very long or short time in one area lol that's even more confusing doh
13 Re: T-cut? on 8th April 2014, 7:21 pm
Turbazz
Lol thanks guys! I shall definitely try it out
So do I wash the car then apply this and then wax or polish the car?
I only have auto glym deep shine polish
14 Re: T-cut? on 8th April 2014, 7:33 pm
Cheers indy .....i know exactly what you mean ......
15 Re: T-cut? on 8th April 2014, 8:39 pm
For paint buffties the pulsars paint work is piss poor, you can scratch it just by looking at it.
16 Re: T-cut? on 8th April 2014, 11:10 pm
Indy
Your welcome mr nomad
Or you can scratch the paint work by farting next to it at a distance of approx 1 meter after a vindaloo lol
Turbazz make sure u de grease the car first so the correct process would be
1) degrease everywhere
2) wash car
3) clay car using clay bar if u want to be anal
4) wash off clay
5) dry car
6) start machining (polishing)
7) wipe off polish
Cool use a solvent to remove all polish (this is pre wax stage)
9) wax car
10) stand back and admire ur hard work
Please note this is not going to happen in 2 hours or so, to do the job properly give yourself aleast 1 full day it's a real tedious process and make sure you have a lot of pain killer tablets to hand as your back will really hurt after lol
17 Re: T-cut? on 10th April 2014, 11:38 pm
Turbazz
